Old 01-07-2013, 01:29 PM   #21
Think0rz
My Ride: 05 AW M3
Originally Posted by Cipri View Post
A second hand vanos unit is 350$ here local, I don't have to pay for labour because I can make the swap, already changed the vanos bolts by myself.
I think I will wait until spring when building the engine and see what remaining budget I have.
I guess at $350 its worth a shot to see if it will fix your problem. If it does then it was a relatively cheap fix which we can all appreciate
Think0rz is offline   Reply With Quote
Old 01-07-2013, 01:43 PM   #22
InDiGlOM3
My Ride: HPF M3 stg 2.5
How long after you replaced bolts did your vanos go downhill?
Sent from my PG86100 using Bimmer App
Old 01-07-2013, 01:55 PM   #23
Cipri
My Ride: E46 M3 2002
It was broken before I changed the bolts, first I thought that changing the bolts will fix the problem
Cipri is offline   Reply With Quote
Old 01-07-2013, 09:14 PM   #24
InDiGlOM3
You could tell once you got into it that it wasnt the bolts right?
Old 01-08-2013, 12:36 AM   #25
Cipri
Yes, it's pretty obvious because all the bolts are in position - nothing moves or has any play.
Old 01-08-2013, 08:20 AM   #26
InDiGlOM3
Just making sure, Ive done them myself. Just reading into your situation, you said your vanos went and you changed bolts. I was thinking you changed bolts then later the vanos went out which in my mind would say something you did was wrong which then id say i wouldnt do the swap if i were you. But obviously youll be fine. Where did your learn the process? Its pretty easy but alot of people mis a small step that causes alot of noise and still think something is wrong with vanos.
