Old 10-12-2011, 10:58 PM   #1
Zell
Zell's Avatar
My Ride: so turbo wow
FCABs - Aftermarket or Genuine BMW?
Yes, I did
I am going to do my front control arm bushings soon, and I always like to use Genuine BMW parts; however, I am not interested in replacing these again in 50,000 miles.
The OE bushings are fluid-filled, reducing noise, vibration and harshness. This is an important characteristic to me, as I like having a nice ride. Fluid-filled bushings do an excellent job of this, but at the expense of longevity.
The two bushings I am considering:
Genuine BMW:
Pros: 2-year warranty
Same noise, vibration and harshness as stock
Guaranteed fit
Cons: Don't last as long
Expensive
Meyle HD:
Pros: Last longer
(I think) 2-year warranty
A little bit cheaper
Cons:
I am one of those particular people that notice things that lots of people don't.
Will I be noticeably sacrificing ride quality/harshness compared to OE?
They claim "no," but lots of aftermarket manufacturers claim a lot of things, so I am a bit skeptical.
Old 10-13-2011, 02:16 AM   #2
swordsman11868
My Ride: 2003 325i
IMHO if everything else is stock the stiffer F cabs won't give you a noticeably harsh ride.
I used poly urethane for a while before I lowered my ride on Bilsteins and I couldn't notice a difference. Once lowered the ride is stiff but not too bad.
One caveat - I'm still on stock 16" rims. Not sure if larger rims would transfer more road feel.
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 10-13-2011, 07:57 AM   #3
CirrusSR22
My Ride: E36 318ti, E46 323it
I doubt you'd have any vibration issues with "solid" rubber Meyles. Polyurethane I can see, but not rubber. Keep in mind the E30 and E36 have the same basic front suspension design and none of those had the fluid filled control arm bushings - just rubber.
CirrusSR22 is offline   Reply With Quote
Old 10-13-2011, 08:23 AM   #4
nk_zhp
My Ride: ZHP / E30 M3
I just installed a set of HD 2 days ago. There is definitely more feel from the road but I actually like it. Any more would be a little too much for a street driven car. I think HDs are a perfect balance. I don't have that weird feedback in the wheel when I get on the brakes any more.
hope this helps.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 10-13-2011, 09:03 AM   #5
avglushk
My Ride: e92
Originally Posted by Zell View Post
Yes, I did
Genuine BMW:
Guaranteed fit
Expensive
Meyle HD:
Pros: Last longer
Cons:
http://www.autohausaz.com/search/pro...0Bushing%20Kit
Originally Posted by Arsevader
Sorry to hear about your mirror. This is what happens when you don't change your mirror fluid at the recommended intervals.
For Sale: 1. OEM used headlights and corners, see link http://forum.e46fanatics.com/showthread.php?t=884565
2. 2 brand new Bosch post cat oxygen sensors
avglushk is offline   Reply With Quote
Old 10-13-2011, 09:06 AM   #6
bimminge46
My Ride: 323Ci, 89 325i ETA
powerflex
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 10-13-2011, 09:52 AM   #7
Blocked Out
My Ride: Imola 330i M-Sport
Go oem, 50 k miles is really good for fcab.
No way in hell myele would last that long.
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 10-13-2011, 09:54 AM   #8
OrientBlau
My Ride: 2003 330i
50K?
OE FCABs need to be replaced every ~20K.
Are you sure youre not thinking of control arms? Those might not last more than 50K - 60K.
EVen if they did last 50K, thats a LOT of miles for a part that only costs $120 for the pair.
I would still buy OE FCABs.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 10-13-2011, 10:42 AM   #9
Zell
Zell's Avatar
That's just what I read online, that FCABs go bad 50-60k, and non-ZHP control arms around 100k.
Old 10-13-2011, 10:49 AM   #10
OrientBlau
My Ride: 2003 330i
Ive had mine replaced 3 times in 60K. The first two times were performed by the dealer under warranty.
Of course it depends on the roads you drive on and how much excess play youre willing to tolerate, but 50K is really not possible. It would seem a lot of posters keep them well beyond their useful life or are refering to poly bushings, which last longer than rubber but provide a really harsh ride. If you search, you'll see many who bought AM FCABs almost always return to OE bushings and regret having to spend the extra time and money replacing inferior parts.
Old 10-13-2011, 11:08 AM   #11
TxZHP04
My Ride: ESS TS2+ ZHP
I can't speak to the rest of their product line but I typically get 1.5X - 2X the life out of Meyle HD CABs and rear diff bushings relative to stock.
My stock CABs lasted roughly 35k miles on a completely stock suspension. I now get 55-60k miles with Meyle HD CABs even though I have a much more aggressive suspension setup (255 vs 225 front tires, stiffer front sway, 550 lb/in front spring rates vs ~140 lb/in stock).
Aside from the fact that the slightly stiffer bushing may reveal other previously undetected suspension problems which people then tend to blame on the bushing, I have no problems recommending the Meyle HD CAB. It may also be possible that the Meyle bushing is more sensitive to having the proper insertion depth on both sides of the car although I've never experienced any unusual vibrations with my bushings. A tiny bit of extra road feel, sure, but no vibration through the steering wheel.
Old 10-13-2011, 11:25 AM   #12
Penguin Koolaid
Banned
My Ride: Inline Six
I have Meyle HD FCAB's and control arms. I have easily put 15,000 miles since they were installed and the ride has been smooth and confident. ZERO problems. I plan to replace them once they are more worn with Meyle HD FCABS's again.
FCAB's usually last ~20,000-25,000 miles.
Penguin Koolaid is offline   Reply With Quote
Old 10-13-2011, 11:28 AM   #13
My Ride: Lexus
Exact same story here. Same mileage even. All good.
Old 10-13-2011, 11:29 AM   #14
My Ride: Lexus
See my photos of the Meyle equipment here: http://forum.e46fanatics.com/showthread.php?t=841749
Old 10-13-2011, 11:38 AM   #15
ModBargains III
ModBargains III's Avatar
My Ride: E46
Originally Posted by bimminge46 View Post
powerflex
+1
I run Powerflex FCABs on my car. I've had them on for about 10k miles, no signs of wear or tear!
PowerFlex Urethane Suspension Bushings E46 Non-M/M3
http://www.modbargains.com/PowerFlex...shings-E46.htm
I hope that helps
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 10-13-2011, 11:49 AM   #16
trizzuth
My Ride: 234k, 16yr old B3AST
lemfoerder
trizzuth is offline   Reply With Quote
Old 10-13-2011, 11:55 AM   #17
My Ride: Lexus
Originally Posted by trizzuth View Post
lemfoerder
lemforder=genuine bmw
Old 10-13-2011, 12:44 PM   #18
Blocked Out
Well, when I bought my current car it had oe bushes in. I decided to change them just because I wanted to run Urenthene. When I took out the oe bushes they were stamped '08 so my best guess would be that they had about 40k miles and they were perfectly fine(They even still held oil in them). My friend bought Myele for his car a few years back and they disintegrated within 25k miles (yes, we all drive quite alot over here).
Eventhou I have Powerflex bushes in my car I still recommend OEM for OP , because I think they will suit him better.
IMG_1725
Old 10-13-2011, 12:53 PM   #19
Kubica
My Ride: 2003 325xi
P-P-P-Powerflex.
Old 10-13-2011, 12:55 PM   #20
Steven747
My Ride: 05 330ci
op obviously didn't search
