E46 Xi Forum
Old 09-15-2011, 06:50 AM   #1
farhan082
My Ride: 318 i 2005
Unhappy a hard push while gear changes
hi,
i m new here. i have purchased my first BMW last month but unfortunately it is in the workshop from the first day. mechinic told me it has a problem of AIR MASS..i changed it then he asked me to change VEUS of timing belt i changed it as well
but still the gear is shifting with a hard push.. there is no error or fault in computer .can anyone tell wat problem it can b? as i m really stuck and dont know wat to do,,any help will b appreciated
farhan082 is offline   Reply With Quote
Old 09-15-2011, 11:35 AM   #2
Gus330vrum
My Ride: 330ci
Originally Posted by farhan082 View Post
hi,
Low on Transmission Gear oil?
Only happens when its Cold start? said to be normal on e46/US ....
maybe ball shifter?>
Gus330vrum is offline   Reply With Quote
Old 09-15-2011, 11:39 AM   #3
TiAgXi
My Ride: e46xi, e46m
I'd start by replacing the transmission fluid with Redline or another quality D4.
TiAgXi is offline   Reply With Quote
Old 09-15-2011, 12:09 PM   #4
farhan082
My Ride: 318 i 2005
everything is fine oil etc...there is no error on computer check as well
i have searched internet and some suggested to upgrade or degrade the transmission software
this hard push is only in first nd second gear after that car runs very smooth
Old 09-15-2011, 12:12 PM   #5
TiAgXi
Wait, is this an automatic transmission? I sorta assumed cars in Saudi Arabia were mostly manuals, sorry.
Old 09-15-2011, 01:15 PM   #6
eeleaj
My Ride: Boost 325xi
maybe you should change your mechanic
eeleaj is offline   Reply With Quote
Old 09-15-2011, 01:17 PM   #7
eeleaj
how many miles does your car have
Old 09-15-2011, 02:22 PM   #8
farhan082
My Ride: 318 i 2005
154000 yeah may b i have to but to my surprise i am recomended by so many frnds to that mechinic... he said he come to know wat is the problem...i will see it on saturday if not then will take it to dealr..
thanks for replies
Old 09-16-2011, 02:57 PM   #9
eeleaj
let us know what the problem was if your mechanic fixes the problem
Old 09-19-2011, 05:41 PM   #10
markusvt
My Ride: 330xi
My best guess, clutch master/slave issue, and you are not getting full travel. There is NO connection with your codes and the shifts, different faults, with different sources.
markusvt is offline   Reply With Quote
Old 09-21-2011, 03:29 PM   #11
farhan082
My Ride: 318 i 2005
these are the two eror codes...i really need help on that..car manafucturing date is March-2004
http://imageshack.us/photo/my-images...921210413.jpg/
http://imageshack.us/photo/my-images...921210302.jpg/
Old 09-22-2011, 01:27 AM   #12
eeleaj
im not sure so heres a free bump to the top maybe someone else can help
Old 09-22-2011, 03:13 AM   #13
choleaoum
Ceiling missing!
choleaoum's Avatar
My Ride: BMW 330Ci
Send a message via AIM to choleaoum
my money is that it's the differential bushing. it's a thud right? everytime you shift or kinda let go of the clutch it kinda jerks around. feels like its bouncing.
at 154k the diff bushings definitely must be out.
choleaoum is offline   Reply With Quote
Old 09-23-2011, 08:38 PM   #14
farhan082
My Ride: 318 i 2005
same problem he has checked all the air leaks...and finally told me to take the pic of some fault codes to show u if u can help
this pic is taken on 3 RPM
velvotronic is running in safe mode....
waiting for some help...
Old 09-23-2011, 11:45 PM   #15
Gus330vrum
My Ride: 330ci
is that a laptop diagnosis! tool... where did u purchase? i want one! =D
Old 09-24-2011, 06:53 AM   #16
farhan082
My Ride: 318 i 2005
yeah it is laptop based....and owned by my mechinic :p who is at the moment unable to fix my car which is with him from the lalst 1 month
Old 09-24-2011, 07:49 AM   #17
aeorozco
My Ride: 2000 323i
Send a message via Yahoo to aeorozco
Maybe you need to replace your Vanos, since that is a regular symptom of when they start to go bad, jerky bouncy take offs...good luck, free bump ttt
2000 323i ........Stock for now
aeorozco is offline   Reply With Quote
Old 09-24-2011, 08:05 AM   #18
farhan082
My Ride: 318 i 2005
i have already replaced it...last week..but problem is still there
Old 09-25-2011, 06:16 AM   #19
farhan082
My Ride: 318 i 2005
hi
any luck??
Old 09-27-2011, 12:19 AM   #20
eeleaj
maybe intake cam sensor???
