Old 09-11-2011, 11:04 AM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Shark Edit: It's Alive
Like a lot of you, I REALLY WANT A SHARK EDIT. I just came across this from Jim Conforti himself:
http://forums.bimmerforums.com/forum...&postcount=439
With some luck, Santa will make this a very merry Christmas !
SUMMIT POINT WV 1:24:229 SCCA
Old 09-11-2011, 11:17 AM   #2
bwallace530
My Ride: 325
What's that?? Link does not give much info
Is this the software I was reading about a long time ago where you can edit the shark injector software?? If so this would be awsome
Sent from my PC36100 using Bimmer
bwallace530 is offline   Reply With Quote
Old 09-11-2011, 12:26 PM   #3
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 09-11-2011, 01:45 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
<------- True believer.
Old 09-12-2011, 08:52 AM   #5
Drewfus2101
My Ride: N/A
I thought there was some talk on here a while back, and someone made it sound like they were testing this on their car. I could have read it wrong though.
Drewfus2101 is offline   Reply With Quote
Old 09-12-2011, 04:37 PM   #6
secono330ci
I wonder if Jim needs one more car to test on... I would love to help out.
Old 09-12-2011, 05:06 PM   #7
bwallace530
My Ride: 325
So when will this be able to buy??
Old 09-24-2011, 01:32 PM   #8
xdmikey
My Ride: e46 cabrio
Rob, is this an addition to the shark someone would have installed already or a new edition?
suggestion for the less than highly-skilled among us: stay w/original or wait for this one?
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP
xdmikey is offline   Reply With Quote
Old 09-24-2011, 01:51 PM   #9
Rob43
Rob43's Avatar
A new edition.
Suggestion for the less than highly-skilled among us: stay w/original or wait for this one?
That is the question, isn't it. Only J. Conforti knows when it's really coming out, so I can't give you advice on how to proceed. But, I just can't see J.C. writing that post back around 7/2011 if he didn't mean it.
Old 09-24-2011, 01:53 PM   #10
mvrk10256
My Ride: E30 325i
I am not going to hold my breath.
Old 09-24-2011, 02:24 PM   #11
bwallace530
My Ride: 325
It think its bull how every other car has the availability to mess the ECU expect bmw.
Old 09-24-2011, 06:23 PM   #12
mrshelley
My Ride: 2004 330i
The main reason is that there is a limited number of poeple out there that want to tune with their car. Then most BMW people are only willing to spend $300 - $400 for something to only get 10hp.
As for other cars, most are simpler but then a Porsche is pretty much the same as a BMW. Difference is, the Porsche crowd don't mind spending $2000 - $3000 for something that might only net 10hp.
One other thing that will happen. Since turbo cars can get the most power increase by messing with the ECU, the newer BMW's (i.e. 135 or 335) there is a big market for that. When BMW ditches the NA inline 6 for the Turbo inline 4, there will be a group that will jump on that right away.
Old 11-18-2011, 04:31 PM   #13
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
Jim C had mentioned to me that Shark Edit was still going on and with him running so many of his own businesses aside of Shark Injector stuff/Edit that also has kept him busy. He was revising a few things.
Jims quote
Depends on the options - but I won't really set the price until
it's released. Which should be in a month or so - maybe less.
Right now I'm trying to figure out why a stupid virus scanner
is detecting my programs as a trojan dropper - when they are
stupid function test programs.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 11-18-2011, 05:53 PM   #14
Rob43
Rob43's Avatar
"Jims quote: Depends on the options - but I won't really set the price until
stupid function test programs."
Please, what was the DATE of this conversation ?
Shark Edit =
Old 11-20-2011, 08:24 PM   #15
darksideracer69
My Ride: 01 325ci
I got a reply from oem tuning, and they said that they can tune the eu2 version of the dme. I wonder if this shark edit will be able to also.
IMAG02051
Old 11-20-2011, 08:41 PM   #16
aggieE46
Keep it clean
aggieE46's Avatar
SE should be able to tune almost any Bosch or Siemens system.
Old 11-20-2011, 10:44 PM   #17
Hornung418
My Ride: '04 MB ZHP
Fux yeah!
Currently the Shark Injector doesn't support European DME tunes. I hope the Shark Edit is my dream come true. I want headers desperately, yet I need to pass OBD2 emissions...My MIL is off which is instant fail. But I have until February 2013...NBD.
Hornung418 is offline   Reply With Quote
Old 11-21-2011, 12:32 AM   #18
darksideracer69
My Ride: 01 325ci
Originally Posted by Hornung418 View Post
Fux yeah!
You should of jumped on those 2 sets of equal lenthgs headers that were posted.
Sent from my SGH-T959V using Bimmer
IMAG02051
Old 11-21-2011, 12:34 AM   #19
bwallace530
My Ride: 325
Is it out?
Old 11-21-2011, 08:42 AM   #20
aggieE46
Keep it clean
aggieE46's Avatar
I may be wrong, but I don't think the Edit is going to allow you to go in and change things like that. It's for tuning, not for turning on/off factory options.
Aside from that, wiring up an LC-1 to fix the no cat issue is a heck of a lot cheaper than a full Shark Edit solution is going to be.
Fux yeah!
