Old 10-13-2011, 09:50 PM   #1
joeyrevolution
My Ride: E46 325i
oil leak 325i
hey all, been hunting down an oil leak that was dripping over my AC compressor. as i did research forums were saying it could be the crush seal on the timing tensioner bolt. I finally got the car on a lift and could not see the leak coming from there. I happened to get my hands on a fiber optic scope and could see and feel fresh oil coming from the seam right next to where the tensioner bolt is located. I can see a hex bolt covered in oil as well (part # 07119900486) on realoem.com. it doesnt seem like this engine has an upper and lower casing. could this be a leak in the timing bolt cover? is there a gasket that needs to be replaced or does it just need to be tightened? what are my options and fixes?
thanks for you time.
joe
joeyrevolution is offline   Reply With Quote
gasket, leak, oil, timing
