E46 Xi Forum
Old 09-02-2011, 10:52 PM   #1
link101b
My Ride: 2004 330xi
blown head gasket
So my head gasket popped from what i understand this is a common problem with the e46.
I have decided to do the repair myself
I found this guide on pelican parts:
http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
But im not sure this is for a 2004 330xi. Anyone know if this guide will work?
The head gasket kit from Victor Reinz seems like a good option to go with:
http://www.pelicanparts.com/cgi-bin/...2F%30%32%29%20
Anyone have any advice or a better walkthrough to follow? What special tools will I need? Any other common maintanence I should do while I have this all torn apart? I would appreciate any input.
Thanks in advance!
Bob
link101b is offline   Reply With Quote
Old 09-02-2011, 10:54 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes, the guide will work for your car.
Old 09-02-2011, 10:59 PM   #3
link101b
My Ride: 2004 330xi
Great! thanks for the fast reply.
Old 09-03-2011, 12:07 AM   #4
link101b
My Ride: 2004 330xi
Any other advice?
I'm going to start taking her apart tomorrow and get parts ordered. I'll clean everything up during the week and put her back together next weekend if parts get in. I'll try and post some pics throughout the week.
Old 09-03-2011, 11:06 AM   #5
White_Knuckles
My Ride: 2003 325xi
Good luck brother. The weight of the head is serious I recommend an assistant.
Care to share the story and your mileage? - like a "this can happen to you" narrative. Did you have an over temp issue that caused it?
Old 09-05-2011, 11:36 PM   #6
link101b
My Ride: 2004 330xi
Well, we are stuck for the time being...wanted to get it all torn apart this weekend but ran into a special tools prob.
As far as the story goes, its not that interesting. I was going over Parleys summit just outside Park City, UT. Got to a gas station on the other side to get gas and it died in the gas stall. No warning indicators or anything came on and I never noticed if the temp was pegged before stall.
Checked fluid levels and coolant was gone, so I got some and it drained instantly, called a tow truck and took it to the shop. They said cracked radiator so I said fix it. After that was fixed the engine still didnt pressurize and dumped fluid everywhere, pretty much screaming head gasket. I didnt feel like dropping 3k + to a shop so decided to recruit my dad and do it ourselves (he is a small engine deisel mechanic).
We started out well, got all the plastic crap off:
Had a little issue getting the coolant overflow off the radiator but once we did the radiator came right out:
Lost my first knuckle with the radiator
Got the belts off:
Got the head cover off and removed plugs:
This is where we got stuck. Everything we have read said the cams are very tempermental. We went over options and decided there was nothing we wanted to do with them until we get a tool. We still decided to continue and get the head off but ran into a problem with the second chain.
The guide difers on many places and we didnt see how to get this off without removing the crankshaft pulley. And off course we dont have a pulley tool...
All the specialty tool shops I could find in Salt Lake were closed for labor day weekend so we decided to call a stop. All in all it went well, and got in many Labor day beers
You guys see anything we missed?
ID:	415706   Click image for larger version
ID:	415707   Click image for larger version
ID:	415708   Click image for larger version
ID:	415710   Click image for larger version
Old 09-06-2011, 02:32 PM   #7
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Good luck and keep us posted (with pics, please!)
Nervous is offline   Reply With Quote
Old 09-06-2011, 07:52 PM   #8
link101b
My Ride: 2004 330xi
Have called all over Salt Lake City and cannot find any shop that rents BMW specialty tools, not even the dealership...
Anyone have a suggestion where I might find these? If not I guess i'm buying them then I'll rent them out. This is a little frustrating
Old 09-06-2011, 08:04 PM   #9
White_Knuckles
My Ride: 2003 325xi
You need the trick tools for sure.
The head must be sent out for crack and warp inspection. The last concern is the integrity of the head-bolt threads. Some have tried just replacing the head gasket as a quick and dirty fix. It's a bad day when they discover instant fail as the head was warped or they can't quite torque the head down to specification. The block threads under stress stretch as the head may have moved upward (warp) yanking on the bolts. The threads are shot and will never take torque. Some have used tapped thread inserts that hold. New bolts are required.
BEFORE removing the head test to see if the bolts hold torque. Back off the bolts and try to re-torque them in sequence. Now they're used and will stretch a bit but should pull close to spec. You're looking for when it feels stripped or way off from holding torque. For a proper test you would burn a new set of bolts. This will tell you absolutely if any threads are toast.
Old 09-06-2011, 08:16 PM   #10
link101b
My Ride: 2004 330xi
thats a great idea, I was going to get new bolts regardless.
I am really concerned about ruining the camshafts, any thoughts there?
Old 09-07-2011, 08:32 PM   #11
White_Knuckles
My Ride: 2003 325xi
Not sure how you could ruin them? You of course have a proper manual as in a Bentley? With the cam positioning/alignment tools you should be fine disassembling and reassembling. If you're winging it with limited resources then yes, you could seriously mess up timing damaging something. Research is everything for this surgery.
Old 09-09-2011, 11:08 AM   #12
link101b
My Ride: 2004 330xi
OK, got my parts ordered, Javier at Pelican Parts was very helpful.
I got coming:
Head Gasket kit (includes all seals from the head up)
Head bolt set (includes washers)
vanos cam timing master kit (includes 5 little irritating must have tools)
Camshaft hold tool with flywheel lock
6 quarts oil and oil filter
1 gallon BMW coolant
Everything was in stock and should be here by mid next week.
Figured out a fix for removing the cams, the dealership said they will remove them, let me take the head to the machine shop and then put them back in for $250. Ripoff but its safer then having to buy new ones for $650 each.
I'll add a couple pics when we get the head off this weekend.
Old 09-09-2011, 09:59 PM   #13
White_Knuckles
My Ride: 2003 325xi
That's a deal. They have the liability to time it right. Pelican is great, orders always come through on time well packed and correct.
Old 10-04-2011, 07:29 PM   #14
link101b
My Ride: 2004 330xi
ok, this project has become a nightmare, anything that can go wrong has...just got to keep pluggin along though, i guess...
New question: I accidently broke the plastic timing chain rail guard and will have to replace it. Do I have to take the crankshaft out to get the front plate off to do this?
Thanks again all.
Old 10-04-2011, 08:15 PM   #15
link101b
My Ride: 2004 330xi
ok we just put serious leverage on the crankshaft bolt and not a budge...what am I missing?
Old 10-05-2011, 04:37 AM   #16
Pierce1
My Ride: 03 330xi
Reverse thread??
Pierce1 is offline   Reply With Quote
Old 10-05-2011, 08:38 AM   #17
Fred The Puppy
My Ride: 330XI
Not reverse thread, but is factory torqued to 300 ft/lbs
Fred The Puppy is offline   Reply With Quote
Old 10-05-2011, 09:55 AM   #18
link101b
My Ride: 2004 330xi
ok that makes sense, going to need some more leverage. thanks
