Old 08-31-2011, 09:17 PM   #1
hcardona111793
My Ride: 2004 325i
Exclamation TIPS! on installing Parrot BLuetooth + USA SPEC. experienced help needed!
hey everyone!
so i just bought everything to do the parrot + usa spec project into my 2004 325i!. i will be doing it this weekend but i am wondering if there are any tips any of you could give me when installing this? (if to use the parrot microphone/ where to put it, where did you route your USA spec? how was it? where is your outlet located? any recommendations?)
hcardona111793 is offline   Reply With Quote
Old 08-31-2011, 09:53 PM   #2
hcardona111793
My Ride: 2004 325i
Anyone!? please guys
Old 08-31-2011, 10:36 PM   #3
spencers
My Ride: 2006 330i
SEARCH.
Find delmarco's DIY threads. Follow them.
I have both installed. All the hardware and boxes are tucked away behind the glovebox.
spencers is offline   Reply With Quote
Old 08-31-2011, 10:39 PM   #4
moiz21
My Ride: 1999 323i 5-SPD
No real trick to the bluetooth hook up. Follow these instructions: http://www.bokchoys.com/differential..._bluetooth.htm
Really easy, just a bit time consuming. The biggest pain will be the vents. There are some clips on the underside that you need to free in order to get them to come out. And the best place for the mic is the factory spot. You may want to angle it so its facing the driver for better sound pick up, but that's about it.
As for the usa spec, is it the one you hook up via the radio or the cd changer?
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 08-31-2011, 10:41 PM   #5
Steve330ci
My Ride: 2006 325ci vert
When I installed mine, I found that there was just no room behind or beside the head unit to put the new connectors and wiring. What I did was remove the instrument panel gauge cluster to access a large space to the right of the cluster. Then, after connecting the new wiring, I pushed the bundle to the left of the head unit into the space accessible by removing the instrument cluster. Then, I reached in from the cluster side and tucked the wiring in. Then, I reinstalled the instrument cluster. Hope this saves you some time.
Steve330ci
2006 325ci vert
Steve330ci is offline   Reply With Quote
Old 09-01-2011, 07:18 AM   #6
hcardona111793
My Ride: 2004 325i
yes it is, and thanks man, this is what i was looking for!
Perfect, il make sure to keep that in mind. thanks!
Old 09-01-2011, 08:09 AM   #7
Lemonsqr
My Ride: 2001 TiAg 330i
clipped my mic right behind the mirror from the headliner. Works like a charm and is pretty much hidden from view.
Lemonsqr is offline   Reply With Quote
parrot bluetooth, usa spec
