Would Cam position sensor keep your car from starting? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.60 average. Display Modes
Old 09-02-2011, 08:03 PM   #1
bmw East N Bull
My Ride: Bmw
After reading the codes, i got 2 Misfires and cam position sensor, would that keep my car from starting, My car is still sitting in my drive way and hasnt started for a week noww?
bmw East N Bull is offline   Reply With Quote
Old 09-02-2011, 08:04 PM   #2
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Yes, of course it would.
hi its me alec is offline   Reply With Quote
Old 09-02-2011, 08:08 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yup. Which sensor is it? The DIY is easy by the way and you can get the OEM (ONLY OEM) sensor from ecstuning.com
Old 09-02-2011, 08:10 PM   #4
bmw East N Bull
My Ride: Bmw
Its coming up as Cam position sensor
Old 09-02-2011, 08:12 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
But it should say like sensor a or b or something like that.
Old 09-02-2011, 08:16 PM   #6
bmw East N Bull
My Ride: Bmw
i will check it tommorow first thing, Im not really farmilliar with the sensors but is there a difference with Camshaft and crankshaft sensor??? where is the crankshaft located
thanks
Old 09-02-2011, 08:18 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well I'm saying there is an intake sensor and an exhaust sensor. Get back to us when you can.
Old 09-02-2011, 08:18 PM   #8
hi its me alec
thanks
The crankshaft is toward the bottom of the block. Cams are right underneath the valve cover up top. All the sensors are toward the front of the engine
Old 09-02-2011, 09:10 PM   #9
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
My understanding is that a bad crank sensor would cause the car not to crank. A bad cam sensor, the car would crank, but not start.
But, just to complicate things, I'm pretty sure guys have gotten cam sensor codes, replaced them, and still have issues starting. I don't know what else might trigger a cps code that's not the cps...something upstream of it. Timing is pretty well fixed. Only other thing that messes with timing is the vanos...maybe it's retarded--literally and figuratively!
I don't know that the vanos can get stuck in a position where it's retarding or advancing incorrectly and thus the cps might pick up on that. Just a guess. I'm not a mechanic and don't play one on the Internet!
Search cps, camshaft position sensor, in advanced/title search along with 'no start' and see what you get. You're not the first no start with cps codes I'm positive. Don't go ordering parts just yet. Do the research.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 09-02-2011, 10:35 PM   #10
Loaded325i
My Ride: bmw 325i
thanks
OP stay very clear from your engine please. That's all Im gonna say, I warned you.
It doesnt matter which sensor goes bad, the car will still turn over no matter what. The sensor going bad wont keep the battery from applying voltage to the starter. Thus turning over the engine. The crankshaft position sensor and camshaft position sensor(s) work in unisyn with eachother to determine the correct time to apply voltage to any specific cylinders at that time. Vehicles WITHOUT distributors typically have these types of sensors otherwise the car has no idea when to apply spark and to what cylinders.
Loaded325i is offline   Reply With Quote
Old 09-03-2011, 07:31 AM   #11
SweetBMW
My Ride: 318CIA
Bad Crankshaft sensor = car will start, but will require a few more rounds on the starter motor before the cam position sensors take over RPM reading and firing positions. Will also (possibly, not all cars do this) struggle to get past 4000rpm. lots of misfire, hesitation of throttle.
Bad camshaft position sensor: car will start, (might also require few more rounds on the starter motor), and have reduced power.
SweetBMW is offline   Reply With Quote
Old 09-03-2011, 07:48 AM   #12
dmax
dmax's Avatar
Goes to prove you can't trust what you hear on the Internet! If you're right, Loaded, then I apologize for passing along rumors...as it seems I may have done regarding a bad crank position sensor causing a no-crank.
We have a number of seasoned professional mechanics here, and it's easy to tell the really good ones--they're patient, explain clearly, and don't condescend. You can recommend getting the car to a shop without also insulting someone. I do it all the time!
dmax on Facebook
Mangofy your E46!
Old 04-08-2017, 05:52 PM   #13
Datbmwguy
My Ride: 2000 E46 323i
Send a message via ICQ to Datbmwguy
Did you ever figure out what the problem was i'm having the same issue
Datbmwguy is offline   Reply With Quote
Old 04-08-2017, 07:19 PM   #14
jdstrickland
My Ride: '94 325iC & '00 323i
1.) Closing in on 6 years since the last post on this thread.
2.) What issue are you having? The crank or cam position sensors will give you a Check Engine light and a code. What is your code?
Old 04-17-2017, 05:24 PM   #15
Datbmwguy
Camshaft position sensor a Is the only check engine light I replaced the starter crankshaft sensor ignition switch clutch switch I don't know what else to check all the fuses and relays are good
Old 04-18-2017, 05:03 PM   #16
SSchwab
My Ride: 99 328i, 00 Z3 2.8
Crank but no start problem?
Have you confirmed you have gas in the tank and fuel pressure at the rail?
SSchwab is offline   Reply With Quote
Old 04-19-2017, 12:41 PM   #17
Datbmwguy
I have more than a half tank is fuel coming out to see your real when I pulled it and that would cause the car not to crank if the pressure isn't correct cause the starter not too crank
Old 04-19-2017, 01:29 PM   #18
SSchwab
What is your battery voltage reading before cranking?
Old 04-19-2017, 01:52 PM   #19
jfoj
My Ride: 330CiC, M5, X5, E93
How about a COMPLETE and CLEAR sentence about what is going on?
Not sure if this is Voice to Text gone bad or typing while driving?
Is this a no crank problem?
Is this a crank, no start problem?
Does the tach move to 100-150 RPM if this is a crank, no start condition?
Do you have another key?
Old 04-19-2017, 01:59 PM   #20
SSchwab
I am trying to walk this guy through step by step.
