Old 12-30-2011, 03:19 PM   #21
Mr_325
My Ride: 2007 X5 3.0Si
my EE's i ordered have their own harness and everything so i actually had to take out my sedan taillight fix i did with the grounding wire
Mr_325 is offline   Reply With Quote
Old 12-30-2011, 03:44 PM   #22
My Ride: 2016 Lexus
I must be lucky cause my EEs have been on my car for a year and still work perfectly. I am however getting RCR depos in the next day or two and will put mine up for sale. $60 local
Old 12-31-2011, 05:10 AM   #23
xlzx90
My Ride: E46 320d
Originally Posted by trj View Post
Yup that means the lamp is faulty.
You might want to check the connections in side the lamp housing. I have done a DIY on cutting the housing of EE tails, the link is somewhere above. Use that DIY and check the connections. Resolder the wires. Solder joints are the weakest links on EE tails.
Good luck my friend.
I try to blank the brakelight wire and take a cable direct to the lamp. Maybe its a solution. Its like dont get enough charge for lighting harder.
xlzx90 is offline   Reply With Quote
Old 01-02-2012, 02:53 AM   #24
xlzx90
My Ride: E46 320d
I have send an email to EE. They reply and they are going to send me replacement lamps!!! Now I'm wainting.
Old 01-02-2012, 03:29 AM   #25
trj
My Ride: 325Ci
Nice I didn't know your lights were under warranty. Good that you didn't have to go through cutting the tail lights.
Happy for you man.
Happy new year
Old 01-02-2012, 04:15 AM   #26
xlzx90
My Ride: E46 320d
Happy for you man.
Happy new year
nope,they arent under warranty! Im so happy. theye were very friendly and so on.. so,have
a good new year,haha
Old 01-02-2012, 04:17 AM   #27
trj
My Ride: 325Ci
You got lucky, I get crap even when I ask something to be replaced under warranty. Happy for you sir.
Old 01-02-2012, 05:01 AM   #28
xlzx90
My Ride: E46 320d
Maybe its why I emailed the motherfirm not the dealer! I wrote directly to taiwan to the industry!
Old 01-23-2012, 03:35 PM   #29
Shayn
My Ride: 325ci
how did you do that? my eagle eye leds are messing with me!
Shayn is offline   Reply With Quote
Old 02-13-2012, 10:21 PM   #30
trj
My Ride: 325Ci
Alright I guess its time for me to do this trick now.
My drivers turn signal is whacking out on me.
Sometimes the work and sometimes done.
And sometimes the LEDs are too weakly lit.
All the LEDs are working, just the whole turn signal cluster is acting up.
Havent swapped the lights to check, because its intermittent and very cold out there too.
What would you guys suggest? OP?
I guess you had the same issue and used graphite pencil trick, shall I just take the box out and solder the 2 pins?
Old 02-19-2012, 07:28 PM   #31
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
I'd graphite it first. I'm not familiar with how the electronics work - so I'd defer on the soldering idea.
phamine is offline   Reply With Quote
Old 02-28-2012, 12:13 AM   #32
rlan214
My Ride: 2001 325xi
ive soldered the 2 pins and that fixed my turn signal but one of my brake light is still out and I know its the wiring because I swapped out the wiring the broken brake light was swapped also any more pins need soldering ? or pencil tricked ?
rlan214 is offline   Reply With Quote
Old 02-28-2012, 12:46 AM   #33
trj
My Ride: 325Ci
Thanks guys, I will try to solder them since they are supposed to be bridged anyway.
Just to confirm are we talking about these two pins?
Old 02-28-2012, 12:49 PM   #34
rlan214
My Ride: 2001 325xi
this is what I soldered
Old 02-28-2012, 12:50 PM   #35
rlan214
My Ride: 2001 325xi
I prolly messed it up tho lol so someone pls verify
Old 02-29-2012, 03:02 AM   #36
trj
My Ride: 325Ci
by looking at the circuit board, the 2 pins you soldered looks like they are not meant to be connected. But it worked for you
Don't know if I should try that. lol
Will wait for more inputs.
Old 02-29-2012, 04:47 PM   #37
e4sixxx
My Ride: 2000 328ci
I'm having the same issue and called ddm they claimed never to hear about these issues, but one question I have is what exactly does the graphite do? Act as a solder less connection?
e4sixxx is offline   Reply With Quote
Old 02-29-2012, 04:56 PM   #38
trj
My Ride: 325Ci
To my understanding, graphite pencil does exactly what soldering does but in a reversible way.
Old 04-30-2012, 05:48 PM   #39
trj
My Ride: 325Ci
Alright, finally found the fix(at least for mine). Mine are eagle eye tails.
Looks like the solders start to crack(stress cracks may be) and the connections get very fragile.
I had to play around with it a couple of times but finally found the pin that was to be re-soldered.
If anyone has this flickering issue, dim blinkers or blinkers working sometimes only, try this before replacing the little resistor box.
Resistor boxes can be ordered via Bryan@jlevi, so if it doesn't work don't hesitate to order from him. Great guy.
Ok, DIY:
pry open the little black box stated in the above posts.
press(hold) both sides of the board at various places while the blinkers are ON.
If you find a spot where you hold and the lights work properly, note(mark) that spot. That is the area you should be concentrating on.
Check the solder joints on each pin in that area. If you see any cracks or notice anything not touching, remove the old solder(use de-soldering braid) or just solder on the joints again.
I had to solder 3 points to find the one that was the culprit, so don't hesitate to try.
My lights are working perfectly fine, it has almost a month I did this repair and the lights have held up.
If it doesn't work, order a new box.
Old 06-22-2012, 05:57 PM   #40
trj
My Ride: 325Ci
Do not solder those two together.
It will turn off the whole light when you press the brakes at night(when you have your tail lights ON).
