Old 10-09-2011, 09:16 PM   #1
rcdhogan
My Ride: 2004 330 CI
Oil light malfunction?
A few days ago I heard a tapping from the engine, sounded like lifter tap. I went to check the oil and it was somehow 2.5 quarts low! I refilled the oil and the noise is gone and the car seems to be running much more smoothly.
The oil light has never come on over the past 6 months since my last oil change. It seems as if the oil has been leaking from the bottom of the filter housing. I have replaced the o-ring there and seems like the leak is fixed.
Question, is the sensor that is responsible for turning the oil indicator light on malfunctioning? If so, where is it located and how can it be tested?
rcdhogan is offline   Reply With Quote
Old 10-09-2011, 09:17 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's possible that it has failed completely, but it should at least throw some oil light on the dash.
Old 10-09-2011, 09:20 PM   #3
rcdhogan
The oil light does come on on the dash when I start the car, but it has never come on indicating low oil.
Old 10-10-2011, 01:19 AM   #4
Tangent_
My Ride: '01 330i, '11 Z435i
If the oil light comes on for 10 seconds around 15 seconds after you start the car, that's an indication the sensor is bad.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 10-10-2011, 05:43 AM   #5
jmorgan.music
My Ride: 2000 323i
i have the same problem, when i start my car up it goes yellow then turns off 15 seconds after. this means the sensor is faulty, my mate diagnosed my electrics and it came up as faulty oil sensor. it is located at the bottom for the sump pan.
jmorgan.music is offline   Reply With Quote
Old 10-10-2011, 06:07 AM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You'd think. As stated, OP, the legend here is that it will trigger a malfunction. Mine had been coming on like Tangent said.
If you were this low and the oil light didn't come on, then it would be the first such failure I recall reading about.
No problem, though, as your solution is pretty easy. Check your oil!
You were 2.5 qts. low? That's really bad for the car. But that's great for you, because otherwise I wouldn't have known you're not checking your car nearly enough.
Think of it as a huge lawnmower. You'd check the gas and oil before starting it, wouldn't you?
(Edited--removed my diatribe about finding leak. But, who did the last oil change? Jiffy lube? That o-ring should be put on properly--mine hasn't leaked and I do my oil myself!)
You need to open your hood way more often.
Take care of your car...check all your fluids, belts, filters...and don't be frightened to open the hood, look, smell, feel, hear, touch the engine and listen to what it's telling you.
Face Munich, read pages 1-25 of Owner's Manual, pour 1 oz. of oil on your hair and leave it like that for a day, and you'll be fine!
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 10-10-2011, 06:12 AM   #7
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
When sensor's fail they tend to throw some sort of code or light.
OP you should be able to test the sensor. If you have a bentley manual you should be able to find the resistance specifications for the sensor. Break out the multimeter and test it
Drew@Swift Motorworks is offline   Reply With Quote
Old 10-10-2011, 10:34 AM   #8
Brinkley
My Ride: 99 328i, 07 z4 3.0
I've thought that basically that the yellow light coming on at start up is the car telling you that it has no idea your of your oil level.
Brinkley is offline   Reply With Quote
Old 10-10-2011, 11:12 AM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
The O-ring at the bottom of the housing will not fix the leak you observed. You need to replace the oil filter housing gasket, Item 8 in the attached diagram -- this diagram is for my car, your car may be different, and you have to look it up...
http://www.realoem.com/bmw/showparts...88&hg=11&fg=30
THE YELLOW OIL LIGHT
The light comes on before the car is started to tell you if the light works, and comes on after the engine is stopped to tell you the oil is low. The error in the system is that it comes on for a few seconds after the car is started, then goes out again. The Owner's Manual does not give a very good description of the light, except that when RED, the situation is serious enough that the car whould be stopped immediately.
oil, tapping
