Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 09-15-2011, 09:36 PM   #1
Guest021715
Account closed.
Cheap Alarm Solution! (Installation + Pics & Video)
A few days ago I stumbled upon the $5 lock beep thread here, and thought I would try something similar to substitute my vehicle not coming with a factory alarm. The installation is very easy and requires only 2 main components:
1) An alarm siren - I pulled mine off a vehicle at the junkyard for $10.
2) A method to program your vehicle to flash corners when locking/unlocking.
To prep, I extended the wires of my alarm siren with blue 24 gauge wire and used excess amounts of electrical tape to secure the connection
Next, I removed the cabin air filter, its cover, and its housing. There are 3 twist clips for the air filter and 4 T-30 Torx screws holding the housing in place. At this point you will also have to detach the bottom part of the wire casing to free the housing (pictured at the bottom).
After the housing has been taken out, you will encounter another HVAC air box panel, which is held in place by 2 T-30 Torx screws, one at each side. There may also be a twist clip present near the DME which needs to be removed.
Once you have removed the air box panel, start looking for the factory alarm harness. It will be located behind the drug bin, and most likely taped to a wire that leads behind the firewall. Hard to miss, once you find it, this is what it looks like:
The siren installation is next. I routed the blue positive/negative wires through a hole with a rubber plug located near the top of the drug bin. Simply remove the plug if you have one, if not, you can drill a hole (not recommended), or simply route the wire over the top and behind the rubber weather stripping.
Your positive wire should be connected to the top left hole, and negative in the bottom left hole as shown in the picture below (borrowed from tranceasia8)
After the connection is secure (I used an excessive amount of electrical tape, once again) tie back any loose wire to the original strand.
To keep the siren in place I positioned it on top of notch with a threaded hole, and found a bolt that fit the thread. My car has 3 of these notches in the drug bin.
The finished product
Now a video demonstration of my new cheap alarm. Hope this helps some of those who didn't want to spend hundreds of dollars on the OEM alarm!
Old 09-15-2011, 09:45 PM   #2
cak323i
My Ride: ///M3 & 330i ZHP
interesting and loud
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 09-15-2011, 10:20 PM   #3
maze416
My Ride: 2004 325ci
nice work
maze416 is offline   Reply With Quote
Old 09-15-2011, 10:27 PM   #4
ED955S
My Ride: 2003 BMW 330i
Excellent and thanks for sharing! I am going to give this a try once I can find a siren.
How did you activate the lights to flash?
2003 BMW 330i E46
2004 Mini Cooper S R53
2016 Porsche Cayman 981
ED955S is offline   Reply With Quote
Old 09-15-2011, 11:11 PM   #5
bartola
My Ride: 323ci / ESV Lade
Cool write up.
bartola is offline   Reply With Quote
Old 09-15-2011, 11:31 PM   #6
Mr_325
My Ride: 2007 X5 3.0Si
nice work!
i wanna try out the Viper SmartStart with iPhone
Mr_325 is offline   Reply With Quote
Old 09-15-2011, 11:44 PM   #7
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Great!
Bimmer4Lyfe is offline   Reply With Quote
Old 09-16-2011, 12:26 AM   #8
raptordavedave
My Ride: 02 BMW 330Ci
after you have done this does the car need to be programmed?
raptordavedave is offline   Reply With Quote
Old 09-16-2011, 01:18 AM   #9
Guest021715
Account closed.
Yes, the car needs to be reprogrammed. There are very cost effective solutions that I can go in more detail only via PM.
I've added flashing high-beams and 4-ways with the alarm, which were not part of the video. There are many customizable options.
Old 09-16-2011, 01:41 AM   #10
Redline
Redline's Avatar
My Ride: ///M3 Vert
the factory alarm system is fairly cheap installed and working...why not just go for that? it does a great job as well.
k.
///M
Old 09-16-2011, 01:48 AM   #11
Guest021715
Account closed.
Because this works just fine and costs a hell of a lot less
Old 09-16-2011, 02:36 AM   #12
Beans562
My Ride: 330i
Send a message via AIM to Beans562
another great thread by ac_2007
Beans562 is offline   Reply With Quote
Old 09-16-2011, 04:14 AM   #13
Apple4life
Apple4life's Avatar
My Ride: 03 325i SULEV
Nice and loud
Was the siren from a salvaged e46? Do you know how loud the siren is in terms of decibels?
Apple4life is offline   Reply With Quote
Old 09-16-2011, 05:25 AM   #14
eneka
My Ride: 2003 325i
Originally Posted by Apple4life View Post
Nice and loud
it's probably from another car, the oem e46 alarm looks a lot different
eneka is offline   Reply With Quote
Old 09-16-2011, 07:04 AM   #15
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Good job OP.
rizwan1377 is offline   Reply With Quote
Old 09-16-2011, 08:31 AM   #16
jgold47
My Ride: 2004 X5 3.0
I have an extra siren lying around as well and have wanted to do this, but didnt want it to look non-stock. I was going to power the siren with a relay to make it even louder, but it seems like the stock wire output is good enough....
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 09-16-2011, 10:17 AM   #17
Guest021715
Account closed.
Nice and loud
eneka is right, the siren I used was pulled from a random car with an alarm system. I just based my decision on the fact that it was in good condition and single tone.
UPDATE: For those wondering what the setup options are (in the legitimate version of) PA Soft 1.4, I have taken a screenshot of my revised options which include the flashing high-beams and 4-ways not seen in above video:
Old 09-16-2011, 10:19 AM   #18
Zell
Zell's Avatar
My Ride: so turbo wow
Want people to really notice someone breaking into your car? Set the siren to a cheap late-night cable porno scene.
You'll get everyone's attention, and the thief will probably run the **** away the second that starts coming out of your car.
Old 09-16-2011, 10:26 AM   #19
Guest021715
Account closed.
Funny story, yesterday when I was playing around with the alarm getting to know the functions, I set it off to see how long it would stay on.
About 10 seconds in, my headlight washers started spraying continuously and the wipers went off. Emptied about half my washer reservoir.
I've been trying to recreate this and get it on video.
Old 09-16-2011, 06:02 PM   #20
PrisonMike
My Ride: 323cic
nice! this saves me a bunch of money
PrisonMike is offline   Reply With Quote
