Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
I have a 2001 330ci with manual trans and 98k miles. Today while i was waiting at the stop light i kept depressing my clutch pedal for no reason. While i was doing this i noticed that everytime i let off the pedal my idle would go from 600rpm to about 700-800rpm. This happens everytime I let go of the clutch pedal I just never noticed it before. I didnt have my A/C on either. The car idles fine and never has any kind of surging problems other than what i think is the vanos seals symptoms. Does anyone have any idea of what can be causing this? I cant figure out how the clutch pedal would be affecting engine idle.
#2 |
Possibly in need of a reprogram, also check your disa valve.
#3 |
That's normal.
That's just the icv and VANOS doing it's job.
![]() *F-BOMBS IN SIGS*Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | FR strut bars | Self tuned 027 chip | KoseiK1's on R888's | +crazy OCD things |
#4 |
i replaced my DISA about 3k miles ago.
does the dealer reprogram? if it indeed is normal then thank goodness! thank you for the quick response |
#5 |
It's 100% normal. When your idling and stopped the icv closes further and he VANOS is tuned for lower emissions and loser gas consumption. When you press inthe clutch; switches are triggered letting the car know you are about to take of hence bumping up the revs and changing VANOS timing for easier take of and improved torque.
#6 |
i just got schooled. lol thanks a lot!
| Tags |
| clutch pedal, engine surging, idle, rough idle |
