#1 |
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
anyone know the best lube to remedy this or if something in the hinge needs to be tightened?
-j |
#2 |
Wd-40 bro
Winter Authority When Hell freezes over,we'll play Hockey there too
![]() Its fundamental to our nature, man must explore. you've Met a terrible fate haven't you ? KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now) Questions about Header wrap? clickHere Supercharger build thread click Here |
#3 |
try silicone lube if you dont like the WD40 smell.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser 2008 YAMAHA YZF-R6 ![]() |
#4 |
You can also use 3 in 1 lube that still comes in small tin bottle
#5 |
My Ride: 02 325i
that simple huh,
I was under the impression that the lube from the factory (lasted aparently 10 years) was something that would get broken down by other types of lubricants. ok, thanks!
-j |
#6 | |
2009 Mazda RX-8 R3
#7 |
I use ZEP 45. I use it for my guns and it works great
Sent from my PC36100 using Bimmer |
#8 |
Its that simple Motor oil will work just as well
#9 |
good ole WD-40
#10 |
#11 |
My Ride: 02 325i
-j |
#12 |
I used WD-40. The creak went away for a while but came back soon enough. I would suggest an actual grease to get it done right.
Sent from my PG86100 using Bimmer
#13 |
using an oil well work as well Ive used WD-40 lots, Im surprised it didnt work for you
#14 |
My Ride: 02 325i
where exactly to apply it? dont want messy jam... (alpine white)
-j |
#15 |
The hinge itself is most likely squeaking If lube ing it up dosent help it might be worn out. Grab the bottom of the door and lift up and down and see if their is play in the hinge
#16 |
My Ride: 02 325i
No play in hinge thankfully
-j |
#17 |
This oil works very well
![]() Its what i use on my car its not messy and seems to last
#18 | |
#19 |
My Ride: 02 325i
for the record,
I used wd 40 and it immeadiately got louder.... cleaned that off, used silicone: niose still there. losened /tightened all bolts/ hinges... noise still there. hard to pinpoint where the sound is actually coming from. after cleaning off again and sitting overnight: noise is 90% gone but is still there a bit. ![]() is it possible that the black rocker arm has a worn component where it connects inside the door?
-j |
#20 |
Applied WD40 4 months ago..havent heard the squeaking yet,..just apply it generously.
