Old 08-10-2012, 08:39 AM   #21
budysr
My Ride: 330ci
I had this exact problem shortly after I bought my 2003 330ci and it turned out to be the MAF that was causing the 3 lights. Previous owner had replaced the MAF and used an aftermarket part. Replaced with a new OEM MAF and also had vac. leaks repaired. Problem solved
budysr is offline   Reply With Quote
Old 08-10-2012, 06:37 PM   #22
2003silver330i
My Ride: 03 BMW 330i
I have the same issue today after filling up with gas. All three of these lights popped on along with my low coolant light.
2003silver330i is offline   Reply With Quote
Old 10-06-2012, 03:00 AM   #23
sick204
My Ride: BMW 323i 2000
im having a similar issue with mine now .. but its the eml tc and check engine .. but when i shut it off and restart it it goes all off except the check engine it takes a lil longer to go away but it eventually leaves.. this is the second time its happen n the first time it was cuz i had a leakage in my radiator and needed to change my rack and pinion but now i have no clue why its doing it again after long months of not doing so. so hope you find an answer!
sick204 is offline   Reply With Quote
Old 10-07-2012, 12:33 PM   #24
PRDesignsTony
My Ride: 02 330ci
after I changed the intake lower boot it never happened to me again.
Stretch + poke = All show, no go!!!
PRDesignsTony is offline   Reply With Quote
Old 04-01-2013, 12:20 PM   #25
DrkSide_RbL
My Ride: 99' 328i Sport Sedan
Send a message via AIM to DrkSide_RbL
Originally Posted by SweTurbo View Post
Jesus all this guessing...
EML light comes on when the DME cant control the engine propery, you said your intakr boot was broken so my thoughts are that your TB is seized(a motor tries to move it , if it cant then the wire will move it and you will have an EML light)
As the throttle is part of the xSC system that light (and brake light) will come on aswell.
That the light isnt permanent is usually a sign of this happening.
This would be the best answer out of everyone who replied on here. EML is usually related to the throttle body. I would try these steps:
-Clean throttle body flaps inside and out with throttle body cleaner. Removing it is best way to clean it.
-Clean Idle Control Valve (IDC)
-Make sure there are no rips in boots. If so replace.
-Last option is to change Throttle body or MAF if the problem is still not solved. The potentiometers imbedded in the TB is most likely not working properly.
DrkSide_RbL is offline   Reply With Quote
