Old 10-11-2011, 12:50 PM   #1
Scott4uf21
My Ride: 2001 325Ci
Question Loss of electrical things
As I was driving home today, I got out of my 2001 325Ci and when I turned the lights off and took the key out of the ignition the car was still beeping as if the lights were on. When I drove it later I realized that some of the lighting on my dash was not working. The background was fine but the blinkers, fog lights, brights, did not show up. Also I checked my side view mirror and it was stuck in the down position from being in reverse. I tried to manually adjust the mirror, it came up but is stuck in one position and will not move now.
I'm not crazy familiar with these cars, I've changed the brakes myself and did a good job, and can do basic things, I just wondering, besides checking the fuses is there anything else that could have caused these problems? Or has anyone else experienced the same thing?
Only changes i've made was installing HIDs that have worked fine and still work with this issue.
Any help is appreciated
Scott4uf21 is offline   Reply With Quote
Old 10-11-2011, 01:08 PM   #2
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Try disconnecting the battery for 10 minutes then reconnect.
BMW-North is offline   Reply With Quote
Old 10-11-2011, 01:17 PM   #3
Tremorz
My Ride: 01 325ci
check if your sunroof works, and check if your radio works, some of the issues you stated seem like its an kbus problem possibly?
Tremorz is offline   Reply With Quote
Old 10-11-2011, 01:20 PM   #4
Scott4uf21
My Ride: 2001 325Ci
Radio works, ill do the battery disconnection and get back to you guys. Thanks so far. Ill check the sun roof too
Sent from my SAMSUNG-SGH-I997 using Bimmer
Old 10-11-2011, 01:26 PM   #5
Scott4uf21
My Ride: 2001 325Ci
Sunroof works....AC does not (just noticed)
Old 10-11-2011, 02:10 PM   #6
jgold47
My Ride: 2004 X5 3.0
k-bus error. Search for K-Bus and you will find a pretty useful thread.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 10-11-2011, 06:14 PM   #7
Scott4uf21
My Ride: 2001 325Ci
So, I drive to school, still no AC, mirror stuck, limited cluster lights and when I drive home everything worked fine. Def a electrical issue. I hope it stays working.
Old 10-11-2011, 06:26 PM   #8
Jmanscotch
My Ride: makes my pants tight
Just to throw out another option to look into (but probably not your issue); when the batteries go on these, they like to haunt a few electrical functions before they kick the bucket 100%. So, easy/free check of battery to make sure it's not in need of replacement.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
beeping, cluster, dash, electrical, mirror
