Sponsored by BAVSOUND
Old 09-06-2011, 04:42 PM   #1
steve108819
My Ride: 2002 325xi
Just fixed my AM radio reception. Super easy
I just got my '02 325XI last month and noticed right away that the AM radio reception was virtually non-existent. Finally got around to checking into it today. All I did was unscrew the antenna amplifier connector, blew the dust out, than screwed it back on. That's it. BTW I read in various places that you had to take the light out before you remove the C pillar. I didn't do it that way. Just pop the two upper clips out than remove connector from back of light. Whole thing took about 5-6 minutes and most of that was trying to locate exactly where the clips were located while removing the pillar. Just wanted to pass on how quick and simple this fix actually is. It may or not be what's wrong with your car, but it's worth 5 minutes to find out.
steve108819 is offline   Reply With Quote
Old 12-09-2011, 10:14 AM   #2
cbuniva
My Ride: 2002 330XI
Thanks for the advice. I have been having the same troubles with my 2002 330XI and will attemp to fix the bad reception problem now having read how easy it was for you.
cbuniva is offline   Reply With Quote
Old 12-09-2011, 10:17 AM   #3
Bartacus
My Ride: 2002 320i Sedan
This is great info! The radio reception on my E46 sucks too! I wonder if anyone has done a DIY for anything antenna related. Since I'm a noob, I could really use some pics.
Bartacus is offline   Reply With Quote
Old 07-05-2012, 12:23 PM   #4
AndyC69
My Ride: 320i SE E46
I can confirm the Ariel/antena location for the E46 (320i) is in the near side rear roof pillar (RHD vehicles) or off-side (LHD vehicles).
My problem was fixed by removing the door seal near the pillar, removing the pillar lining; light left in situ but disconnected to allow more space and tightening the co-ax connection to the amplifier. No special tools were required. AM reception is now perfect.
Please note that FM generally will work with little or no ariel.
AndyC69 is offline   Reply With Quote
Old 06-04-2013, 04:17 AM   #5
Cupa t
My Ride: 320
**I know this is an old post**
But not on mine it doesnt...it's a pita, I can see me putting a proper one one, I just cant be arsed with all this fancy electronic boxes to enhance a radio....a good old aerial....simple!
Cupa t is offline   Reply With Quote
Old 06-07-2013, 10:22 AM   #6
Linx
My Ride: '02 BMW 325iT
Anyone know if its in the same spot on a touring?
Linx is offline   Reply With Quote
Old 07-12-2013, 04:10 AM   #7
uzz32soarer
My Ride: 2002 E46 M3
No FM radio on 2002 M3
Hi guys,
First post here and new owner from Australia. I have an Imola Red 2002 M3 and love it but can't get the FM radio to work. The car has Becker Business radio, TV, CD and no NAV.
TV, AM, CD all work perfectly but FM wont even pickup a station when auto scrolling. If you manually enter an FM station, memory holds the numbers but no FM sound at all.
Is this likely to be an antennae module failure or an entire radio module failure?
Seems that USA / UK / Oceania antennae units all work on a different frequency to cater for various world destinations.
Any help seriously appreciated. Any tests that I can do to ensure I have power at the radio or antennae?
Here's a pic of my centre console and head unit for reference.
Thanks in advance.
Rob.
Name:	HK Head unit.jpg
uzz32soarer is offline   Reply With Quote
Old 07-12-2013, 12:37 PM   #8
Halston@BSW
My Ride: E30 X5 TJ
Checking the connections is always number 1. Sometimes it works. Sometimes it doesn't. It's 'free' so worthwhile!
Halston Pitman
rhp@bavsound.com | ext. 104
BSW | Audio Solutions for YOUR BMW
www.bavsound.com | 404-963-8857
iPod Integration | Plug & Play Speakers | Subwoofer Solutions | Satellite Radio | HD Radio | Bluetooth
Halston@BSW is offline   Reply With Quote
