Old 02-23-2013, 05:20 PM   #301
terzinator
My Ride: 325iT 5-sp RWD Sport
yeah, the stance on the coilovers is awesome. Is there any spring set out there that would approximate that stance?
When it's time to do my suspension (69K miles on the car), I envision going with Koni FSD's, but not sure about the springs. (Eibach pro kit?)
(My car has the OEM Sport Suspension.)
E46FANATICS Touring Forum!
terzinator is offline   Reply With Quote
Old 02-23-2013, 08:33 PM   #302
lab rat
My Ride: '02 330iT
It IS time to do your suspension at 69k
Koni FSDs are very good.
There are two ways to deal with uneven gap between front and rear. Add thicker spring pads in the back. Touring has 5mm pads on each end of each rear spring. 15mm pads are available from BMW.
In this case you want shorter springs - H&R Sport for sport suspension (same as H&R Race for non sport suspension).
The second way to do this is getting lower spring perches for the front. While more expensive I believe it is better way to go because you don't lose as much suspension travel compared to option one.
In this case you can use longer springs (could probably try to keep your OEM sport). Something like H&R Sport (for non sport suspension, I know it's confusing).
Look around the forum and ask owners what they run. Concentrate on the front, the rear can be raised (easy and cheap).
Because sleeper
Old 02-23-2013, 10:37 PM   #303
terzinator
I know we're veering off topic from your original thread, but we're talking alpine white sport wagons, so what the hey...
OK, so 69K is time to do suspension (I've read Mango's bible)... How can I tell that? I mean, it drives and handles great. Or is it all preventative?
So, keep the OEM sport springs, but get Koni FSD's and use lower front perches? Is that anything? (I like that idea, but not sure if it's the right way to go.)
Old 02-23-2013, 11:15 PM   #304
lab rat
My Ride: '02 330iT
Don't worry about the thread, I'll have to rewrite it properly in the Showroom section anyway.
At 70k the shocks are typically gone. It's hard to tell as the springs and stabilizers are pretty stiff and suspension travel is short. But you will notice the difference when you replace them.
You could start with the OEM springs and see how it looks if you don't mind taking the suspension apart couple of times.
I'm having hard time finding the lowering perches for e46. Bimmian and JLevisw used to sell them but I don't see them there now.
Because sleeper
Old 02-23-2013, 11:39 PM   #305
terzinator
Looks like supremepowerparts.com has the perches... $70.
http://www.supremepowerparts.com/143..._category.html
Old 03-19-2013, 04:23 PM   #306
lab rat
My Ride: '02 330iT
Ok, step one in new round of troubleshooting done.
Compression tested 180-185 all cylinders (dry test). Leakdown 10-12%.
It would be good to get some comparison numbers so I could guess the compression ratio. 185 seems pretty high to me on a b30.
This would confirm my suspicion of previously shaved head.
Next step will be:
Pulling the SC, replacing all vacuum hoses, cleaning/replacing ICV, replacing temp sensor an everything else I failed to do when I had the engine out. Doh!
If that doesn't fix it I'll be either adding head spacer or meth.
Because sleeper
Old 03-24-2013, 10:08 PM   #307
lab rat
My Ride: '02 330iT
Snapped couple of pics. Made me realize how much I suck at white balance.
As far as the looks I'm going to black out the window trim at front grille.
Because sleeper
Old 03-24-2013, 10:36 PM   #308
E RaK
My Ride: 2001 325xit
Super clean. Thinking about an MTech II rear end?
E RaK is offline   Reply With Quote
Old 03-25-2013, 01:26 AM   #309
lab rat
My Ride: '02 330iT
Maybe one day. I mainly put the front one on to get enough air to the heat exchanger for intercooler. I like the M-tech II look.
Because sleeper
Old 03-25-2013, 01:57 AM   #310
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
what is the sticker on the left back hatch?
/_________\
O==[][]==O
Old 03-25-2013, 09:39 AM   #311
lab rat
My Ride: '02 330iT
Just a dumb dealer sticker. It's been there for 11 years. I didn't think it would come off cleanly so I left it.
The car will need full respray eventually. I'll deal with it then.
I might change the colour to the 2006+ AW or some other brighter white (Audi maybe?)
Because sleeper
Old 04-05-2013, 10:01 AM   #312
jaredstaubin90
My Ride: 2001 BMW 330i
Awesome build! Been glued to my phone for the past 30 mins reading through everything! Great looking wagon. Great Job with all the work, wish I was gifted and could do all that work by myself. Love the car!
jaredstaubin90 is offline   Reply With Quote
Old 04-05-2013, 10:19 AM   #313
lab rat
My Ride: '02 330iT
Thanks. One of the points of this thread was to show that it's surprisingly easy to do something like this with no previous experience.
Because sleeper
Old 05-24-2013, 01:05 PM   #314
lab rat
My Ride: '02 330iT
Updates:
I ordered bunch of parts to replace when I take the SC off - ICV, knock sensors, crank position sensor, vacuum lines, and some more cooling hoses/pipes. Stuff should be here next week.
I broke one foglight (small rock).
Last week I started hearing strange noise from the rear axle. Turns out it's a diff. It only makes the noise when decelerating. I'm gonna take it apart to see what broke. I hope it's the main diff gears and not the limited slip.
Anyone has a spare diff? I don't care what the ratio is as long as it has 6 hole input flange (diff from a 330).
Also noticed one of the tires is busted. Not worn out treads but something inside that makes it wobble. I'm likely not gonna go with the Hankooks again.
Because sleeper
Old 05-24-2013, 01:28 PM   #315
daniel_f.
My Ride: 330iC
I hope you donīt mind testing a bit...
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 05-24-2013, 02:43 PM   #316
lab rat
My Ride: '02 330iT
Ok, testing what?
Thanks for reminding me to paint those intercooler brackets
Because sleeper
Old 05-26-2013, 04:48 PM   #317
E RaK
Gahd this is still amazing!
Old 06-01-2013, 03:51 PM   #318
lab rat
My Ride: '02 330iT
****, I forgot to order the intake gasket
Because sleeper
Old 06-01-2013, 04:04 PM   #319
330i ZHP
330i ZHP's Avatar
Make it yourself - I have made quite a few of them. Time consuming but easy to do
/_________\
O==[][]==O
Old 06-01-2013, 06:40 PM   #320
Minnoe07
My Ride: 2004 BMW 330Ci
Project: Sleeper wagon
I have a spare differential but it will probably be a lot of shipping to get it there.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
