HELP!!! Car shuts off when i give it gas.... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-17-2011, 08:17 PM   #1
volcom_da6
My Ride: 03 325i
Exclamation HELP!!! Car shuts off when i give it gas....
so recently my 03 325i has been acting up on me.the car turns on and stays on untill i put it in reverse or drive and give it gas it shuts off. I ran it low on gas one day and the next day it felt weird. It felt like it was miss-firing and sputtering. I thought it might the spark plugs since i hadn't changed them in over 8 months. so i changed the plugs out and its still the same. Also i just recently replaced the fuel filter about 4 months ago so i thinking it might just be clogged up? the car fight now has 96k miles on it. has anybody ever had this problem? im also thinking its my fuel pump.... please peps help me out i need to get my car running asap thanks for you help!
volcom_da6 is offline   Reply With Quote
Old 09-18-2011, 08:06 AM   #2
volcom_da6
My Ride: 03 325i
Anybody ever had this problem?
Old 09-18-2011, 08:27 AM   #3
Cengawer
My Ride: 325ci Convertible
I would say it's the fuel pump since you said you were running low on gas one day. When you have low gas, all the dirt n gunk in your tank sinks to the bottom and when you add gas on top of that to fill it up, all that gunk mixes therefore going into ur engine through the fuel pump. That would be my best guess.
Cengawer is offline   Reply With Quote
Old 09-18-2011, 06:44 PM   #4
volcom_da6
My Ride: 03 325i
ok any idea where i could find one for a good price? will i have to drop the tank to get to it?
Old 09-19-2011, 07:16 PM   #5
Cengawer
No they go around 30-50 bucks online. You don't need to drop the tank. It's a simple DIY. I've seen posts on how to do it
Old 09-19-2011, 07:17 PM   #6
Cengawer
Just search ull find it
Old 09-20-2011, 09:15 PM   #7
volcom_da6
My Ride: 03 325i
Cool thanks bro!
Old 09-22-2011, 05:01 PM   #8
volcom_da6
My Ride: 03 325i
just replaced the fuel pump and its still giving me the same problem. the car still shakes and and shuts off asfter a few minutes. what could it be now? i wanna replace the fuel filter again but who knows if that would be the problem....
Old 10-23-2011, 05:47 PM   #9
HyphyMovementZ
My Ride: ZSP, DC5, EM2
I had the same for me it was the camshaft position sensor
HyphyMovementZ is offline   Reply With Quote
Old 11-21-2011, 12:43 PM   #10
330i lover
My Ride: e46 330i
Did this fix the issue? My car is having similar sputtering issues.
330i lover is offline   Reply With Quote
Old 11-21-2011, 12:48 PM   #11
Custom3
My Ride: HellRot 330CI
any codes?
Old 11-23-2011, 11:46 PM   #12
BMWUSMC3051
My Ride: 2000 BMW 323i
Check intake and exhaust hoses if they have a hole the engine will choke its self out exhaust hose is near washer resivor Intake obvious cost 2$ for a new hose hope this is the problem n this solves it for u did for me
BMWUSMC3051 is offline   Reply With Quote
Old 11-27-2011, 08:27 PM   #13
330i lover
My Ride: e46 330i
Resolution?
Old 12-04-2011, 08:36 PM   #14
Rhudeboye
My Ride: 968 330i
Yes, please check in on the status.
Rhudeboye is offline   Reply With Quote
Old 12-13-2011, 01:05 AM   #15
howie1971
My Ride: BMW E46 325Ci
I had this problem I replaced fuel pump yesterday and it seems to have fixed the problem (I ran out of fuel twice, it seems they are pretty sensitive) however I still have a vacuum leak, I have taken off the intake hoses and can not see anything perhaps I will try the exhaust hose.
howie1971 is offline   Reply With Quote
Old 12-19-2011, 05:45 AM   #16
330i lover
My Ride: e46 330i
Yeah, I'm still having the issues. If my warranty doesnt cover it then i'll buy a pump from pelican parts. Did you have to replace anything else other than the fuel pump assembly? Fuel pump seal or a relay?
Old 07-01-2014, 01:59 PM   #17
FERNY_M3
My Ride: 325i
I have the same problem, now it got worse and even in D when i gently very gently press on the gas pedql and hold it the egine starts to gargol or choke idk but its sounds like its dieing and somtimes it turns off completely. Back then it was just when i was going in reverse now it happens somtimes when its in D. To add this only happens when the car is just turned on in the begining of every day only when its just warming up, aftr that trought the day f i turn it on or off put it in reverse or D its b just fine only does it when the car is turned on for the first time of the day.
FERNY_M3 is offline   Reply With Quote
