Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
Rating:
Display Modes |
#421 |
Do you have a link or more info on this? My 2001 330Ci has issues with the tail lights going off and on and the head light flicker.
#422 |
Will the dealer do the recall fix if i have aftermarket LED lights?
EDIT: I called the dealer and they wont touch it.
![]() Last edited by n2Bimmer; 05-01-2012 at 02:04 PM. |
#423 |
i found out my e46 has this problem too, unfortunately i found this out as i put in the LAST of our TMS clears pkg. i don't feel like putting it all back to stock so i'm just going to see if they'll fix this with the TMS' in. i'll probably bring the original housing with me as my passenger ground has melted and pulled out of the connector. For now i just taped it up and left the light backing off. i called and my vin is included...i just didn't bother telling them about the lights. we'll see.
| 89 M3 | 93 M5 | 87 190e 16v | 03 325i | 03 X5 4.6is |
#424 |
Be prepared to be turned away when you get there.
Want an easy way to find your cabrio specific needs?
Tired of seeing cabrio specific info showing up in your search results when you don't have a cabrio? Either way, head over here and VOTE! Everyone can benefit. It takes only mins to actually set up, so there really is no good reason not to have one!!! Click here to submit your vote! |
#425 |
i called them back and asked them about the lights, they said ok, just bring the old burnt housing along. we'll see...
#426 |
Clears shouldn't matter as long as the bulb housing is a factory part. My recall fix has been acting up. I keep getting a bulb out from driver rear.
#427 |
The wife says they fixed the connectors with no issue, this was with TMS clears installed not the OE tails. Gonna scope it out when I get home.
#428 |
Wonder if I can get my front turn signal replaced because of condensation
![]() Sent from my MB860 using Bimmer App |
#429 |
I have an 01 330Ci and the dash warniing light (light out) is on/off intermittently - both rear lights show up. Seems to be assicociated as much with humidity as anything. My bulb boards and plug thereto all look good - no evidence of deterioration due to excess amperage etc on either male or femaile side. I nonetheless ran a ground wire directly from battery ground to the ground-circuit on both boards (L and R) , but to no vail. Inhdicatgor light still on / off unpredictably. Any suggestions would be appreciated.
(01 not covered in recall) |
#430 |
Hey all,
I had my recall work done in the winter. It didn't fix my tail lights tho which constantly have to be wiggled back into place because the bulb housing fixture and wire connector have giant burn holes in them (I'm assuming from the failed ground). Would you think the dealer should/would cover this and help get them fixed up? Before I could play with the wires and get them to light up appropriately, but no more. Anyone have experience with this? Thanks (and yes, I know the obvious answer is to replace it myself and save myself the hassle lol) |
#431 |
From what I see elsewhere on this site, your problem with an 02 should be covered in the recall.
#432 |
Finally..better late than.... ...we will see if they will fix on my "2001 ci".... so many other issues with this vehicle.. always a sensor..or some other minor *big $ issue" .. lol ultimate $$$ machine
#433 |
I have the same issue. It doesn't affect the drivability of the car but it is certainly annoying. Does this recall still apply?
#434 | |
I bought a 2002 325i a little over 2 years ago. Sometime, in the past few months after reading about this recall, I took the car to the dealership to see if they'd cover it. Interestingly enough, the service advisor mentioned it to me without my asking. It turns out, the previous owner had already had the issue fixed, but it's nice to know BMW offered it anyway. Granted, this was in Canada. I'm not sure about the US, but ideally they should still do it. |
| Tags |
| e46, recall, tailights |
