Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 09-18-2011, 09:32 PM   #41
Kevin03
My Ride: 2003 325i
Where can I score the software? Do I need to get this from a dealer? Freeware?
My 2 cents..i have a high end aftermarket alarm that I would like to install when I get then time, but this would be great for the mean time. In my last set up I installed the siren inside the car for two reasons. A thief will get in the car to steal radio or what ever they are after. So it is really loud inside in hopes that it will be too annoying and thief will leave. False alarms in middle of night will not annoy neighbors as it is quite outside of car. Also I have never seen anyone come running to chase away a car thief breaking in to someone else's car.
Thanks for write up and in advance for answer on software.
Kevin03 is offline   Reply With Quote
Old 09-18-2011, 10:09 PM   #42
Guest021715
Account closed.
If you'd like more info on the software, PM me. Without the tilt & interior motion sensor, there is little room for false alarms. This would only activate if the doors, hood, or trunk were opened.
Old 09-18-2011, 10:15 PM   #43
eneka
My Ride: 2003 325i
you could also easily wire a cheap shock sensor to the hood switch
eneka is offline   Reply With Quote
Old 09-24-2011, 12:47 PM   #44
Toofpik
My Ride: 2002 325ci
Awesome
Toofpik is offline   Reply With Quote
Old 09-24-2011, 05:57 PM   #45
Blocked Out
My Ride: Imola 330i M-Sport
Thank you for a great write up.
Original BMW Teile ///
IMG_1725
Old 09-28-2011, 05:12 PM   #46
zhenkaaaM3
My Ride: Fst'r then your e46
Pretty cool DIY.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 09-28-2011, 05:45 PM   #47
zhenkaaaM3
The point of you changing up your alarm was to make it more louder/annoying?
or do you believe the unlock/lock is a better sounding alarm? sounds very loud in your garage.
Eugene
Old 09-28-2011, 06:32 PM   #48
Guest021715
Account closed.
It wasn't changed, I added it. Outdoors it sounds like every other alarm, maybe a bit quieter.
Old 10-03-2011, 12:32 PM   #49
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
I will do this DIY today. I have already activated the alarm, Thanks OP!!!.
and I finally found the siren i was looking for, I took it out from an 04 sienna.
rizwan1377 is offline   Reply With Quote
Old 10-10-2011, 09:52 PM   #50
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
so for $70: http://www.resettools.com/bmw_scanner_1.4.0
i can modify most of the settings on my car, and read all of the errors and codes?
this one is only $30
http://www.xcar360.com/bmw-scanner-1...scan-tool.html
scott0482 is offline   Reply With Quote
Old 10-10-2011, 10:14 PM   #51
eneka
My Ride: 2003 325i
http://www.bmw-scanner.com/?page=bmw...files_download
are the cheaper ones bootleg? since the bmw-scanner site says it is $600
the $30 OBD cable i got from ebay worked fine, the software/ computer settings just takes some time to install (vmware+DIS, etc. etc)
http://www.ebay.com/itm/BMW-USB-OBD-...item415d7ba043
Old 11-01-2011, 09:37 PM   #52
MRHEAT
My Ride: 04-325i
Just hooked it as per your instructions worked perfect but what is that plug for---the factory siren ?
MRHEAT is offline   Reply With Quote
Old 11-10-2011, 10:09 PM   #53
Guest021715
Account closed.
Correct
Old 11-12-2011, 03:15 PM   #54
azblkonblk
My Ride: 330
ac, epic thread. Bookmarked and saved.
azblkonblk is offline   Reply With Quote
Old 11-12-2011, 03:39 PM   #55
djnekkon
My Ride: MB3ci & z33 HR
cool DIY..
Old 11-12-2011, 04:07 PM   #56
Ivan328
My Ride: 2000 328i
Very good DIY !
Ivan328 is offline   Reply With Quote
Old 11-15-2011, 12:49 PM   #57
jeepo23
My Ride: 2008 X3, 6 Speed
In this picture, you have nothing in there. In my 02 330XI it has some sort of small lines going into the side. Any idea what those are? And why I got them and you dont?
jeepo23 is offline   Reply With Quote
Old 11-15-2011, 06:45 PM   #58
Guest021715
Account closed.
cool DIY..
Originally Posted by Ivan328 View Post
Very good DIY !
Thanks guys
If I'm not mistaken those are A/C or ABS lines. You have AWD, which requires a front differential, different axles, etc, so your setup is not the same.
The concept is the same however, just find a secure place to mount the siren elsewhere. You may need lengthier wire.
Old 12-13-2011, 11:57 AM   #59
daki_bmw
My Ride: 330Ci
Originally Posted by ac_2007 View Post
I have Euro e46 without OEM alarm. Is there any chance that Euro e46s without this option weren't even prewired for alarm?
I've done everything by this thread (and others) up to the point where you find the actual connector, but for the life of me I couldn't find it. I've been looking with a flashlight for a good hour, but besides some wires that go through mentioned area, I couldn't find anything. Is there any, even remote chance that I could have missed that connector?
As I've said, my car doesn't have an alarm, but it also doesn't have, for example, that plastic thing in the headliner where you enclose motion sensor. That leads me to beleive that European e46s (without alarm option) weren't even prewired for an alarm (I couldn't imagine wiring going through the headliner, without any opening that a connector or two can "exit" it.) Or am I just finding an excuse for not being able to find siren connector under the hood?
Oh, by the way, I don't even have a hood switch nor clown nose on a rearview mirror.
daki_bmw is offline   Reply With Quote
Old 12-13-2011, 12:06 PM   #60
redneckrice94
My Ride: 2000 323i
Ill do this in the spring when I have my car back!
"If you cant stand behind our Troops, feel free to stand in front of them."
redneckrice94 is offline   Reply With Quote
