Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#21 | |
We have pulled a couple motors apart that had the vanos tab broken but the cars were still running just fine. We usually have used vanos units in stock if anyone needs one. :-) Chris
![]() ![]() HorsepowerFreaks.com 12905 NE Airport Way Portland, OR 97230 (503) 256-5600 BMW Performance Parts Product questions or to purchase - sales@horsepowerfreaks.com |
#22 | |
Big Pimpin'
For a 100% pure drag racing build.. deleting the VANOS would be the first task I would undertake. Drag racing is WOT action. What purpose does variable cam timing have in that environment? Maybe make driving around in the pits a little more luxurious? I do agree VANOS has it's benifits in certain areas.. but for the guys getting hard core serious about drag racing I see it as an obstacle. |
#23 |
Sorry didn't pay attention to reading the whole post. Kind of breezed through it all. Seems like the edge of failures are leaning towards the later years (04+), but many 02 and 03s are still affected.
#24 | |
Raj could explain it better, hopefully he writes something up.
#25 | |
An all out drag racing cam profile results in something that is often not even street able, barely idles, lots of overlap. The cams that Faelar is talking about would have to be one-off, carefully thought out, custom grinds that maximize a narrow band of forced induction situation. Am I correct so far? I dont know. A sin against the German Car Gods? Maybe not. I remember seeing an older BMW pulling a wheelie and scorching the quarter mile in 8 seconds and this SEVEN second M3!: Do you think either of these had a working vanos? I dont know. You tube is full of super fast drag times for almost every M3 except the E46. Maybe its time to get radical.
![]() Last edited by Bdave; 09-22-2011 at 11:45 PM. |
#26 |
And...nobody has a drag e46 M3 in this forum...so vanos is staying.
#27 | |
Big Pimpin'
Compare this dyno plot from a billet 6765 with just a .68 hotside to a HPF stage 3. Yes, once it makes peak power it does run out of steam some, however you'll notice it makes peak power sooner. The power band is also more manageable, it doesn't have that huge hump which is one reason I believe that HPF cars have traction problems and also the reason they feel so powerful. I adjusted the dyno plots so they had the same vertical and horizontal reference. This is pretty close to an overlay I could make.
#28 | |
We've spun a 6765 up to close to those numbers in the first graph and it lasted a few pulls until massive smoke came billowing out. We'll see how long the one that made this first dyno pull lasts. We back the boost down to keep the turbo from overspinning and cooking the bearings. We've destroyed close to 10 turbos or more by overspinning them on the M3 over the past 4 years. We're the only company that tunes the vanos. I can guarantee you, you will lose 50rwhp of power across the entire spectrum if you can't move the cams to match the airflow into the engine. Also, you can't run a higher duration cam, nor would you want to. These cams are NA so they have a much greater duration and overlap than turbo cams would because they are relying on the intake and exhaust valves being open together longer to pull in the "un-pressurized" intake pulse. Increasing the time both valves are open on a turbo motor allows some of the new intake charge to simply blow out the exhaust. There's a ton of theory behind the exact timing of events and how the cams work. The factory S54 cams also have an extremely fast ramp with a ton of lift. The duration and lift they have is more than sufficient to accomodate 1022rwhp which we already did without any modification to the head, valves, valve springs and cams at hardly any boost (31psi) on 110 leaded. Had we run a larger turbo, more boost or better fuel we would easily get into the 1200rwhp+ category still with no cams or headwork. Any change to the cams, valve sizing or vanos will cost you "area under the curve". The reason I know is because we've set the cams to every position possible for 3 weeks of dyno tuning and set ours up with the optimal position. Simply changes to cam timing on the S54 will easily cost 100rwhp. The reason your powerband is still good is because the DME is controlling the cams. They are not "parked". The problem is simply how to provide the optimal tune for the VE of the engine and BMW engineers accomplished a lot of this by providing the technology to move the cams. You can't feel it in the M3 because it is variable and seamless. Take a Honda VTEC motor for example and you can definitely feel the change when it kicks to the new setting. It would be like never having that. I ran cam gears on my Supra and ran +1, -3 on the cam gears. Changing even one degree on either cam shifted the powerband to the right or the left. With vanos you don't ever have to crawl under the hood and make an adjustment nor do you ever have to shift the powerband sacrificing power at one rpm to gain it at another. You just "raise" the powerband at every rpm by putting the cams in the optimal position. Also.... The valve springs in the S54 have enough spring pressure to handle 40psi and 9,000rpm+. So adding more spring pressure is just going to cost you power. Chris.
![]() ![]() HorsepowerFreaks.com 12905 NE Airport Way Portland, OR 97230 (503) 256-5600 BMW Performance Parts Product questions or to purchase - sales@horsepowerfreaks.com Last edited by HPF Chris; 09-23-2011 at 04:24 PM. |
#29 | |||
Big Pimpin'
Friendly wager for Mfest next year, fastest track and 1/4 mile times, one steak dinner? |
#30 |
This is juicy. Why have we not heard of this before? Can you describe more about this in detail? According to John (I asked him) HPF does not touch the Vanos in a built motor unless the customer specifically asks for servicing.
I dont know why, but I have this phobia about my Vanos failing. I am possibly interested in refurbishing it before it fails. So what sort of tuning would a 2.75 owner be interested in? This is good stuff. For my purposes, I love my vanos and I want it working as good as it can. John mentioned that he sees gears fail. I read that its the Buna N piston seals that fail. Needs Viton. Then you guys do some magic in tuning the darn thing. Cool.
#31 |
Big Pimpin'
HPF isn't the only shop that can tune VANOS. It's the only kit vendor that tunes the VANOS.
#32 | |
Chris
#33 | |
#34 |
What seals do you guys use when you put the Vanos back on the car? Also when you say you adjust it do you mean via EMS or does John adjust something mechanically with the Vanos unit iself?
#35 | |
The brand new Beisan seal kit sounds interesting. How many man hours would a shop charge to install something like this? Isnt a VANOS R&R big man hours/special tools=big bux? It is a pretty major decision to spend big dollars to fix something that is not broken.
#36 | |
Chris.
#37 | |
Take care, Chris.
#38 | ||
My Ride: 05'M3, 03 996TT
Link to other info i found for VANOS intake cam bolts DIY: http://m3forum.net/m3forum/showthread.php?t=321494
![]() Best ET 11.93 Best Trap 134 |
#39 | |
In regards to specific years, I have not seen any conclusive statistics for susceptibility. Honestly, I still think that those that experience VANOS failures are a very small percentage. It's just being on the forums, we are a very small niche of enthusiasts and obviously when something goes wrong, it is bound to find it's way here. So I'm not even sure if it's safe to say that a VANOS failure is "common" but more so that the specific underlying cause of a VANOS failure has lead to a consistent aggregating factor.
![]() 2002 E46 M3 6MT | Jet Black . Black Nappa | My Build Thread Evolve Automotive CF Airbox & AlphaN . Supersprint V1 Stepped Headers & V1 SPipe . KW V2 . Volk Racing TE37 |
#40 | |
![]() Best ET 11.93 Best Trap 134 Last edited by 02black330ci; 09-27-2011 at 06:50 PM. |
