Go Back   E46Fanatics > Everything Else > Polls & Surveys - Please Participate!
This forum contains "official" polls and surveys
View Poll Results: Vote: Do you believe in preventative maintenance?
Preventative maintenance is key to good vehicle health 322 83.20%
Preventative maintenance is a waste of money. If it ain't broken, don't fix it! 65 16.80%
Voters: 387. You may not vote on this poll
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 2.75 average. Display Modes
Old 01-13-2013, 11:15 AM   #141
RayPooley
My Ride: 320i SE Coupe
Originally Posted by ryannel2003 View Post
I'm all for preventative maintenance. The last thing I need is my car stranding me and not being able to call somebody or have to wait for a tow. I'd rather get it done and then my worries can be avoided.
For the record, replaced my crankshaft sensor along with my camshaft sensors when my intake camshaft sensor was playing up. Sort of pre-emptive strike as it were. Nine months later got a crankshaft sensor fault. Had to replace it again. Begs the question. Did I prevent a problem by replacing the original working crankshaft sensor or create one? The truth is that there is no such thing as preventative maintenance. Might reduce the risk a bit but its not necessarily going to protect you from failure.
Old 01-13-2013, 11:15 AM   #142
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
i do a bit of both, preventive for the bigger things, but say something like the clutch, i know one day its going to be so worn its just gonna slip all day, but its not going to really kill anything, so ill leave that in for know, then when i drop the transmission to replace that, ill preventatively replace other things too. engine belts? all the time, id rather not risk it. expansion tank, replaced about a 30000 mi ago, shouldnt have to worry about that for a little bit.. windshield washer pump? no thanks, ill wait for that.
you catch my drift..
jmillsner is offline   Reply With Quote
Old 01-13-2013, 04:57 PM   #143
WheyArea
My Ride: '03 TiAg ///M3
Depends on the part and likelihood of failure. Cheap things like oil, air filters, sparks I do quicker than recommended. Other things like tranny/diff fluid, fuel filter, cooling system and pulleys at 100k. The only other thing I find needed is the vanos. Outside of that I think everything else is overboard.
/// Dinan ECU /// Brembo BBK /// BBS LM 19" /// Bilstein PSS10
/// Eisenmann Exhaust /// Supersprint Mid Pip /// AC Schnitzer Spoiler
/// Hamann Lip /// AC Schnitzer CF Diffuser /// K&N CAI /// Valentine 1
Coming Soon...... OEM SSK, CSL bootlid
WheyArea is offline   Reply With Quote
Old 01-13-2013, 05:43 PM   #144
TerraPhantm
My Ride: M3 & ZHP
Absolutely prevent? No. But statistically the less time something has been in service, the less likely it is to suffer a failure. That still counts as preventative in my book.
As I mentioned earlier in this thread -- anything that can cause a catastrophic failure (cause much more expensive damage) and/or leave me stranded, I change preventively. Anything else I'll let fail before I replace.
Though I should mention with items such as shocks, they may not fail even if their performance has degraded significantly. Part of why I bought this car is for performance, so I'll replace such items before complete failure as well.
TerraPhantm is online now   Reply With Quote
Old 01-13-2013, 11:06 PM   #145
My Ride: Lexus
^ Well put.
For example, my DISA. Still working fine. No point in replacing it early. It won't cause a catastrophic failure.
Cooling system on the other hand is the one thing that is NOT optional.
It's all about reducing the chances of a breakdown or overheat and keeping the car performing optimally. There's no use in owning a sloppy-handling and driving BMW.
Old 01-14-2013, 08:16 AM   #146
lsteg
My Ride: 2001 330ci
If nothing else I just practice PM for my own peace of mind. I sometimes replace working parts just because they are prone to failures (fuel pump, exp tank, alternator) and I don't want to be stranded and stuck with a huge towing bill. Another plus side to PM is that I fix the parts when it's convenient for me and I don't have to rush ship parts and scramble to get my car repaired. I can take my time and make the repairs when I want to. We have all of this collective knowledge about our vehicles and items that are failure prone so why would I not take every action to avoid them?
lsteg is offline   Reply With Quote
Old 01-14-2013, 06:35 PM   #147
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
160k miles on original fuel pump and water pump lol
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 01-14-2013, 07:15 PM   #148
Toad21
My Ride: 00' 328CI
There are 48 morons who troll this forum.
Toad21 is offline   Reply With Quote
Old 01-14-2013, 07:49 PM   #149
Stinger9
My Ride: '04 330Ci
You can get quite far when your alternator fails. When I noticed my alternator light was on I got another 25 miles at least riding on my battery until it got too low. Enough to get to service or home in most cases.
Old 01-14-2013, 07:55 PM   #150
DHK
My Ride: 2002 BMW 325Ci
This needs and in between option. Some things on these cars need to be replaced regularly and if you know when the last time they were replaced is, and you know how much time/miles have passed then yea go ahead and replace em before they show symptoms.
I do however see a lot of people that replace parts all over the place for no real reason and Im not sure that's really necessary. I wouldn't say Im against it persay, but I dont do it on my car.
Personally I have just found a mechanic I trust, I take him the car every 5 months or so, he gives me a quote on what he thinks the car needs usually 200-500 dollars. I do research to make sure the quote makes sense.
Then I select what I want done and he does it.
DHK is offline   Reply With Quote
Old 01-14-2013, 08:14 PM   #151
Stinger9
My Ride: '04 330Ci
Kind of a guideline as to what to replace to avoid being stranded.
I think I see your mission statement as self-defined!
Let me know if you need someone to do a rough edit?
Old 01-15-2013, 05:14 AM   #152
todd92
My Ride: 05 330i ZHP
Originally Posted by Toad21 View Post
There are 219 morons who troll this forum.
FTFY
todd92 is offline   Reply With Quote
Old 01-15-2013, 05:25 AM   #153
RayPooley
Hey! Be nice!
Old 01-17-2013, 09:50 AM   #154
DonaldE
My Ride: 2002 330i
I fix all my **** BEFORE it breaks
DonaldE is offline   Reply With Quote
Old 01-17-2013, 11:47 AM   #155
My Ride: Lexus
Originally Posted by wildirish317 View Post
Here's a "must read" for all of you, an oldie but goodie:
http://www.amazon.com/Zen-Art-Motorc...eywords=pirsig
"The real cycle you're working on is a cycle called 'yourself.'"
I just downloaded this on Google Play for $7.59. Would like a good read. Thanks for the recommendation!
Old 01-17-2013, 12:02 PM   #156
My Ride: Lexus
^ Let me know what you think. It's not a fast read.
Yeah apparently its 490 pages or something
Old 01-17-2013, 12:54 PM   #157
golf_234
My Ride: E46, E90
God owning my e46 was expensive.
golf_234 is offline   Reply With Quote
Old 01-17-2013, 01:19 PM   #158
My Ride: Lexus
tends to happen after 10 years
Old 01-17-2013, 01:30 PM   #159
Stinger9
My Ride: '04 330Ci
Compared to paying the cost of a new car?
Yet drives and looks like a new car if you take care of it.
Old 01-17-2013, 02:04 PM   #160
My Ride: Lexus
+1 I could not be happier with the reliability or performance of my car! And 0 car payments!!
