#1 |
Tips for easier DDE (Angel Eyes) Installs
Granted I've been working in the 12-Volt electronics industry for some time now, and wiring a car just comes naturally now.....I hope this can help some of you and not confuse you too much. FREE TIP for making installation of your own DDE kits a breeze without having to run extra wires and relays(unless the person you purchased them from MAKES you use their relay kits to honor their "warranty"). These wiring harnesses and relay kits that come with a lot of DDE/Angel Eye/Halo Kits are complete overkill, not to mention costly. DDEs draw such little current that you can simply tap directly into pretty much any power source in your car and it would power them just fine, such as your ECU power wire.
Relays are used for accessories drawing higher amounts of current, to where you want to be able to switch something on by means of a power source that cannot fulfill the needs of the accessory you want to turn on, therefore the Relay still allows you to use that power source to turn your accessory on, but actually draws power for that accessory from a different source of your choice, such as a direct battery connection. I know that sounds confusing, but back to the topic at hand. When wiring up your DDEs, even if you want to get fancy and have them automatically turn on when the car is on, but also be able to activate them via your remote (most companies out there charge extra for this for some reason!!), just run a wire from your driver's side floor light 12+ Positive Wire into your engine compartment right near the ECU box, then tap a 2nd wire into the thick RED ECU wire with the yellow dots on it. Now you have two wires run to a common juncture point, each with its own separate power source. Now run the positive wire from you DDEs (it's easiest to ground each DDE ballast out as close to the ballast as possible (negative wire), then take the positive wires from both ballasts and join them into one wire for easier routing and less clutter in your engine compartment) up to the ECU box area. This will be your "junction point" where all your connections will be made, keeping things simple, neat, and hassle free. The key to connecting the DDE's power wire to the 2 separate power sources you now have at the ECU box (the interior light source and the ECU constant source) is to Diode Isolate the 2 wires. Diodes can be purchased at Radio Shack or any car audio shop for less than a dollar. Take 2 Diodes and twist the wires together (coming from the diode end with the silver band around it) and use a butt connector to attach the Diodes to your single DDE Positive Wire. Now you simply connect your 2 power sources to the other end of each diode (one power source wire per wire coming out of the diodes). This allows your Halos to be powered by either source, yet keeps the juice flowing in only one direction (to your DDEs) and prevents any shorts, if say your ECU power and your interior light power is both on at the same time. It may sound complicated to those that don't have much experience in 12-volt wiring, or don't know what a Diode is, but it's really quite simple. Coming from someone like me who has been in the Car Audio/Video & Security field for a while now, trust me, this is the way to go. Once you figure out how things like relays, switches and diodes work, the possibilities are endless as to what you can do with your car's electrical system. Anyways, sorry for the longa$$ writeup, but I hope this might help some people out, save you some money, and avoid the tedious and sometimes confusing Relay setups that everyone pushes with their DDE kits. |
#2 |
I like your idea of reducing the number and length of wires.
So you are piggy-backing on the interior light and ECU fuses? I'd hate to loose power to the ECU because of a faulty DDE ballast blowing the fuse. Also, with the lighting and ECU power in parallel you can potentially draw twice the current from the DDE before blowing either fuse. There really isn't any protection at all for the DDE wiring in the event of a short. Adding an inline fuse between the diodes and the ballasts would do the trick (2 Amps). I read another DDE post somewhere with a circuit diagram using diodes. Put the two together (with the inline 2 Amp fuse) and you've got a great DIY.
#3 |
Yes always use an inline fuse when adding an accessory such as DDEs, I pretty much assumed whoever was reading this already knew you should use an inline fuse ; ) Thanks for bringing it up though, incase we got some newbies that want to learn how to do it the right way. I doubt a ballast problem/short would blow the ECU fuse, since the ECU fuse is a pretty decent amperage if i recall correctly, so it's definitely a good idea to use a small fuse inline on the DDE Power wire (2-5amp), tapped in before your junction/connection points at the ECU Box area of your engine compartment. The closer the fuse is to the DDE Ballasts the better, so in the event of a short, the entire wire doesn't heat up and start to melt all the way up to the ECU Box before the fuse blows. I will post pics of my finished installation in a day or so hopefully.
#4 |
Something you forgot to mention is diode size. Most common diode size is 1-amp. For DDEs is best to use 3-amp diodes, protected by a 3-amp fuse. Although a 1-amp diode would probably work, you are really pushing the limits of the diode, as DDEs current surges over 1-amp at times and could cause the diode to "melt down".
#5 |
Ya I know Im really digging up an old thread here, but you have to at least respect the use of the search button right?
Can anyone verify this last bit of information about current surges above 1 amp?? Also at what kind of durations? If its just a few usec or msec than ok, but if not... The reason I ask, is that the harness that came with my Predator Chromiums uses a 22awg wire for the Brown Trigger (footwell, remote app). This wire sources voltage to the ballasts provided the ECU isnt providing power to the relay (i.e Scenario: Normally Closed position). Stranded 22awg is rated for approx Nom Current: 1.28A and Max 1.45A. Seems like they would be cutting it a little close by using 22awg. 18awg would have been a better choice, provided theres enough room/space to fish it all the way to the footwell tap. I havent installed the kit yet so I dont know. Thanks. |
#6 |
I have seen 1A fuses blow from DDEs regular operation. Never have measured max current though. I know it does not exceed 3A. In case of doubt, always use a bigger wire, especially for longer distances. We always use 18ga wires fro DDE instllation.
#7 |
Hmmmm.
Im going to conact Jlevi about this, since I got if from them. If no one can givea concrete answer, Ide rather use the 22awg to feed the coil of a 2nd relay with 18awg+ on the NO and COM contacts to source the voltage. Im already a bit skeptical of the harness wiring in which all of the 22awg is rated for 80C when it should be 105C for automotive. I dont mind redoing it, just want to make sure it doesnt void the warranty. |
#8 |
Even if it does, remaking the relay is simple. The DIY guide is around the site, and it can easily be made in under 10 minutes.
#9 |
The best way to do it is with two 3A diodes (no relay necessary), 18 gauge wire and a 3A fuse. Have done many cars this way with no problems.
#10 | |
Tips for easier DDE install
#11 | |
Tips for Angel Eyes
You are my new best friend. I followed your instructions, hooked 'em up, held my breath, and pushed the unlock button on my fob:Voila!!! So, let's recap: CCFL Angel Eyes from E-Bay:$5.00, Shipping and handling: $20.00, Miscellaneous parts for install: $12.00, Getting this advice for free and having it work:F****ng PRICELESS!!! You are a Steely-Eyed Missleman. I owe you a cold one if we ever meet! Thanks again!!! |
#12 |
My Ride: Silv/Grey M3 (SMG)
Thanks for the simpler way of doing it.. Well here's the finished product. I will put up a DIY for the non Umnitza angel eyes one if needed.
2004 M3 Silver/Grey Premium Package, SMG.
#13 |
My Ride: 02 330Ci Norma Jean
Would by any chance you have a wiring diagram? I think that would help out more than text...
- Gerry (USAF Combat Controller)
![]() OEM Mtech2 | PSS Coilovers | Orion Angel Eyes | 19" BBS CH | Hardwired V1 | CF Blue/Silver Roundels | CF Clubsport Splitters | OEM M Steering wheel | Black Kidney Grill | CF Windshield wipers |
#14 | |
Just diodes (substitute "grey" with whatever color feeds your DDE ballasts): Or using a relay just like the sponsors here:
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol. |
#15 | |
Also, I would recommend 3A diodes and a fuse at the ECU tap feeding the diode as well. |
#16 |
Since I only used the ECU to power up my DDEs do I still need the Diodes? But I am using an Inline Fuse thought. Currently at 5amps. I am at work right now. But when I get home.. I will take pics of the stuff I did.. It is still not finished.. I.E. clean.. I still need to zip tie the wires and stuff.. but you will get the idea.
#17 | |
Only thing you need is the fuse to protect the ECU (FAN) circuit from shorts in the DDE ballast or new wiring. |
#18 |
Unless the relay has a flyback diode installed I would avoid doing that to prevent potential damage to the ballasts when the relay de-energizes.
#19 | |
Actually, not a bad idea to add the diode either way, since you have the current spike going to the ECU fan wire anyways. |
#20 |
Should I go with a lower amp like 3 instead of a 5 that I currently have... Just curious. Thanks.
