///M3 Forum
Old 09-16-2007, 02:02 AM   #1
supra123
Banned
My Ride: 2002 BMW M3
How To Launch Properly? (6 SPEED MANUAL)
I was wondering what is the proper way to launch a 6 speed manual e46 m3?
Including rpm's, Shifting techniques, Clutch release, etc. Also was wondering if the launch control feature can be used with the 6 speed manual gearbox?
Thank You
supra123 is offline   Reply With Quote
Old 09-16-2007, 04:07 AM   #2
604dude
My Ride: 2003 M3
There are no computer controlled features on a manual device.... Just keep the traction control off.
Here's what i do and im not a professional.
keeps the revs at 3500-4000 and let out the clutch smoothly but not slow enough to slip it all day. If your tires are spinning you didnt let it out smooth and slow enough. If the car slowly leaves the line and your slipping your clutch too much, you are releasing the clutch pedal too slow. If your tires are begging for mercy but still holding a lot of grip on the road (80% or more), your doing good. The instant the clutch is fully engaged and the tires are not spinning, hold the pedal full down.
To get a real good launch, you will have to USE that clutch disc. Your starting off the line with the engine at full torque, and trying not to spin the tires, so the clutch has to do all the work in transmitting the energy.
For shifting, it just takes practise. From clutch in, off gas, shift gear, clutch out, on gas, it shouldn't take more than 0.5 of a second (thats a pure guess, i dont have a millisecond stop watch. but it should be one fast half second motion).
604dude is offline   Reply With Quote
Old 09-16-2007, 10:20 AM   #3
BartenderPlease
My Ride: 328i Sport
Send a message via AIM to BartenderPlease
^ Hell, it even feels faster than 1/2 second haha.
Gottalovethexi: thx for the old p-chopped sig
| BBS CH | FK coils | RE Bushings/Mounts | K&N Intake | ZHP box/no resonators |
| 330i brakes | FX-R + Orion V4 | Full Exterior LED kit | JL Audio in trunk |
BartenderPlease is offline   Reply With Quote
Old 09-16-2007, 10:45 AM   #4
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
if you practice...you'll know when you have a good launch...you wont sit there and spin tires but they will spin a tad.
bimmer07 is offline   Reply With Quote
Old 09-16-2007, 01:48 PM   #5
supra123
Banned
Thanks guys. Any more advice? Any 1 got any videos? Thanks
Old 02-26-2013, 07:04 PM   #6
jaydee973
My Ride: 2003 BMW //M3
At what gear to you guys launch from? 2nd?
jaydee973 is offline   Reply With Quote
Old 02-26-2013, 07:11 PM   #7
danwilz
My Ride: E46 M3 Vert 2012 X5
1st 1st 1st
danwilz is offline   Reply With Quote
Old 02-26-2013, 07:14 PM   #8
diM3tri
My Ride: 330ci + stg2 Scoobie
7th
more pedals then doors.
diM3tri is offline   Reply With Quote
Old 02-26-2013, 07:17 PM   #9
///BeckeR
My Ride: 03 TiAg 330i ZHP
False. Launch control on a manual e46 m3 has been done.
There's some software coding trick that can be done. I read it in a post by Evolve tuning last night, ill have to find that thread again
03 TiAg 330i ZHP
///BeckeR is offline   Reply With Quote
Old 02-27-2013, 11:02 AM   #10
DSilk56
My Ride: M-3 Convertible
Launch control can't really work on a manual transmission, because clutch engagement isn't controlled by the car's computer. It's controlled by the master control unit in the driver's head. You will get very good acceleration times by launching at 3,500 rpm (which is 1,200 rpm shy of peak torque), but you will be replacing clutch plates with relatively high frequency. Remember that at a 3,500 rpm launch, if your tires aren't burning, your clutch plates are slipping.
DSilk56 is offline   Reply With Quote
Old 02-27-2013, 11:26 AM   #11
///BeckeR
By launch control I mean that you can code the computer to limit the rpms while the clutch is down (like how you can't rev past 6k in neutral). Set it to 3500 rpms so when the pedal is to the floor the motor is at 3500 rpms, release the clutch and you have launch control
03 TiAg 330i ZHP
Old 02-27-2013, 11:40 AM   #12
e46jki44
My Ride: e46 325i sedan
I believe that is called 2-step.
Sent from my SPH-D710 using Bimmer App
e46jki44 is offline   Reply With Quote
Old 02-27-2013, 11:54 AM   #13
SurreyF1
My Ride: BMW
OP is getting ready for red light races
SurreyF1 is offline   Reply With Quote
Old 02-27-2013, 11:08 PM   #14
Slyde
My Ride: 2001 M3 TiAg
That sounds like it will introduce problems. Presumably you could not rev match on a downshift if RPMs are maxed to 3500 when in neutral (clutch depressed or mid-shift through neutral to lower gear)? That sounds like a recipe to lose the rear if downshifting in a corner... might you even slow yourself when up-shifting from 8000 to next gear? I think 3500 in third, for instance, is slower than second near red-line.
Call it "launch control", but it sounds like tard-proofing.
Slyde is offline   Reply With Quote
Old 02-28-2013, 09:47 AM   #15
///BeckeR
Call it whatever you want but this is something Evolve said themselves
03 TiAg 330i ZHP
