Old 10-14-2011, 07:17 PM   #1
shata
My Ride: 00 328i , 06 330i
Cooling System Maintenance EVERY 60K!
I just thought id point this out to people that haven't had this car very long, Take a look at it if your before or slightly past 60k (interval). Most likely it wasn't done.
I learned the hard way I only replaced the pump about 4-5 months ago or roughly 152k im at 157k now and my system has sprung leak today. Sigh...
Ordering ECS Cooling Maintenance Kit - Level 3 soon and taking weekend to do it right. When bmw says something needs to be done, It be wise to have it done trust me.
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Old 10-14-2011, 08:12 PM   #2
05graysport
My Ride: 46/325 B5/S4 39/M5
or you could have done something between 60k and the 92k extra miles put on after
05graysport is offline   Reply With Quote
Old 10-14-2011, 08:17 PM   #3
bmw335ion18s
My Ride: '04 330Cic 5AT
Mine exploded at 49k. Yup, 49k.
bmw335ion18s is offline   Reply With Quote
Old 10-14-2011, 08:28 PM   #4
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
Looks like the same picture as my car, last week, at 187k. The radiator sprung a pretty bad leak. Turned out the end of the pipe from the radiator to the upper radiator hose was literally disintegrating. It fell apart in my fingers after I took it apart. New radiator was $150 from Pelican Parts.
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 10-14-2011, 08:55 PM   #5
shata
Ya its freakin toast, I noticed it week ago when Coolant light came on in morning...im like wtf well after another week this happend today. (Topped off with 32oz of coolant mix) Gona try push another 2 weeks out of it so I can take it to shop but I dont have spare cash for 1000$ repair.
Old 10-14-2011, 08:58 PM   #6
shata
Wow 49k... thats terrible.
Old 10-14-2011, 09:18 PM   #7
tonykim
My Ride: 2000 328i
you guys are lucky. our 328 cooling system was damaged during assembly at the factory causing the lower half of the radiator to have no flow. it clogged over time and even with having the system flushed what ended up happening was a combo of thermostat failing and overflow tank breaking and massive engine overheat...it all happened in a matter of seconds.
2000 328 Sport/Premium Pkg, 2005 Ford F150 FX4 SuperCrew, 1993 Ford Mustang LX 520 hp EFI stroker - sold, 1989 Mustang Saleen 450 hp vortech 302, 1978 Pontiac Firebird, 1969 Opel Kadett Rallye ex-SCCA car
tonykim is offline   Reply With Quote
Old 10-14-2011, 09:21 PM   #8
shata
Thats pretty freaking bad man, im sorry hope bmw covered that repair otherwise the car is pretty much totaled at that point.
Old 10-14-2011, 09:29 PM   #9
Sanchjer
My Ride: 323i e46 SOLD!
Do it yourself man. It isn't hard.
Sent from my PG86100 using Bimmer
Sanchjer is offline   Reply With Quote
Old 10-14-2011, 09:43 PM   #10
Alex2003
My Ride: 2003 red bmw 330ci
My coolant light popped on and off like 4 times in 2-3 days then stopped. Does that pose a problem or do I actually just need to put coolant in? And I was told cooling system maintenance was $300-$400 not $1000.
Alex2003 is offline   Reply With Quote
Old 10-14-2011, 09:49 PM   #11
shata
Ya if it comes on it means its low, It will only pop normally when car is cold in morning. In morning before you start it open it up and add 50/50 mix of bmw coolant (not any other brand, go to stealership and get it). Then fill it till the float is at the point like on little diagram.
Well its 640$ for parts Complete system from hoses to radiator...everything. Then labor I know guy that charges me 60$/hr (GM master mechanic) So im estimating 1k roughly. I cant chance it doing it myself if I don't have my car for work im screwed.
The Cooling system maintenance kits are sold in different levels 1-3. Given people don't take care of their cars and never service nothing im going 3 but if you know previous owner did their stuff then maybe you only need 1 or 2.
Old 10-14-2011, 11:28 PM   #12
Steven747
My Ride: 05 330ci
ecs's cooling overhaul kits have cheap mtc parts in some of them and isn't a real cooling overhaul... a real cooling overhaul is a CO from getbmwparts.com and if your really good you will get a stewart emp on top of that and your set.
shata maybe try changing your rims and your cooling system won't fail so much
Old 10-14-2011, 11:57 PM   #13
ZHPRegistry
Past Site Sponsor
My Ride: was a bit tiresome
How did you know that is a problem from the factory?
ZHPRegistry is offline   Reply With Quote
Old 10-15-2011, 08:59 AM   #14
tonykim
My Ride: 2000 328i
when I took it apart there was a piece of plastic missing from the quick connect male end. as I dug through the hardened deposits a layer at a time I reached the bypass valve and found the missing piece of plastic mechanically jammed between the wall and the spring on the bypass valve holding it in place. the overflow tank had never been out of the car nor the cooling system disassembled. the dealer verified that through the service records. they also did not detect the issue nor the formation of hardening deposits in the bottom flowpath of the two pass radiator when they flushed the system a few years earlier. my guess is the nipple had a flaw and the force applied during assembly broke it.
Old 10-15-2011, 09:03 AM   #15
tonykim
My Ride: 2000 328i
and no bmw said too bad so sad. the engine got hot enough that it smoked the oil in the lifters. it was the final straw for us of a long list of premature failures even though we had been super diligent with maintenance. so we parked it in the driveway and it sat for over a year as a yard ornament. then i pulled everything down replaced all the cooling system parts, filled it with water, changed the oil, put a pint of magic mystery oil with the castrol synth, and fired it up. no leaks, no overheat, but the lifters clacked for about 25 minutes and one by one went quiet. except now I have a few that make noise on cold start up and when it's fully warm the engine is a little louder than it should be. but amazingly it uses no oil and no coolant, gets 24 mpg, and on we go. i figure i will drive it until it explodes. so far 10k miles. Hail Mary and thanks bmw for not helping out.
Old 10-15-2011, 10:22 AM   #16
celt
My Ride: '02 325i
Since the cooling system is failure-prone I would avoid after-market parts. Try getbmwparts.com - prices are good and service is excellent.
celt is offline   Reply With Quote
Old 10-15-2011, 10:22 AM   #17
shata
Change my rims? How is that gona make a difference. When I replaced the pump few months back it was cause the Bearing shattered in pump which broke the pully also.
Old 10-16-2011, 01:12 AM   #18
Kwaz
My Ride: 323I
Coolant systems suck ass in bmw's I've done 2 complete overhauls an extra coolant tank as well but easy as 123 to DIY, and 1000? That's ridiculous
Kwaz is offline   Reply With Quote
Old 10-16-2011, 01:19 AM   #19
JaYaRe
My Ride: goes, Brroom Brooom
my expansion tank has gone out twice FML the first time it cracked, i replaced it, the second exploded and took the belts out... :[
100_0903-1
JaYaRe is offline   Reply With Quote
Old 10-16-2011, 06:13 AM   #20
GoingNuts
Just Nuts
My Ride: 2004 330Ci
So you did something and following that the car broke. Now you want everyone to follow your foot steps ? People would be better off going in the opposite direction.
GoingNuts is offline   Reply With Quote
