Old 09-20-2011, 02:29 AM   #1
MJLavelle
My Ride: 2001 BMW 330ci
Tired of poor fitting Depo Clear Corners? Look at this great fitting, $24 eBay set!
I recently bought the clear corners in the link below, off of eBay.
http://cgi.ebay.com/ebaymotors/99-01...ht_4476wt_1026
Here is the link for the store, since the link for the actual item will eventually disappear.
http://stores.ebay.com/p-s-team?_trksid=p4340.l2563
Edit: I should point out that these were for an 01' 330ci coupe, with the clip in lights. I can not make any guarantees that their sedan version or their screw in units will fit as well. But they fit great on my car, FWIW. Also, they have the normal v clip mount. No modifications or extra parts. You just slide them in, and the clip engages.
I originally had Depo's, and they were a horrible fit. They stuck out, and looked bad. I paid about $60 for them, from Bimmian.com.
I paid $24 for these, and they fit perfectly. I was a little skeptical, but I figured that for $24, I did not have a lot to lose. I was pleasantly surprised. The clips and posts are very close to the OEM corner lights, more substantial than the Depo's. The ones I bought have a clear lens, that I think matches well with the headlight assembly. They also have other versions, such as clear smoked, and the non-transparent, OEM style, also in smoked (at least at the time I was shopping, I do not know what they are currently listing). I have attached photos, so you can judge for yourself. BTW - I did not have to do any trimming or adjusting to get these to fit. They popped right in. There are several posts on this forum for trimming and fitting Depo's, so I am sure I am not the only one who had issues with them.
Side view. Note the flush fit.
Untitled by MJLavelle, on Flickr
Another view. Note that they fit flush with the headlight lens.
Front/side close up view.
Full front view, passenger side.
Front view, entire front. I was pleased with the overall look.
As you can also see, the chrome bulbs I bought from Stealthauto.com have degraded quite a bit in the 2 years since I installed them with the Depo's. It was not as obvious when they were in the non-transparent Depo's. I may replace these soon. They are showing a good bit of yellow now.
Last edited by MJLavelle; 09-20-2011 at 04:29 AM. Reason: Clarified application and mount type.
Old 09-20-2011, 02:34 AM   #2
Andy2108
My Ride: SpecE46 & E46 M3
those are the same exact peice of junk ones that came with my M3 when I bought it. They didn't fit properly and were so loose (since they had been installed with "custom brackets") that one litterally fell out on the highway.
I bought new depo corners from ecs tuning (I think) for like $30. they installed like OEM and look OEM, but better.
To each his own, I guess
De gustibus non est disputandum.
Old 09-20-2011, 02:54 AM   #3
MJLavelle
@ Andy2108 - I don't think these are the same, or they have been improved. No "custom brackets" or any monkey business. They clicked right in. Did you notice that I said that I did not have to do any fitting or trimming? I will be glad to pull them out and post a photo of the clip assembly. It looks like the OEM lights. Maybe the outside appearance was the same? Since they came on the car when you bought it, I have no idea how you could determine that these were "the same exact ones", in the 6 minutes after I posted this. There are other sellers who offer clear lens corners (Kholaty for one). Also, how do you know that the "Special Bracket" was not a fix made by the original owner when he was not able to fit them in right? Were your lights designed for the screw in type of corner light?
Now, my Depo's did pop out once while driving, because one of the posts had broken off. And I was never able to get them to completely "click" in. Do your Depo's fit right? Are they the clip in type? If so, feel free to post pics. Maybe they have changed. How long ago didd you buy them?
It is not like I have anything to do with this company. I was just surprised that these $24 lights fit better than the $60 Depo's I bought 2 years ago. I have had these in a month, and so far, they have not budged. I have also hit them with a direct blast from a pressure washer, and no leaks.
Last edited by MJLavelle; 09-20-2011 at 03:32 AM. Reason: F#%king autocorrect and other stuff
Old 09-20-2011, 04:24 AM   #4
BBBoy323i
My Ride: 01' 325ci
I have these on my 323i, now i know where the PO got them. IMHO i love the look and fitment seems okay (think i have the old model), wish the bulb was amber instead of yellow, but they really match the black shroud (my model). Looks nice
BBBoy323i is offline   Reply With Quote
Old 09-20-2011, 10:58 AM   #5
My Ride: 2016 Lexus
My clears from Khoalty have been perfect... but the clear sidemarkers from Khoalty? theyre already yellowing and they have no rubber surround so its hard plastic against my nice paint and it looks stupid. need to find some good clear sides. probably oem.
Old 09-20-2011, 11:07 AM   #6
Guest021715
Account closed.
The white surrounding doesn't really fit with the rest of the headlight imo. Smoked corners would've gone well with your black headlight inserts.
$25 Depo corners from Khoalty would still be my choice.
Old 09-20-2011, 11:10 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Old 09-20-2011, 11:29 AM   #8
TArse
My Ride: 03 330xi, 87 325is
my first set of clear side markers from khoalty were great. Second set is garbage
Bimmer App - Because it's faster than my computer.
TArse is offline   Reply With Quote
Old 09-20-2011, 12:19 PM   #9
FastHackem
My Ride: E60 M5
I think it looks really nice. The bulbs do need to be replaced though IMO. Have you considered error free LED bulb replacements?
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 09-20-2011, 12:23 PM   #10
bimminge46
My Ride: 323Ci, 89 325i ETA
i had a feeling they were going to be the disco balls
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 09-20-2011, 02:40 PM   #11
trizzuth
My Ride: 228k, 16yr old B3AST
i used to have some of these honda-looking corners on my 330i. before i got some sense slapped into me and bought some DEPO smoked corners.
trizzuth is offline   Reply With Quote
Old 09-20-2011, 02:54 PM   #12
Mr_325
My Ride: 2007 X5 3.0Si
for facelift sedans i can vouch for Bimmian fitment and looks
i think however next time i will be going with Turners as there price is better and i've seen in previous threads they use the same company that creates the OEM corners.
Mr_325 is offline   Reply With Quote
Old 09-20-2011, 03:27 PM   #13
MJLavelle
Right. Because you never see blacked out lights on a Honda, or 78' Camaro's.......
Old 09-20-2011, 04:05 PM   #14
Lusticles
My Ride: 325Ci
Look like a better fit than my Khoalty corners. Too bad that they're rather ugly.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 09-20-2011, 04:47 PM   #15
MJLavelle
Wow, judgmental group today...
@Lusticles - they have OEM looking ones as well. Check their website. I think that the Depo fit issue must be Pre-facelift only.
Old 09-20-2011, 04:50 PM   #16
liquiddawn
My Ride: 2001 BMW 330i
I have a pre-facelift and my DEPO clear corners fit perfectly fine and line up perfect. I have no issues with them at all!
liquiddawn is offline   Reply With Quote
Old 09-20-2011, 04:56 PM   #17
MJLavelle
Well, I know I am not the only one. There are several threads on this forum for trimming and fitting Depo corners. When did you buy yours?
Old 09-20-2011, 04:59 PM   #18
liquiddawn
I just bought them about 3 weeks ago. If you take out the lower headlight trim and push them in they should line up perfectly. If you just slide them in they don't fit 100%. This is what worked for me.
Old 09-20-2011, 05:06 PM   #19
GMrc51
My Ride: 2001 325 coupe topaz
Sorry but they look cheap.....got my smoked set up frm jlevi and it was a snap....
Sent from my PC36100
GMrc51 is offline   Reply With Quote
Old 09-20-2011, 05:15 PM   #20
MJLavelle
They must have changed the design of the Depo's. The ones I bought 2 1/2 years ago fit horribly, without trimming the crap out of them.
Also, these must not photograph well. They look pretty good in person, and I have had 4 people ask where I got them. That is why I posted this. I'm happy, and that is what counts. If you have Depo's that fit, then great! Move on, nothing to see here.
bad fitting corner lights, clear corners, depo alternative, depos, ebay
