Old 09-23-2011, 12:54 PM   #1
Tutankhamon
My Ride: 2017 M2
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Quick Power Steering Question
Just wanted to try and diagnose a minor issue I seem to be having. At idle the car seems to have a bit of a drone coming from what I believe to be the passenger side of the engine. It's very inconsistent and doesn't happen all the time. I believe the drone to be coming from the power steering because I can reproduce the sound whenever I turn the wheel a bit.
What's throwing me for a loop however is whenever I press down on the accelerator a bit and get the rpms north of 1000, the drone goes away. I checked my PS fluid and it seems a bit low. Somebody correct me if I'm wrong here but there are 2 ridges on the PS dipstick, should the level be touching the fill line or should it be right at the bottom line? Currently it's sitting right at the bottom first ridge.
If it's not the PS what can be located towards the passenger side that would drone at idle like that?
Also I guess I should ask, where exactly is the PS pump located?
Thanks in advance for the help.
Tutankhamon is offline   Reply With Quote
Old 09-23-2011, 01:11 PM   #2
avglushk
My Ride: e92
I had that drone too. Put more ATF in PS container. Fluid should be at the top ridge.
Originally Posted by Arsevader
Sorry to hear about your mirror. This is what happens when you don't change your mirror fluid at the recommended intervals.
For Sale: 1. OEM used headlights and corners, see link http://forum.e46fanatics.com/showthread.php?t=884565
2. 2 brand new Bosch post cat oxygen sensors
avglushk is offline   Reply With Quote
Old 09-23-2011, 01:14 PM   #3
Tutankhamon
My Ride: 2017 M2
Was your drone also coming from what seemed like the passenger side?
Old 09-23-2011, 01:21 PM   #4
avglushk
My Ride: e92
hard to say. dont remember. it was long time ago. But it always happened when i was making right turns. For some reason didnt hear anything when i was turning wheel to the left. But adding more ATF solved my problem.
Old 09-23-2011, 01:32 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
TUT,
Not knowing where GTA is, I don't know what the passenger side is.
PS pump on my car is on the left side of engine. Follow the fatter hose from the PS reservoir...it goes to the pump.
Fluid 'should' be at the second fine line on the stick, as mentioned.
If it's not clear pink, then start turkey basting with appropriate fluid, which is Dex III for my car.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-23-2011, 02:09 PM   #6
My Ride: Lexus
That noise can be anything with a bearing. And engines have tons of stuff with bearings that spin. Are you up to date on your tensioner pulleys? Hows your alternator and a/c compressor?
Don't automatically associate the noise with your power steering pump because it gets louder as you turn the wheel. Realize that when you turn your steering wheel, your engine RPMs will fluctuate a bit to compensate for the pump being used. If I had to guess, I'd guess your a/c compressor bearings are just noisy.
Old 09-23-2011, 02:15 PM   #7
Tutankhamon
My Ride: 2017 M2
Originally Posted by D. View Post
TUT,
Toronto, Canada so same side as you. I'll top up the fluid as it needs to be topped up anyways. Thanks for the input.
Pullies should be fine as they were replaced not too long ago. A/C compressor has never been touched to be honest. If the bearings are noisy for the A/C, is this something that can be replaced independently or do I need an entire new A/C unit?
I'm basically just trying to narrow down the possible culprits, it definitely sounds like passenger side though.
Old 10-05-2011, 03:02 PM   #8
Tutankhamon
My Ride: 2017 M2
I think I may have found the culprit and I may have lucked out, might be an easy fix.
It turns out that the vibration seems to be coming from the secondary air pump. More specifically, it seems like the air pump casing itself is vibrating up against the metal bracket holding it.
Has anybody ever experienced something like this before? The air pump seems to just freely rest in the metal bracket with rubber cushions. Did I lose a clip or something that secures it or do they all just freely sit there?
Old 10-05-2011, 03:28 PM   #9
dmax
dmax's Avatar
My doesn't wobble...take a photo of what you have and I'll have a look at mine and compare. Also, realoem is your friend, you know!
I'm sure you can tighten up the bracket...I'll check later...but also, if by chance the hose feels squishy and thus might have plugged the inlet to valve, I could see how the pump might cavitate, even though it's only air, that might add to the wobble...a crazy theory! If hose is soft, check that inlet for gunk.
HTH
Mangofy your E46!
Old 10-17-2011, 11:26 AM   #10
Tutankhamon
My Ride: 2017 M2
Thanks dmax for the help and the offer. I'll post a pic when I get the chance. From doing a bit more research, it seems that the airpump shouldn't be able to move as much as it does in my engine bay. I can literally lift the entire thing up. Looks like the mounts are made of poor quality and are just broken. I feel like I should just zip tie everything back down but that might not look right.
