Old 09-05-2011, 12:20 AM   #1
mcguiver7
My Ride: 323i
new fan clutch but still have truck noise
2000 323i w/ 110k miles
My problem is I just replaced the fan clutch with a brand new one (MTC) from ecs tuning. It stays locked at start up even when the engine is cool and continues to stay locked regardless of temp or rpm. Any ideas as to why a brand new fan clutch would constantly engage?
The domino effect started with me changing the coolant (used bmw coolant). Expansion tank cracked a week later (older style) and replaced with the newer style (red bobber stick). Then the water pump bearings went and I replaced that. Then the fan clutch was constantly engaged. So I replaced the fan clutch with a brand new one (MTC) from ecs tuning. Also noticed the lower intake boot elbow had a few large cracks (but oddly no lean engine codes) so that also got replaced.
Completely off topic, but also wanted to mention i'm on my third front driver window regulator. Last one I bought from ecs tuning lasted 3 months. The rear driver side regulator just went out for the 3rd time as well. both passengers have gone out at least once. Tracks have all been greased. The door ajar function in the door lock module on both front doors have failed. Cam sensor failure around 60k. This evening the oil light came on at start up for a brief second. 5 bucks says that sensor is bad.
I think my 87 325is (295k miles on the odom) was more reliable than this car. Venting complete............
mcguiver7 is offline   Reply With Quote
Old 09-05-2011, 02:57 AM   #2
Shmo
My Ride: 2000 323i
Send a message via AIM to Shmo Send a message via MSN to Shmo Send a message via Yahoo to Shmo
If you want the truck/bus sound gone you need to do the electrical fan swap
You did pray to your BMW shrine first, asking the Great Roundel for guidance on parts' choices first, right?
Shmo is offline   Reply With Quote
Old 09-05-2011, 09:05 AM   #3
mcguiver7
My Ride: 323i
I read up on it, but i'm having a hard time justifying the costs when a fan clutch is $65-165. I was just hoping maybe there is some sort of break in period. Doesn't make sense that initially the noise wasn't there. Maybe the MTC fan clutch is junk?
00 323i
78 911 targa
Old 09-05-2011, 09:25 AM   #4
avglushk
My Ride: e92
Truck noise is always there. U probably just didnt pay that much attention to it. In winter time it's hard to hear it but in summer time it's always there. U need to do electrical fan swap like Shmo said. Hope that helps.
Originally Posted by Arsevader
Sorry to hear about your mirror. This is what happens when you don't change your mirror fluid at the recommended intervals.
For Sale: 1. OEM used headlights and corners, see link http://forum.e46fanatics.com/showthread.php?t=884565
2. 2 brand new Bosch post cat oxygen sensors
avglushk is offline   Reply With Quote
Old 09-05-2011, 09:53 AM   #5
iansanderson
My Ride: 2001 330CiC
you need to return the MTC part and buy an OEM part or at the very least, a BEHR part.
The new fan clutch is defective.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 09-05-2011, 11:20 AM   #6
Shmo
My Ride: 2000 323i
The electric Behr fan is $184 right now
Old 09-05-2011, 11:27 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 on getting a Behr or Sachs clutch, but.... I would just double the price, do the swap and sell the aux fan and the other parts. THE best thing I ever did to the car.
Old 09-05-2011, 01:51 PM   #8
mcguiver7
My Ride: 323i
And that's for everything plug and play? Can you tell me who's selling it for that much? Considering the mechanical oem is 165, i'd spend $20 more for the electric.
00 323i
78 911 targa
Old 09-05-2011, 01:55 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Here is my DIY
http://e46fanatics.com/forum/showthr...735&highlight=
Here is the part: 17117561757
http://cgi.ebay.com/ebaymotors/BMW-E...item1e65f7dc1d
Old 09-05-2011, 02:15 PM   #10
polychrome
My Ride: 2002 325i
+1
Taking out the mechanical fan / aux fan combo and replacing it with an electric fan will make that bus/freight truck noise go away. I did mine last week and I'll never go back to the OEM setup.
polychrome is offline   Reply With Quote
Old 09-05-2011, 07:53 PM   #11
Twright
My Ride: 1989 325ic, 1999 328
Before you spend money on an electric fan, make sure it's the fan that's making the noise. On my car, the noise was the power steering pump. Take the mechanical fan off and drive it. If it still makes the noise, it's not the fan. Be careful when you do this and keep the car moving, so that it does not overheat.
Twright is offline   Reply With Quote
Old 09-16-2011, 07:56 PM   #12
mcguiver7
My Ride: 323i
Did the electric fan swap today. only took about an hour. noise is finally gone and it even feels a bit more peppy without the drag of the fan.
00 323i
78 911 targa
