Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 09-13-2011, 06:28 PM   #1
Mulatto325
My Ride: 325ci convertible
FS: Crunch 4 channel Amplifier GPV 1000.4 $75 shipped.
Image Hosted by ImageShack.us
Specs
•Ground Pounder Series 4-Channel Amplifier
•RMS Power Rating:
***9702;4 ohms: 62.5 watts x 4 chan.
***9702;2 ohms: 125 watts x 4 chan.
***9702;Bridged, 4 ohms: 250 watts x 2 chan.
•Dynamic (Peak) Power Rating:
***9702;4 ohms: 125 watts x 4 chan.
***9702;2 ohms: 250 watts x 4 chan.
***9702;Bridged, 4 ohms: 500 watts x 2 chan.
•Max power output: 1000 watts
•MOSFET PWM power supply
•No remote bass level input
•LED power/protect indicators
•Bass boost (0-9 dB at 45 Hz)
•Soft start sound
•Damping Factor: 180
•Channel Separation: 80dB
•Variable Input Level Control: 0.2V-5.0V
•Protection (DC, short, thermal, overload)
•Full range line output
•Unbalanced input (RCA Jack)
•High level inputs
•Illuminated Crunch badge
•Variable high-pass/subsonic filter (60-1,200 Hz)
•Variable low-pass filter (30-250 Hz, mono 24 dB/octave)
•Frequency response: 30-1,200 Hz, 3dB
•Dimensions: 11-1/8L x 9-3/4W x 2H
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 09-14-2011, 03:15 PM   #2
Mulatto325
Bump
Old 09-15-2011, 11:33 AM   #3
Mulatto325
Bump
Old 09-16-2011, 10:54 AM   #4
Mulatto325
Bump
Old 09-16-2011, 08:49 PM   #5
Mulatto325
Bump
Old 09-18-2011, 05:38 PM   #6
infamous_e46
My Ride: Tu Mama
im out of the e46 scene i have a left over new in box oem mahle fuel filter and some new fuel line and clamps
would u trade and i add lets say 10 bucks
http://forum.e46fanatics.com/showthread.php?t=866336
infamous_e46 is offline   Reply With Quote
Old 09-19-2011, 10:17 AM   #7
Mulatto325
Bump
Old 09-20-2011, 11:26 AM   #8
Mulatto325
Bump
Old 09-21-2011, 11:33 AM   #9
Mulatto325
Bump
Old 09-22-2011, 07:05 PM   #10
Mulatto325
Just a side note. I replaced this amp with a more powerful Alpine. The Alpine is great definitely cleaner. But today I had to drive a total of 4 hours with the volume at 27 out of 40 and the last hour of my ride the alpine went into thermal overload protection. That never happened with this crunch amplifier. Just saying.
Old 09-23-2011, 11:09 AM   #11
Mulatto325
Bump
Old 09-24-2011, 09:02 AM   #12
Mulatto325
Bump
Old 09-24-2011, 09:30 AM   #13
aeorozco
My Ride: 2000 323i
Send a message via Yahoo to aeorozco
If your new amp is going into "limp" mode then you have it set wrong, you shouldnt need to turn up the gain on your amp more then halfway, and you may need to adjust the equilizer on your headunit to keep it out of thermal overload, also newer amps tend to do this during the break in period, I have always had my new amps heat up and turn off until I get them adjusted right where I want them and broken in.
2000 323i ........Stock for now
aeorozco is offline   Reply With Quote
Old 09-24-2011, 11:16 AM   #14
Mulatto325
I bought the amp used. Good point about the gain. I was adjusting it after I first installed it and I never turned them back down. Now I just set both gains to the nom setting. It will be awhile before i am able to go for a long ride and see if it dose it again. I don't know how much that will make a diffrence. I know it gets hot where I mounted them (above the spare,below the carpet). Back in the late 90's I had 2 Alpine MRV 1005's profesionaly installed and in the summer after about an hour or so with the volume at about 75% they they would go into TO protection. Its just really hot down here.
Pics of my old setup in my jeep. (Very old) My loudest system.
Old 09-24-2011, 11:40 AM   #15
aeorozco
My Ride: 2000 323i
Ouch man....yeah you need to get air moving on that amp, a little trick we used to use in my car show was to mount a small like 5 in personal fan in the trunk bc I done like to look st it on to my box. You might have to wire in a dc/ac converter a c/dc
Sent from my SCH-I510 using Bimmer
Old 09-24-2011, 04:38 PM   #16
Mulatto325
If the gain doesn't fix the problem I was thinking of adding a small 12v amp fan on the driver side of the trunk and 1inch by 5inch slot on the passenger side. But summers almost over and I never have a problem once it gets cooler out.
My current set up
Old 09-29-2011, 11:40 AM   #17
Mulatto325
Bump
Old 10-01-2011, 09:50 AM   #18
Mulatto325
Bump
Old 10-05-2011, 11:05 AM   #19
Mulatto325
Bump
Old 10-25-2011, 10:47 AM   #20
Mulatto325
Bump
