Right Front Axle Boot Replacement - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 10-03-2011, 06:51 AM   #1
snp1973
My Ride: 2002 325xi
Mine (outer) is leaking grease; the indy shop I use for most things wants $800.00 which seems out of line.
I was considering just getting the whole axle from FCP and installing myself. I have looked over a few DIY's - is it hard to get the axle out of the transmission end?
snp1973 is offline   Reply With Quote
Old 10-03-2011, 08:27 AM   #2
TR4G-
My Ride: '01 325xi, '90 325iC
Hey there, I just recently did the same thing. Here are my conclusions: it seems that more than a few people have attempted this repair and run into serious problems either removing the inner joint from the diff or reinserting it back into the diff.
What I did was simple get a new inner boot kit as well so you can separate the inner joint instead of completely removing it. I wrote a nice DIY with pics. Careful though, in order to do it properly you must disassemble the outer joint 100% to clean out the contaminated grease.
Here is a link to the post! Check it out to see what is entailed in this fix: http://www.e46fanatics.com/forum/sho...31&postcount=2
All in all, i would have gone with the new axel route but I did not want to deal with axel pullers and such, plus my joints were fine so I just repacked em. Still going strong.
If you are not scared about removing the axel from the diff then by all means go with the axel replacement. Much less work!!!
TR4G- is online now   Reply With Quote
Old 10-03-2011, 08:29 AM   #3
TR4G-
Whoops.... Clicked quote instead of edit
Old 10-03-2011, 11:32 AM   #4
BLAU III
My Ride: eat's cars.
napa sells oem reman axles for under 100 after the core charge. far easier then repacking. just make sure you have air tools and a big fvcking hammer.
Originally Posted by CollinsE90 View Post
I would battle a pack of wolverines in a porta potty with my hand tied behind my back, yielding nothing but a shake weight taped to my forehead, just to hear her fart over a walkie talkie.
BLAU III is offline   Reply With Quote
Old 10-09-2011, 07:26 AM   #5
snp1973
My Ride: 2002 325xi
I bought a new axle from FCP Groton. Very happy! Left front axle boot is now torn, so will probably replace that axle shortly.
Old 10-09-2011, 03:16 PM   #6
JDUTHIE
My Ride: 2003 325xi
+1 on the air tools, and make sure it goes higher than 88ft Lbs of torque those axle nuts are on there with some serious force..at least mine were, i ended up using a 4 ft pipe and a breaker bar to get those free ahahahah
JDUTHIE is offline   Reply With Quote
Old 10-09-2011, 03:40 PM   #7
john311tran
My Ride: awd + 5 doors
nice DIY mang.
but in all honesty it's way easier and far less time consuming to just replace the whole damn axle. time is money. i made the mistake of doing the boots only, not only did i waste time i lose my car for a week since i was shipped the wrong inner boot :-(
john
john311tran is offline   Reply With Quote
Old 10-10-2011, 04:16 PM   #8
Rickna
My Ride: '01 330xi - '09 IS-F
I was disappointed in the axle I got from FCP. It caused vibration from day 1. You're much better off with A1-Cadone.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
