Sponsored by BAVSOUND
Old 11-15-2011, 01:11 PM   #21
fadeaway
My Ride: 04 330Ci
Originally Posted by chazstace View Post
Its a home build kit, you get them from a place called maplin here in the UK, however do a search on google and I'm sure you will find them.
There are 2 parts to the rear window, one used by the factory amp that I have left in place and the other connected to the new amp. Giving 2 feeds, one for Radio and one for the TMC.
http://www.maplin.co.uk/m-100-profes...plifier-222409
I'm assuming that this is the one that you got. Very nice job getting things to work the way that you did.
Just for future reference, when you say home built it is generally interpreted as "I created this thing using spare parts and ingenuity." When there is a kit with instructions, I would not call it "home built." Either way, good job and nice post!
fadeaway is offline   Reply With Quote
Old 11-15-2011, 01:23 PM   #22
podge3
My Ride: Rover 75 CDTi
Originally Posted by fadeaway View Post
Don't think thats it.
Kit K2622 here looks more like it: http://esr.co.uk/velleman/products/index_kit.htm
podge3 is offline   Reply With Quote
Old 11-15-2011, 02:27 PM   #23
fadeaway
My Ride: 04 330Ci
This looks more like it: http://esr.co.uk/velleman/products/index_kit.htm
That's a java page. It just shows their entire product listing. Which were you referring to?
Old 11-15-2011, 03:02 PM   #24
podge3
Kit K2622.
Old 11-15-2011, 04:48 PM   #25
fadeaway
My Ride: 04 330Ci
Cool. Thanks!
Old 03-01-2012, 12:58 AM   #26
TitanSilverE46
My Ride: 2001 318i & 325i
Looking for a few more details on the hookup. The Dynavin has only one radio antenna input. You are saying you are using your new amp for the radio so I am presuming you are connecting the output from your amp to the existing dynavin antenna lead. Where are you connecting the output from the OEM amplifier that you are now using for the TMC? Where are you picking up the 12v power from?
TitanSilverE46 is offline   Reply With Quote
Old 03-01-2012, 02:46 AM   #27
MaximumWalrus
My Ride: E39 530i
Just as a heads up the newer units have two antenna inputs and tmc seems to work really well
MaximumWalrus is offline   Reply With Quote
Old 03-01-2012, 03:44 AM   #28
TitanSilverE46
Are you saying that newer Dynavin V5 units (post May 2005) have two antenna inputs?
The OP has a 328 so I am presuming pre 2001 which had the older amplfier and head unit. There were two leads from this amplifier to the OEM head unit but only one could be used by the Dynavin. Unfortunately the second lead applied power from the head unit to the amp and so many people had crap AM/FM reception after fitting the Dynavin. I, like many, have fitted a powered antenna adapter between the antenna lead and the Dynavin and as this adapter is also connected to a 12v source, it supplies power to the amp and improves FM reception.
So back to the case in point, unless the Dynavin (post May 2011) has two antenna inputs, I need to know how the OP has connected the output from the two amplifiers to his dynavin.
Old 03-01-2012, 04:37 AM   #29
MaximumWalrus
My Ride: E39 530i
The D99 models have two antenna inputs.
Old 03-01-2012, 05:20 AM   #30
TitanSilverE46
As the original post was Oct 2011, the OP would most likely have a V5 D90 same as mine. The D95 was V6 and D99 was new for 2012. Did either late V90 or D95 units have two antenna inputs like the D99?
Old 03-18-2012, 05:37 PM   #31
chazstace
My Ride: E46 328i SE
I connected the original factory antenna to the TMC, This gives me TMC coverage almost everywhere 100% of the time.
I then tapped into the lower part of the antenna on the actual rear screen itself for FM Radio, then attached a booster. This method works best I found.
chazstace is offline   Reply With Quote
Old 02-10-2013, 08:56 AM   #32
e46 330ci vert
My Ride: e46 vert
Send a message via ICQ to e46 330ci vert
any more info on this please?
e46 330ci vert is offline   Reply With Quote
