Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 07-29-2012, 03:56 PM   #101
fbn2000
My Ride: 330i
Problem solved it was the fuse
fbn2000 is offline   Reply With Quote
Old 09-26-2012, 03:45 PM   #102
JasonSmithed
My Ride: 00 323i
Originally Posted by ac_2007 View Post
Funny story, yesterday when I was playing around with the alarm getting to know the functions, I set it off to see how long it would stay on.
About 10 seconds in, my headlight washers started spraying continuously and the wipers went off. Emptied about half my washer reservoir.
I've been trying to recreate this and get it on video.
this happened to me and hasnt stopped. now my car wont unlock via key fob either. the codes say central locking short circuit. this only happened after i followed this thread and did as you did step by step.
JasonSmithed is offline   Reply With Quote
Old 09-26-2012, 04:01 PM   #103
fbn2000
My Ride: 330i
check the fuse that is what happened to mine and once the fuse was fixed the car started working again from the key fob
Old 09-26-2012, 04:42 PM   #104
JasonSmithed
My Ride: 00 323i
Which fuses? Wiper, central locking, and anti theft? Just a fuse fixed it. If the fuse were bad wouldn't it stop working completely??? Will try this. Thanks
Old 09-26-2012, 05:23 PM   #105
JasonSmithed
My Ride: 00 323i
Checked fuses everything seems fine but the problem persists..
Old 09-26-2012, 05:30 PM   #106
JasonSmithed
My Ride: 00 323i
Don't do this mod it's too ghetto and if you're like me you'll follow everything step for step and mess your central locking system up. Get OEM..
Old 11-10-2012, 12:29 PM   #107
limpiabota809
My Ride: 330 XI
^ deactivate central locking, check fuses again and check if it works
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 11-11-2012, 04:57 PM   #108
alkemyst
My Ride: 06 TiAg M3 ZCP 6M
I have the factory alarm, I wish it was louder the few times it's gone off...fortunately no issues during that.
Anyone have an easy way to add a major siren in the drug bin with the factory alarm? I'd also like to place a couple pain generators inside the cabin, but that is a minor need.
alkemyst is offline   Reply With Quote
Old 11-11-2012, 05:07 PM   #109
Stinger9
My Ride: '04 330Ci
Shouldn't be hard to invent what you request. Get an alarm that is loudest you can find, keeping in mind the current requirements don't exceed the OE.
Then tap into the two siren wires and bring them over to the drug bin.
In this world with pain generators, probably get sued for hearing loss damage and lose the case. Pay for robber's kid's college fund!
Old 11-11-2012, 08:03 PM   #110
Guest021715
Account closed.
I haven't had been able to recreate the issue ever since I posted about it last year.
Its worth mentioning that I also redid the wiring by properly soldering all connections, and shrink wrapping them. That's probably the only "ghetto" part of this mod I could think of.
Check your connections and wrap your wires.
Old 11-12-2012, 12:47 PM   #111
jgold47
My Ride: 2004 X5 3.0
I actually did this. Used a clifford 516 I think. I actually took the step of wiring in a relay activated off the factory alarm wires. That way I had two sirens. Never really had the alarm go off, but it was good for the lock/unlock as I could never hear the damn stock one. Terrible location for the alarm behind the firewall. my 36 and my 53 both have it way out in the open and are much louder.
I also coded the alarm with NCS to use the intervallton setting so it had a more distinct sound.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 11-14-2012, 12:58 AM   #112
wes_rod
My Ride: '01 BMW 325ci
nice diy!! thanks for the knowledge
wes_rod is offline   Reply With Quote
Old 01-14-2013, 01:32 PM   #113
canelane
My Ride: 04 330ci
You may need lengthier wire.
Lengthier
canelane is offline   Reply With Quote
Old 01-14-2013, 01:45 PM   #114
Stinger9
My Ride: '04 330Ci
Loudness comment duly noted.
However, I like the factory location of the alarm. Keeps it out of the way cluttering the engine compartment, but more importantly keeps it in a hard to get to place where thieves might pop the hood and quickly rip out the alarm. (that is the way they work) They won't quickly get to the alarm behind all those layers.
Old 03-26-2013, 08:36 PM   #115
Barbaros
My Ride: 02 TIAG M5
This is really good. I will do this as well. I have a question though... Didn't you need to power it? Is it that factory harness that gives it the power?
Barbaros is offline   Reply With Quote
Old 03-27-2013, 12:27 AM   #116
Guest021715
Account closed.
Yep, factory harness powers it.
Old 03-27-2013, 01:17 AM   #117
jonesenberg
My Ride: '04 330i ZHP 6spd
Nice thread, and well done.
FWIW, it would appear that your cabin air filter is installed upside down? The tabs on the side are supposed to face down, AFAIK.
jonesenberg is offline   Reply With Quote
Old 03-27-2013, 02:03 AM   #118
JasonSmithed
My Ride: 00 323i
Why is this thread still in general. Btw I would not recommend the ghetto mod. I tried using another alarm from another car and the voltages were different and may have needed a resistor.. idk anyway it shorted out my central locking relay and now I have to manually unlock my doors until I send it to the gm5 guy.
Sent from my SCH-I510 using Bimmer App
Old 03-27-2013, 11:31 AM   #119
Guest021715
Account closed.
No, the amperage draw was different, your siren was DOA, or you screwed up your wiring.
This is as "ghetto" as anyone installing a siren or piezo, except it actually serves a purpose and is functional.
I didnít think that this needed a disclaimer, but here it is: use common sense.
If the siren you want to retrofit has a relay, or if it has a fuse rated higher than the OE fuse, or youíre holding a horn in your hands and didnít know any better, stop what youíre doing.
This thread and idea itself is old. Iíve since retrofitted the OEM alarm since the scrapyard wanted $40 for the parts.
Old 03-27-2013, 03:21 PM   #120
NumbaOneNewb
My Ride: 2003 330CI Silver
also, you can always add in aftermarket sensors of all types for cheap. you just need to be able to type into the closes wire that allows you to send the panic signal.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
