Old 10-11-2011, 10:05 PM   #1
YoungFanatic
My Ride: 2002 BMW 325ci
Window Problem
Hey guys.
Im pretty new here if you cant tell. I did search the forums before posting this and I could not find anything similar to my problem, with that said. My car has worked perfectly fine and all of the mechanics are fine with it. But for whatever reason my driver side window is having problems. I drive a 2002 325ci (i will try to post pictures of the problem)
The problem: I am assuming that everyone's car does this thing where after you close the door the window moves up just a little bit into the trim/frame around the top of the door. For whatever reason it seems that when i open my door the window moves up prematurely. so now suddenly my window is the 1cm or whatever to far up. so when i attempt to close the door it smacks against the trim and will stop there. the door does fully close its just the window is slightly bent up over the outside of the trim which allows air into the car and probably is hurtful to the window.
I have noticed that if i (from the outside) push the window inward it will snap back into place and be perfectly fine. or if i roll down the window then roll it back up it goes into place just fine. the door also opens fine and does not feel to get stuck by the trim/glass.
Thanks in advance for any help you guys can offer I truly cannot seem to find any reason for this happening but I could easily be over looking something. If you need anymore information just let me know if it will help you troubleshoot.
YoungFanatic is offline   Reply With Quote
Old 10-11-2011, 10:55 PM   #2
E46330iguy
My Ride: Supercharged 330i
Originally Posted by BMW-North View Post
You need to adjust the vertical travel screws that you will get to from the bottom underneath of the door. Roll the window all the way down, remove the two black rubber grommets (one at front one at back) and adjust the torx screw in each. You turn anti-clockwise to lower the vertical travel. You may have to try a few times till you get it right.
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 10-11-2011, 11:11 PM   #3
RAGEthreads
My Ride: 2000 328i
Speaking of windows...my passenger window is on its last life...I do not feel like going to BMW to fix thi$ problem...does anyone have instructions how to replace the regulator ..if thats the problem..
I know I'll have to carefully pop off the interior panel with all of the plastic clips hidden around, then there is a bolt that holds the window pane near the regulator I believe...ANY ADVICE please respond..thanks
never settle for aveRAGE
RAGEthreads is offline   Reply With Quote
Old 10-12-2011, 06:50 AM   #4
YoungFanatic
Thank you BMW-North I will try this later when the rain lets up here and i have a little bit of free time. Hopefully it works for me.
Old 10-17-2011, 07:10 AM   #5
Liam.attwood
My Ride: 3 series coupe '01'
i have a window problem, if i open my driver door, (with the window up) i can move the window about an inch width ways..
so what is happening is when i drive at around 60+ mph, and open the window.. when i come to close it, the window goes fully up, but stops on the metal trim, instead of going up into its hole (along side the trim)... this is causing a whistle noise, the only time it works is when im going at slow speeds.. obviously something to do with the pressure inside the car pushing the glass out at high speeds..
would anyone know what needs replacing?
clips or a runner maybe?
Liam.attwood is offline   Reply With Quote
