Old 08-31-2011, 08:23 PM   #1
White Coupe
My Ride: 340i
Do I need an alignment after replacing LCAB?
The title says it all. I replaced the LCAB and now I'm seeing a lot of inside tire wear. Should I have done an alignment?
Thanks!
F30 6-spd
E90 (hers)
981 (Porsche)
White Coupe is offline   Reply With Quote
Old 08-31-2011, 08:26 PM   #2
azshorty
My Ride: Hellrot 323CI
it would complimant it.
i know i did it when they were replaced.
azshorty is offline   Reply With Quote
Old 08-31-2011, 08:31 PM   #3
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
they can definitley cause alignment issues.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 08-31-2011, 08:56 PM   #4
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
If you're going to get an alignment I suggest doing your rear control arm bushings as well, they're probably shot. Then get a 4 wheel alignment.
Tim
tim330i is offline   Reply With Quote
Old 08-31-2011, 09:31 PM   #5
That-Guy
My Ride: '01 330i
If your seeing abnormal tire wear get the alignment checked. Something is not right, but i doubt its the bushing. Possible though, just unlikely.
That-Guy is offline   Reply With Quote
Old 08-31-2011, 11:38 PM   #6
taibinhvuong
My Ride: E46 99' 328i
Regardless to the cause by replacing LCAB or not, anytime you see a lot of or even some inside tire wear, you should at least get an alignment check.
taibinhvuong is offline   Reply With Quote
Old 09-01-2011, 12:39 AM   #7
missamo80
My Ride: 2001 325i
Yes. After an LCAB job, get an alignment
Neil
missamo80 is offline   Reply With Quote
Old 09-01-2011, 12:40 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yup get one.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-01-2011, 01:41 AM   #9
ShepsBMW
My Ride: '03 330i - sport pkg
Yeah get one, it'll save you money on tires and improves the ride big time
Sent from my DROID2 using Bimmer App
ShepsBMW is offline   Reply With Quote
Old 09-01-2011, 07:03 AM   #10
White Coupe
My Ride: 340i
Oh yeah... sorry, I didn't explain the whole thing.
Thanks to everyone for the comments.
See, it's my fiancee's car. If the alignment is off due to her hitting curbs, then that's on her. If it's because of me changing the LCABs, then I need to pay for the new tires. Which is what I'm going to do.
F30 6-spd
E90 (hers)
981 (Porsche)
