Old 09-21-2011, 07:58 PM   #1
druggrepp
My Ride: 325ci 2001
whistling noise when starting
2001 , 325ci 5spd.208k, 33mpg, I love this ride...9th BMW
This just started.
High pitched whistle when cold engine started.
Goes away after engine warms up.
Both intake boots new, icv cleaned, disa cleaned and inspected.Both idlers and tensioners replaced.
I looked for torn or ripped hoses , nothing found.
Any ideas?
druggrepp is offline   Reply With Quote
Old 09-21-2011, 10:06 PM   #2
Bavaryan
My Ride: 330i w/out park.
Secondary air injection pump perhaps? It will make a small whistle noise-that is normal. I'm presuming after 208k you know what is normal vs. not normal though.
That pump could very well be on its way out though, listen to that and see if the noise goes away when it shuts off.
Bavaryan is offline   Reply With Quote
Old 09-22-2011, 06:47 AM   #3
druggrepp
My Ride: 325ci 2001
Makes sense,
Will do
Old 01-05-2013, 04:35 PM   #4
jtshawtek
My Ride: 2001 330i
Here is a video of what i am experiencing:
Is this similar to you?
jtshawtek is offline   Reply With Quote
Old 01-10-2013, 05:50 AM   #5
Jsmk23
My Ride: 02 325i-JapanRot Red
Mine does exactly the same. Do you happen to know what it is?
Jsmk23 is offline   Reply With Quote
Old 01-10-2013, 08:34 AM   #6
Sansho
My Ride: 2001 325i
If it happens when you start up and goes away around 2 mins later, then it's associated with your secondary air pump (on the passenger side of the engine), as RG5384 mentioned above. The video sounds more like bearing noise. When was the last time the tensioners were replaced?
Sansho is online now   Reply With Quote
Old 01-10-2013, 12:48 PM   #7
Jsmk23
Yeah mine usually goes away after a couple mins or when the car gets warm. Could you help me out and inform me on what it could be and where exactly is it at? I am fairly new to BMW's and would like to most do most of the work myself rather than mechanics.
Old 01-10-2013, 05:38 PM   #8
Passnu2
My Ride: Sport Wagon
had the same noise and it was my idler & tension pulley. Noise went away for one whole day and returned? I'm hoping that its just the tension pulley for the power steering or A/C (forgot what the second belt was for) that I heard today.
Passnu2 is offline   Reply With Quote
Old 01-10-2013, 08:05 PM   #9
Jsmk23
Is this a bad thing or an easy fix?
Old 01-10-2013, 08:55 PM   #10
Passnu2
not bad, harder on the auto vs manual trans. But its an easy DIY. Search "pulley" and there is a nice write up on water pump, expansion tank, and pulley replacement. I didnt replace the A/C pulley nor did I check it. When I took off both pulley they were toast so glad I replaced them before I had something major happen. Think it was about $60 for both.
Old 01-10-2013, 08:58 PM   #11
Passnu2
I did get that same noise again today as I was in a drive thru. What I noticed today was if I put my car in Neutral the sound pretty much went away. Back in drive the noise came back. After the car sat for a few hours I started it up in the garage and hear nothing so will see how tomorrow goes. Maybe I will have to replace the A/C pulley just to rule it out and probably should have.
Old 01-10-2013, 08:59 PM   #12
Jsmk23
Oh okay. If possible can you shoot me the link?
Old 01-10-2013, 09:21 PM   #13
Passnu2
here you go...
http://forum.e46fanatics.com/showthr...ghlight=pulley
Old 01-11-2013, 01:35 AM   #14
Jsmk23
Thanks bro.
Anyone know how much it would cost more or less with all parts?
Old 01-11-2013, 07:36 AM   #15
Sansho
My Ride: 2001 325i
Idle pulley $36 BMW or $25 OEM, complete AC tensioner $56 OEM or $90 BMW, complete water pump/alt mechanical tensioner $53 OEM. Some have updated to the hydraulic tensioner which was a BMW update, runs $100 for OEM. If you just want to replace the pulley on the mechanical tensioner(s), get Dayco 89133 from Amazon for $19 or Autozone sells it under their brand name to. Made by OEM INA. BMW prices from discounting BMW sponsor TheBMWPartStore.com and OEM from Autohausaz.com.
Old 01-11-2013, 11:32 AM   #16
Passnu2
I got mine at the parts store, Dayco was the brand. Took a video this am of my noise ill try to upload to see if anyone has an idea. I can't tell if its my pulley, possibly bad new pulley, or if its the intake boot issue. What's odd is in neutral or park it goes away. I hear it the most in drive while completely stopped.
2000 323iT - 158k
Recent Maintenance: Spark Plugs/CCV/Expansion Tank/Radiator/Thermostat/Both Intake Boots/Air Filter/Cabin Filter/Valve Cover Gasket/Control Arm Bushings/All Pulleys/Hatch Shocks/Vanos Oil Line/Fuel Pump/Fuel Pressure Regulator/Rear Rotors & Pads/Belts/Water Hoses/Front End Links/Front Sway Bar Bushings/Alternator/Power Steering Hoses/Power Steering Reservoir.
Old 01-11-2013, 11:43 AM   #17
Passnu2
going to be so happy if I have to tear it down again to replace one of these new pulley...thoughts on the noise??
Old 01-13-2013, 11:01 AM   #18
Passnu2
tore it apart again, took off the new pulley's and made sure they were torqued to spec. All good, took off A/C belt and the sound went away so I removed the pulley and it sounded shot so hopefully this was the issue and if so I suggest to just replace all 3 while you have the front end apart especially if your an automatic. If it turns out its something else I will report back
Old 01-13-2013, 11:30 AM   #19
AmazingNutz
Banned User
My Ride: carpet
OP, its the water pump.
Sent from my G6
AmazingNutz is offline   Reply With Quote
Old 01-14-2013, 05:45 PM   #20
Passnu2
yet again noise came back for me...Same thing when I replaced the other pulley's.
