E46 Xi Forum
Old 09-19-2011, 05:08 PM   #1
luke1213
My Ride: 2002 325xi 4 door
interior/exterior pieces junk?
i know this is my first bmw but does everyones bmw have junky interior/exterior trim pieces? i have replaced the windshield cowl because it was breaking apart, replaced half of the front grille, need to replace a trim piece for the driver side windows, need to replace the weather stripping on a portion of the driver side window, the center a/c vent is breaking apart, the 2.5" door speaker grilles have broke and now the speakers are laying down inside the door panel, the hazard light/door lock button has sunk down into the armrest, the trays in the trunk are broken along with the marker lights for the license plate and few other odds and ends. my friend owns a 323 and 328 and his has similar problems with bells and whistles breaking. i understand i did buy a used car and with that comes problems. i guess it all goes back to who the previous owner was. i know that any vehicle i have owned in the past whether i paid 2k or 60k i took care of it. i have a mustang gt that i have owned for almost 11 years and other than the normal wear and tear on the interior and exterior, the car is in mint condition with 82k miles. i guess it's just a pet peeve of mine.
luke1213 is offline   Reply With Quote
Old 09-19-2011, 05:16 PM   #2
SamDoe1
My Ride: 2004 330xi, 3 pedals
You bought a car that is 9-10 years old depending on when it was built. It was owned by someone who probably didn't care about it at all. The fact that it's in good running condition is something to throw a party for. There are plenty of 99-01 cars on here in flawless condition because of the way they were cared for.
You pretty much hit it on the nose with your Mustang, you took care of it and it is in mint condition. Replace all the broken stuff on your car, give it a good wash, clay, polish, and wax and see what it looks like. Also, before you mod make sure you maintain properly. The quality of BMW parts is second to none in most cases, you should be able to tell that almost immediately compared to your late 90s Mustang...
Old 09-19-2011, 05:16 PM   #3
ANREC330
Modded ///Member
My Ride: C6 Vette & M3
Pics, and mine is clean as a whistle.
** Too much for a signature **
Instagram @ j_cerna
ANREC330 is online now   Reply With Quote
Old 09-19-2011, 05:39 PM   #4
luke1213
Fortunately the car does run good. I had to do some maintenance to it but I expected that. I'll get all the pieces that are broke fixed eventually. Once I do, it will be a better looking car. Dont get me wrong the car looks pretty good with all things considered and I really like the car.
Old 09-19-2011, 07:58 PM   #5
whitexi
My Ride: 02 325xi, 98 integra
Just don't open the back doors and lean onto the rain channel that curves around the back doors. They will break to and there not cheap.
whitexi is offline   Reply With Quote
Old 09-19-2011, 08:11 PM   #6
luke1213
That's funny u mentioned that. That is one of the pieces that are broken. Lol
Old 09-21-2011, 05:13 PM   #7
MrJL
My Ride: 2003 330i
When you say rain channel, are you talking about the metal strip that runs along the top of the door? I have been looking for a name for that thing for a while because mine has seperated, and I cannot seem to get the two ends back together.
MrJL is offline   Reply With Quote
Old 09-21-2011, 05:50 PM   #8
luke1213
check the link below and look at item #13. this is the part i am referring too on my car that is broke and needs replaced.
http://www.realoem.com/bmw/showparts...67&hg=51&fg=20
Old 09-22-2011, 03:54 PM   #9
MrJL
My Ride: 2003 330i
Yep. That's the one. It seperated on a seam above my rear driver side door. I cannot push the two sides back together. There is a 1 inch gap that catches people clothes when they brush up against the side of my car. I have got no clue how this happened or how to fix it. I don't know the extent of the damage to yours, but I am just going to live with mine for now... I am busy stopping oil from spraying out of every crevice in my engine at this moment.
Old 09-22-2011, 04:23 PM   #10
luke1213
Getting your oil problem fixed would be my first concern too.
Yea mine has about a 1/2" gap and it is being held on by two sided tape. Got other issues with the car at this moment like yourself. This can wait.
Old 09-22-2011, 04:25 PM   #11
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
they pop off... that part you're talking about is where they were fused or glued together and it has separated.
you cannot slide the main part back, you must remove it and then put it back in the proper position.
remove the long portion (pops off with clips)
put some epoxy on the part that overlaps.
replace the long part and wait to dry.
that simple
don't feel bad, I suffered with that for years before someone on the forum here told me what to do.
when i did it i couldn't beleive how easy it was.
i kinda felt dumb, but then again i was afraid to break or bend the long trim piece.
GL
btw-
apparently some are on with glue goop but mine wer on with clips:
this his how i discovered the fix:
http://forum.e46fanatics.com/showthr...766&highlight=
-j
Bimmer4Lyfe is offline   Reply With Quote
Old 09-27-2011, 11:57 AM   #12
MrJL
My Ride: 2003 330i
Thank you. I can't wait to stamp "Fixed" on this issue. I will probably be able to give this a go on Thursday. Like you said, I was afraid to break/bend the piece.
Old 10-10-2011, 11:16 AM   #13
MrJL
My Ride: 2003 330i
No luck. I was able to bring it in a little closer, but the gap closed from about 1" to .5". I can't get the front part any closer to the back, and the back is on clips, so I can't really move that or they don't line up. It was also 2AM, so I might give it another go with the metal warmed up in direct sunlight.
