Old 01-14-2013, 07:12 PM   #21
Dave1027
My Ride: '06 IR zhp coupe
Originally Posted by Passnu2 View Post
yet again noise came back for me...Same thing when I replaced the other pulley's.
My new to me ZHP has the same noise right after a cold start and goes away in about 20 seconds. You think it's the tensioner pulley?
Old 01-14-2013, 09:36 PM   #22
Passnu2
My Ride: Sport Wagon
Took off my AC belt and my noise is gone again so it's staying off
2000 323iT - 158k
Recent Maintenance: Spark Plugs/CCV/Expansion Tank/Radiator/Thermostat/Both Intake Boots/Air Filter/Cabin Filter/Valve Cover Gasket/Control Arm Bushings/All Pulleys/Hatch Shocks/Vanos Oil Line/Fuel Pump/Fuel Pressure Regulator/Rear Rotors & Pads/Belts/Water Hoses/Front End Links/Front Sway Bar Bushings/Alternator/Power Steering Hoses/Power Steering Reservoir.
Passnu2 is offline   Reply With Quote
Old 01-14-2013, 09:47 PM   #23
Passnu2
Mine would seem to go away when driving then returned when stopped in gear. In neutral or park it used to go away. This last time it was constant and since I replaced my pulley makes me believe my ac clutch/pulley took a crap. It's cold out so in no rush for ac lol
2000 323iT - 158k
Old 01-14-2013, 09:51 PM   #24
Passnu2
Do you know if the coolant system has been overhauled? (Water pump/thermostat/expansion tank/ect) if yes then I would start with the pulley's and new belts. I'm new to this car myself just not working on cars. Post as much as you can as others may have some suggestions as well
2000 323iT - 158k
Old 01-15-2013, 11:45 AM   #25
Passnu2
well it came back yet again for me today...Took off the AC belt and noise fully went away again. Drove it for 15 min and it came back again. Hear it when stopped at a traffic light and "seems" to go away upon acceleration. I'm lost here
Old 01-20-2013, 12:26 PM   #26
JLiprie
My Ride: 2002 E46
Exact same problem. Check the hose off your secondary air pump. Mine had a good size tear. Also the hose rubber deteriorated to the consistency of modeling clay. Really should take it off and look at it.
JLiprie is offline   Reply With Quote
Old 01-20-2013, 04:45 PM   #27
Passnu2
well I'm almost done with the lower intake boots (both) and the DIY: CCV, DISA, ICV, Oil Separator...I did find the prior owner took electrical tape to the hose that comes off the valve cover to the oil separator so my guess is that was my noise or my intake elbow. Didn't see anything wrong with mine but still installed the new one. I hope to report back with NO noises
Old 01-20-2013, 08:46 PM   #28
Passnu2
all good, not a fun project, but its nice and quiet again.
Old 01-21-2013, 03:09 AM   #29
Jsmk23
My Ride: 02 325i-JapanRot Red
So if you can break it down, what things did u do/replace?
And what did it turn out to be?
Jsmk23 is offline   Reply With Quote
Old 01-21-2013, 11:03 AM   #30
Passnu2
^ I'm assuming it was partially my pulley and the vacuum/oil separator....(just a guess)
I replaced the following:
Both lower intake boots (T/B & MAF) - same as the Oil Separator for the DIY...
Replaced Idler Pulley & both Tensioner Pulley
Oil Separator and Vacuum Lines.
I did get a P0340 - CAM Shaft Circuit today so I must have a loose connection or just ironic that it went. Ill play with this today.
So far no noise today and it was going away for ~ 1 day when I did the other items so if I have not replied here in a few days my noise if finally gone.
Old 01-21-2013, 09:13 PM   #31
Passnu2
Im all good, day two with no noise and I forgot to plug the Cam Shaft Postion Sensor back in so it was my stupid fault for the code. Cleared the code and drives great! Glad to be done of this noise!!!
