E46 Xi Forum
Old 10-08-2011, 06:53 PM   #1
Nick_f
My Ride: 2002 BMW 325xi
2002 325xi front passenger axel help
Hey guys.
I have a bit of a problem on my hands. I'm changing my axel because they have been compromised.
I followed the video online on how to remove the axel. It worked great up until the point when i had to remove the axel. I can't seem to get it to budge out of the transmission. I barely get enough room to fit a flat head screw driver in between, but can't get enough leverage to pry it. tried hitting it with a pry bar and hammer, but no luck either.
Anyone else run into this problem? Any words of wisdom/advise from the BMW gurus?
Nick
Nick_f is offline   Reply With Quote
Old 10-09-2011, 11:26 AM   #2
Nick_f
I got it off, success!
Chisel and a mini sledge.
But the sound is still there. it is coming from the front passenger side. Only on light to medium acceleration, it will make a clicking/binding sound, (rumble strip sound)
help
Old 10-09-2011, 12:29 PM   #3
Rickna
My Ride: '01 330xi - '09 IS-F
Did you bother to check the wheel bearings before you you went to all that trouble?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-09-2011, 02:54 PM   #4
BLAU III
My Ride: eat's cars.
make sure you have your new axle all the way in. i didnt get my drivers side in all the way the first time. drove a couple of days and had to do it all over again! did you replace your seals?
+1 on the wheel bearings
Originally Posted by CollinsE90 View Post
I would battle a pack of wolverines in a porta potty with my hand tied behind my back, yielding nothing but a shake weight taped to my forehead, just to hear her fart over a walkie talkie.
BLAU III is offline   Reply With Quote
Old 10-09-2011, 03:37 PM   #5
john311tran
My Ride: awd + 5 doors
fyi,
you don't need to take the strut off the knuckle.. save yourself the step and just push the axle off of the knuckle.
john
john311tran is offline   Reply With Quote
Old 10-09-2011, 08:38 PM   #6
Nick_f
wheel bearing is good, no play. This sound will only happen when I'm accelerating from a complete stop, usually when the transmission is about to shift into second.
it honestly sounds/feels like i'm driving over rumble strips when accelerating from a dead stop (traffic light, stop sign, etx) for no more than 2-3 seconds
The sound/feeling never returns during driving.
Old 10-10-2011, 10:55 AM   #7
radaddict
My Ride: 325Xi
Hmmmm. Maybe I missed something in your original post, but you replaced the right side axel. Perhaps the problem is with the left side?
radaddict is offline   Reply With Quote
Old 10-10-2011, 11:23 AM   #8
Nick_f
I'm leaning towards replacing the left as well. The right was actually shot, plus boot failure.
I usually tend to find the answer using search, but I'm stumped with this.
Anyway to tell if the left axel is shot without removing it?
Tonight I'm going to switch the front and rear diff fluid anyways (part of my maintenance, not because of the sound) hopefully that helps.
Old 10-10-2011, 11:25 AM   #9
Rickna
Have you changed the TC or diff fluids. It does make a difference. Hope it's not the tranny.
2001 BMW 330xi
2009 Lexus IS-F
Old 10-10-2011, 11:29 AM   #10
Nick_f
Diff fluids will be changed tonight.
in the next week, I will change the transmission fluid and transfer case with new filter and gasket.
