Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Site Sponsor Group Buys
Group buys from the sponsors that support E46Fanatics.com and other approved group buys.
Old 10-14-2011, 12:58 PM   #1
Rob Levinson * UUC Motorwerks
UUC Motorwerks, *******
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
UUC * FREE BRAKE FLUID! (see details inside)
FREE BRAKE FLUID
(expires after 10/17/2011)
How can that be?
Buy any complete set of our stainless steel brake lines for your BMW (we cover practically all models), add the two bottles of Motul RBF600 and your order will be automatically discounted at checkout.
Why stainless steel brake lines?
Original brake lines are rubber and can expand under the normal pressure of use. This expansion of the brake line negatively affects the brake caliper piston travel, and makes for mushy pedal feedback. Normal maintenance includes replacement of rubber brake lines about every 5 years.
UUC's Stainless Steel Brake lines are used to "performance tune" your braking system.
Inner TeflonŽ line is covered with woven stainless steel braid that will not expand under pressure. The advantages include better brake pedal feedback and a firmer pedal, along with superior brake modulation. Results will be immediate.
[ CLICK HERE ] for more information!
Why Motul RBF600 brake fluid?
Motul RBF600 is a 100% synthetic fluid compatible with all BMW brake systems. Specifically designed to resist the high temperatures of racing brakes, more than robust enough for street use.
EXTREME THERMAL RESISTANCE AND STABILITY: the elevated boiling point of RBF 600 FACTORY LINE (312°c / 593°F) enables effective braking even under the extreme conditions of competition.
VERY EFFICIENT WHEN RAINY: the very high wet boiling point(216°c / 420°F), is superior to conventional brake fluids provides a particularly efficient braking system in rain and put back the apparition of vapor lock.
[ CLICK HERE ] for our complete website catalog.
* Requires purchase of complete set of UUC brake lines at regular retail price. Expires after 10/17/2011. Valid only through UUC directly, not independent dealers.
(c) 2011 UUC Motorwerks
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
