Old 11-21-2011, 03:49 PM   #21
Hornung418
My Ride: '04 MB ZHP
The EU2 tune does not check for Catalytic Converters, Secondary Air Pump and disables the MIL. So if I can get the shark with support of the European DME base tune, then I would be in business.
But today, I found that I have a Bank 1 exhaust leak at the head. Guess that means I'm getting headers sooner than expected Should have jumped on those Techniks
Hornung418 is offline   Reply With Quote
Old 11-21-2011, 03:54 PM   #22
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Gotcha!
Old 11-26-2011, 02:13 AM   #23
BROKENBIMMER
My Ride: 328i
All the sharks I am finding have the USB port to allow for update..but there is no update available? Also can anyone tell me where I can find a company to get a shark programmed to my needs everything I find is a " one size fits all " for the 328 where others have different tunes depending on upgradesR
BROKENBIMMER is offline   Reply With Quote
Old 11-26-2011, 04:18 PM   #24
aggieE46
Keep it clean
aggieE46's Avatar
Not available.
Old 11-26-2011, 04:22 PM   #25
dfjaws
My Ride: E90 M3 / E86 M Coupe
Interesting.
dfjaws is offline   Reply With Quote
Old 02-01-2012, 09:26 AM   #26
stevenluczynski
My Ride: Is Steel Blue
Any updates?
stevenluczynski is offline   Reply With Quote
Old 02-01-2012, 12:21 PM   #27
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Nope, none that I know of.
But my fingers are still very crossed, the way I see this is there's no way Jim C. spent all that time developing "Shark Edit", and then would never release it.
SUMMIT POINT WV 1:24:229 SCCA
Old 03-08-2012, 01:56 AM   #28
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Bump for a thread i don't want to see die. If he needs a car to test it on.... I'm local. And AWD.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 08-31-2012, 12:37 AM   #29
serdar255
My Ride: '01 325ci / '90 325i
Bump... in case of any new info
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 08-31-2012, 12:47 PM   #30
aggieE46
Keep it clean
aggieE46's Avatar
It'll release right as I put my car back to stock, no worries.
Old 09-25-2012, 07:59 PM   #31
IrocThe325i
My Ride: is turning japanese
i got a shark injector out of a traded in bmw... i want to do something with it except throw it away.
Shark edit neeeeeds to come out.
IrocThe325i is offline   Reply With Quote
Old 09-29-2012, 07:37 PM   #32
HakenTT
My Ride: 323i with S54
Problem with flash tuning OBD2 ecus, is if slight voltage spike or drop will result in failed flash and that means your DME is "bricked" and no longer can be fixed.
The ms42 and ms43 can only be flashed like 13 times, thats it. So you would not be able to do much tuning
HakenTT is offline   Reply With Quote
Old 09-29-2012, 09:29 PM   #33
smooth1
My Ride: BMW FTW
Not true if you're talking about tuning, which is the tune area of the program only.
smooth1 is offline   Reply With Quote
Old 09-29-2012, 11:20 PM   #34
sunnyjay
My Ride: 01 330i
Disable id update and the 13 limit doesn't apply.
sunnyjay is offline   Reply With Quote
Old 09-29-2012, 11:49 PM   #35
smooth1
My Ride: BMW FTW
That limit doesn't apply to the tune area anyway, but yes, there are ways around the limit when you're updating the entire program.
Old 09-30-2012, 12:21 AM   #36
stevenluczynski
Every time this thread gets bumped I get my hopes up
Old 09-30-2012, 05:04 PM   #37
bimmer53
My Ride: 330I, 540I, 330CI
^Same
bimmer53 is offline   Reply With Quote
