E46 Xi Forum
Old 10-10-2011, 11:46 PM   #1
rosshc44
My Ride: 2004 325xi
Rough Idle In Cold
Hey,
This is my first post on these forums, but i have been helped countless times by many of these threads.
I have a 2004 325xi with 185000 kilometers on it.
When starting the car from a cold start the car has a rough and noisy idle and the rpm gage sits at the 1k. As the car warms up, the rpms go down to where they normally idle (600) and the cars idle becomes smooth and less noisy.This is especially true when starting the car after it has been outside overnight in chilly fall evenings and not in the garage.
I have no engine light codes and recently i took it to the shop who replaced my secondary air pump, spark-plugs and drive belt after which the problem seemed to have gone away. Recently with the colder nights, it has started doing it again in the morning.
Any help would be greatly appreciated.
Cheers,
RHC
rosshc44 is offline   Reply With Quote
Old 10-10-2011, 11:50 PM   #2
CSL323
My Ride: 330Ci
Exactly like mine...
The 1K RPMS on cold is fine. The engine runs fine here too...
I don't get any bobbing on my gauge, it's very steady, but when it's being started for the first time on a cold day, I get a noisy idle like the one you describe...
I'm in need of a new belt and sparkies myself.
Interested in a response.
CSL323 is offline   Reply With Quote
Old 10-11-2011, 10:21 AM   #3
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
vanos seals
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 10-11-2011, 10:32 AM   #4
Kubica
My Ride: 2003 325xi
Check the DISA first.
Old 10-11-2011, 12:54 PM   #5
rosshc44
My Ride: 2004 325xi
I thought i might have been the vanos seals but the shop says it would throw an engine code if it was. If it is the vanos, is it absolutely necessary to fix or is it something that can be lived with for now?
What is the DISA?
Old 10-11-2011, 02:05 PM   #6
jasonbimmer
My Ride: 2001 BMW 330xi
noisy cold engine is nothing uncommon on an old car. I would suggest checking the oil level and use proper oil weight. however, you need to find where the noise is coming from.
vanos seals even very worn wont give a code cuz I replaced mine and I know it.
you can live with worn vanos but your power and mpg will suffer besides it very easy to do when you plan to replace the valve cover gasket.
DISA is the little box that contains a flap near the top of the engine on the driver side.
when its worn, it will make a grinding sound. you can test it by unplugging the plug when engine is running and observe the sound change.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
325xi, high rpms, idle, noisy, rough idle
