///M3 Forum
Old 02-24-2013, 07:44 AM   #1
duramax
My Ride: 2002 BMW M3
car has not been driven
Hey guys after almost 1.5-2 years the car is ready for the road. Some might ask why it sat so long, new parts, working away blah, blah... So as it heads to the paint booth in a few days there is one thing left to do which I need help with OIL, I do use the TWS10W60. when its drained should I put in a thinner oil to soak the seals again before putting 10w60 in? I have thought about putting in some Pennzoil 5w30 and run it up and down a few times has a awesome cleaning agent and would soak the seals, what do you guys think?
duramax is offline   Reply With Quote
Old 02-25-2013, 02:14 AM   #2
E46MBM
My Ride: Fly B Laguna Seca M3
uhhh noo
E46MBM is offline   Reply With Quote
Old 02-25-2013, 02:16 AM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Soak the seals? No. Not at all. I'm not even really sure that makes sense. They don't do this in brand new engines that are bone dry.
Run the regular oil and enjoy.
Old 02-25-2013, 02:49 PM   #4
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Use the normally recommended weight of oil. You can have your pick between Castrol, Total, Eneos, etc. - just as long as the rating/specs are the same you are all good sir.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-26-2013, 10:02 AM   #5
DSilk56
My Ride: M-3 Convertible
I would remove the spark plugs and put a few drops of oil in each cylinder before cranking it over. Use the TWS.
DSilk56 is offline   Reply With Quote
Old 02-26-2013, 11:42 AM   #6
shell_guy
My Ride: 2002 M3
New seals in new engines are all wiped with motor oil or assembly lube during the assembly process.
shell_guy is offline   Reply With Quote
Old 02-27-2013, 08:51 PM   #7
duramax
Not driven
well to be honest I actually drained the old tws and added some Pennzoil high mileage, ran it for half an hour at idle, then drove it up and down the road for half an hour parked it and checked for leaks, none then drove it longer, no leaks all is good and drained the oil and back in with the tws, I don't know if what I did makes sense but I'm happy. thanks for all the comments
Old 02-27-2013, 08:53 PM   #8
duramax
not driven
I forgot to say that also when driving I didn't bring the rpm past 4k.
Old 02-27-2013, 09:02 PM   #9
choxor
My Ride: JDM
Whatever works. If it gives you peace of mind to do that routine then it's well worth it. Grats on getting it back on the road.
Old 02-27-2013, 09:08 PM   #10
duramax
not driven
thank you, it feels really good to sit behind the wheel again.
