2005 325i no start condition - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-07-2011, 08:48 AM   #1
curt2199
My Ride: 05 BMW 325i
The car began randomly not starting.
The car has 80k mi. The battery is a year old Napa Legend 75 month that has been on the charger overnight to make sure it has a full charge and tested fine at autozone. I just replaced the starter with a reman'd Bosch thinking maybe it was a bad spot in the starter. I've also tried both keys and it doesn't make a difference. That didn't fix it so I was playing with the key in the ignition and narrowed it down to if I turn it over to start, it won't fire, but if I hold the key there and turn it a little back and forth while maintaining the start position of the switch, it will start.
Does is sound like an ignition switch? I don't want to just keep replacing parts. I've had the car 6 months and am a new fuel pump and starter(although not required it cranks over a lot faster now) in for the 10k mi I've had it, not impressed so far.
curt2199 is offline   Reply With Quote
Old 09-07-2011, 08:55 AM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
It sounds like it could be the ignition switch, however the tale-tell sign of an ignition switch failing is the dashboard lights... Which ones are you getting when it starts versus which ones you're getting when it's not starting... I had a similar issue which proved to be an ignition switch failing and when I paid attention I noticed I wasn't seeing all of the dashboard lights when it wasn't starting... Just my two and a half cents worth.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 09-07-2011, 09:03 AM   #3
curt2199
I'm getting all the normal lights that I can tell when I turn the key on, batt, service engine soon, EMS, etc. When they car is on, not other lights besides my brake pad wear indicator which has always been on since I got the car. I know the pads are good so I'm just thinking its a bad wear sensor there.
Old 09-07-2011, 09:09 AM   #4
curt2199
I just bought a confirmed working used one on ebay for $17. I'll give that a shot and see if that fixes the problem.
Old 09-07-2011, 10:24 AM   #5
Zchild
Is there a difference in the dashboard display when the car starts versus when it does not...
Old 09-07-2011, 10:28 AM   #6
curt2199
a lot of the lights are lit up with the car in run and not started. Then when it does start no lights other than the brake pad wear indicator however I did remember that the right rear tail lamp light out and trunk lid open indicator do go on and off frequently.
Old 09-07-2011, 11:44 AM   #7
Zchild
Got cha; however I'm speaking specifically when you turn your key to position #2, the key position prior to starting the car. You should see dashboard lights both when it will start and when it won't. When my ignition was failing there was a difference in the lights I was seeing when the car would start and when it wouldn't. When it would start I was getting all of the lights and it wouldn't I was only getting half of the dashboard lights.
Old 09-07-2011, 01:23 PM   #8
curt2199
Lights seem to be the same... in fact it seems that it will start every time now that I know I have to hold the key in the start position and move it a bit to get it to crank over.
Old 09-07-2011, 01:27 PM   #9
Zchild
That's both good and bad; it still leads me to believe that your ignition switch is on it's way out...
Old 09-07-2011, 01:28 PM   #10
curt2199
Yeah I should get the replacement by friday so I'll give that a shot and see if it fixes it.
