E46 Xi Forum
Old 09-15-2011, 01:21 AM   #81
Fred The Puppy
My Ride: 330XI
Looks like some of you are talking about differentials, and others are talkin' about transfer cases.
Fred The Puppy is offline   Reply With Quote
Old 09-15-2011, 06:40 AM   #82
xixixi
Banned User
My Ride: 01 330x-xi
I have this exact T case in my garage and performed the exact test. Ever had "locked" diff? Or straight axle? Go try this, come back, start your argument over. How about you buy my T case for 100 bucks and you can tear it apart and educate us all on your vast knowledge of wiki links and videos of your new to you "Locked" T case. You also realize making a system with a 100% locked T case wouldn't allow the abs/dsc to do it's thing right?
Our T case as most already know cause everyone has worked/taken them off before. Has zero electrical connections to it.. As the entire Drive train does minus the transmission (reverse light). Remove a fuse.... hmm sounds like an abs fuse to control the dsc. Now look 1 fuse = unlocked T case... roflmao
Old 09-15-2011, 10:12 AM   #83
TiAgXi
My Ride: e46xi, e46m
So, I emailed the chief engineer at Magna, the company that owns New Venture Gear. He seems like a pretty good guy and was willing to answer my questions. I've redacted his information, however, so that he doesn't end up hounded by idiots. No doubt, there are those here that are smarter and more experienced than the Chief Engineer at New Venture, so I'm sure debate will continue. In any event, have a look:
/endthread
TiAgXi is offline   Reply With Quote
Old 09-15-2011, 10:39 AM   #84
Pierce1
My Ride: 03 330xi
Yep, that's how I understand how it works. Nicely done!!!
Pierce1 is offline   Reply With Quote
Old 09-15-2011, 10:57 AM   #85
SamDoe1
My Ride: 4cyl of fury
/endthread
Old 09-15-2011, 11:18 AM   #86
TiAgXi
Old 09-15-2011, 01:24 PM   #87
Tele
My Ride: E46 330XIT MTech II
Informative tread!
My understanding of our 4WD system has always been that you need "some" friction at the tires for it to work.
...Unless you have mechanical locking diffs. and transfer case
Bad ass Buggy!
Tele is offline   Reply With Quote
Old 09-15-2011, 01:55 PM   #88
Thotfulspot
My Ride: 2003 330Xi
I would assume that Buggy has a Atlas transfer case, mine does. It is gear driven. You get the option of 2WD rear, 2WD rear, 4WD, 2WD front. All of those iterations in low or high range. The only time it would be open is if you put the case in neutral. Besides the clutch based transfer case used in some cars and high end SUVs, that's how truck/jeep etc, that's how transfer cases work. The Atlas allows the front 2WD which most cases don't. Trucks/jeeps etc. Usually just have 2WD rear and 4WD high and low. That's all there is. They are all chain or gear driven. The power is 50/50. There is no option to change the transfer case to open or closed.
Differentials are another story. They come open and you could put a limited slip in which would have the effect of wheels on ice and not being able to move. The other options are ARB (air used to lock it) or Detroit Lockers. Both of these lock the differentials but will allow a axle to go open in a tight turn. The only way to be completely locked is to weld the spider gears.
Thotfulspot is offline   Reply With Quote
Old 09-15-2011, 02:26 PM   #89
jasonbimmer
My Ride: 2001 BMW 330xi
as we were saying, the tcase is a diff type tcase not a chain locking type, otherwise it would not be full time. a full time means the t case always connect front and back diffs allowing different rotation between the front and back drive shafts. I had a wrangler it was a locking part time. you cant turn and should not turn in 4wd mode on dry pavement or you break the tcase (because front and back drive shafts are locked 1:1).
ok since we talking about diff type tcase here, the 38/62 split is done by gears (imagine an open diff with two different size axle gears).
an asymmetrical diff allows torque to be split unevenly. (symmetrical means even split, like our front and rear diff).
however if one drive shaft stops, because of the open diff design, all the power would still go to the other drive shaft.
Old 09-15-2011, 02:41 PM   #90
Tele
I know.
Just trying to make a point by posting the baddest 4WD I could find
But thanks for the Atlas explanation! I’m fascinated by these Buggy’s
Old 09-15-2011, 02:45 PM   #91
TiAgXi
Originally Posted by chuckb View Post
This is largely pointless, i've been going around in circles for a while now. Citing indep resources until i am blue in the face. But since you are resorting to giving people false information to be stubborn and obnoxious, i'll try to put this in a context a child could understand.
Whether you want to call it: open, closed, Dan, or Rita, the values of the transfer case NEVER CHANGE. The BMW literature says this multiple times.
By definition an open diff is variable. It's outputs change. That's what makes it "open".
http://en.wikipedia.org/wiki/Locking_differential:
When the differential is unlocked (open differential), it allows each wheel to rotate at different speeds (such as when negotiating a turn), thus avoiding tire scuffing. An open (or unlocked) differential always provides the same torque (rotational force) to each of the two wheels, on that axle. So although the wheels can rotate at different speeds, they apply the same rotational force, even if one is entirely stationary, and the other spinning. (Equal torque, unequal rotational speed).
By contrast, a locked differential forces both left and right wheels on the same axle to rotate at the same speed under nearly all circumstances, without regard to tractional differences seen at either wheel. Therefore, each wheel can apply as much rotational force as the traction under it will allow, and the torques on each side-shaft will be unequal. (Unequal torque, equal rotational speeds).
What we know:
We know that the t case outpower power is fixed and does not change.
We know that the t case does not provide the same, fixed, torque to both outputs.
We know that the t case output speed is the same to both outputs under all circumstances.
.... You want even simpler??? OK.
"When the differential is unlocked (open differential), it allows each wheel to rotate at different speeds"
BMW: "It uses two open differentials and a single speed transfer case."
One of these things is not like the others, One of these things just doesn't belong, Can you tell which thing is not like the others. By the time I finish my song?
Old 09-15-2011, 03:22 PM   #92
Thotfulspot
My Ride: 2003 330Xi
It's like beating a dead horse, but from looking at transfer case it is a gear driven case. It works like the Atlas case I described above. The gears can only be engaged, not disengaged or anything in-between without stripping the gears. If it was a fluid/clutch differential it would allow the case to run at different ratios. Where the different speeds come into play is in the differentials. They can run at 4 different speeds if it was on a slippery surface. A stock jeep has the same issue. The brakes being controlled will try to apply some friction to give power to an axle that is slipping. Because of the higher ratio in the rear, it would be easy to get stuck if both rear axles were on ice. there would be situations in snow where the rear would be spinning freely and there was enough resistance against the front like snow.
That's the advantage of the Atlas case and being able to direct 100% of the power to the front axles if needed.
Old 09-16-2011, 04:12 PM   #93
xixixi
Banned User
My Ride: 01 330x-xi
so wait... the transfer case is open or locked? I think he was just trolling us!
Old 09-16-2011, 04:42 PM   #94
Thotfulspot
My Ride: 2003 330Xi
There is no open or closed in the type of transfer case unless it uses clutches/fluid. The term open or closed applies to differentials. In a differential axles can move at different speeds when traction is lost. The transfer case has a set ratio front to rear and unless you strip the gears, can't turn at any other percentage then set when built.
Old 09-16-2011, 04:48 PM   #95
Thotfulspot
My Ride: 2003 330Xi
Whomever has the contact at New Venture should ask if the transfer case can change it's ratio. If it can't it would be considered closed. When discussing most 4WD vehicles there is no discussion of open or closed transfer cases. They are closed and you discuss open or closed differentials.
Old 09-16-2011, 05:17 PM   #96
TiAgXi
I've got the contact info. But sorry, I'm not going to bother him. His answer was crystal clear: "The NV124 [transfer case] was an open differential."
You've got yourself stuck in the thinking that because we call it a "transfer case" it's not a "differential." our transfer case IS a differential.
Old 09-16-2011, 05:18 PM   #97
TiAgXi
smartass
Old 09-16-2011, 05:31 PM   #98
Pierce1
My Ride: 03 330xi
Yep. Open differential front to rear instead of left to right. It's that simple.
Old 09-16-2011, 06:19 PM   #99
jasonbimmer
its not ordinary open diff. its a unbalanced diff (two axles have different size gears, unlike front and back diffs that have same size gears).
bigger gear means easier to turn than small gear, in our case the rear axle has bigger gear so more torque goes to the rear than the front.
Old 09-16-2011, 06:42 PM   #100
Pierce1
My Ride: 03 330xi
I'm ofcourse generalizing here.
