Go Back   E46Fanatics > Everything Else > The Off-Topic > Food Talk
Food Talk
Do you like food? If so, you came to the right off-topic section. Discuss your favorite food topics here!
Old 09-09-2011, 12:22 PM   #1
pakman3
My Ride: piece
Arrow shark fin soup
INGREDIENTS
1 pound shark's fin, about 8 pieces
16 cups water
6 large dried black Chinese mushrooms
6 canned bamboo shoots, drained
1/2 chicken breast, cooked
3 tablespoons Shaoxing or dry Sherry wine
4 thin slices fresh ginger
3 tablespoons corn, peanut or vegetable oil
9 cups chicken broth, canned or homemade
2 tablespoons cornstarch
1/4 cup cold water
Salt to taste, if desired
2 tablespoons light soy sauce
1/4 teaspoon freshly ground pepper, preferably white
1 tablespoon sesame oil
PREPARATION
1. Put the shark's fin in a kettle, and add 8 cups of the water, barely covering. Bring to a boil and cook, turning the pieces often as they cook, about 30 minutes. Drain and chill under cold running water. Drain.
2. Put the shark's fin in a mixing bowl, and add cold water to cover. Let stand 24 hours.
3. Meanwhile, put the mushrooms into a mixing bowl, and add warm water to cover. Let stand 30 minutes or longer. Drain and squeeze dry. Cut the mushrooms into fine shreds and set aside. There should be about 2/3 cup.
4. Thinly slice the bamboo shoots, and stack the slices. Cut the slices into the thinnest possible shreds. There should be about 1/2 cup.
5. Using the fingers, pull the chicken breast meat into the finest possible shreds. There should be about 2/3 cups.
6. Drain the shark's fin, and using the fingers, remove the fine, silky fibers. This will yield about 1 cup.
7. Put the cleaned shark's fin into a kettle, and add 4 cups of water. Bring to a boil and drain.
8. Put the shark's fin into a wok or kettle, and add 4 more cups of water, the wine and ginger. Bring to a boil, and let simmer 1 minute. Drain and discard the ginger.
9. Heat the corn oil in a wok or skillet, and add the bamboo shoots and mushrooms. Cook, stirring, about 10 seconds. Add the chicken broth and shark's fin. Bring to a boil. Skim off the white foam that rises to the surface. Add salt to taste. Add the shredded chicken.
10. Blend the cornstarch and cold water. Stir this into the soup. Add the soy sauce, black pepper and sesame oil and serve.
pakman3 is offline   Reply With Quote
Old 09-09-2011, 12:30 PM   #2
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
thats some good stuff
Devious1 is offline   Reply With Quote
Old 09-09-2011, 02:12 PM   #3
brew
My Ride: F150 X5 MR2
You forgot about saving the skin on the fin to make a pouch for serving the soup.
brew is offline   Reply With Quote
Old 09-09-2011, 02:14 PM   #4
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Pig's ears. Provides the exact same consistency at a lower price point and without destroying our ocean's ecosystems
Timeless Motor Group
Old 09-09-2011, 02:20 PM   #5
217Bimmer
My Ride: Dodge Durango
love shark fin soup. those damn eco libtards making it harder to find though.
** Political signature removed - Tim330i **
I always have to laugh when I see a thread described as "Not Work Safe." Is there anything on the OT forum that's really "work safe"? If I were your boss, I'd be mad if you spent any time on this forum at work at all. How is a picture of a naked girl any less work safe than, say, a picture of a matador getting gored in the *** by an angry bull? - VaderDave
217Bimmer is offline   Reply With Quote
