Any non M's with 3" exhaust? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-14-2011, 07:40 PM   #1
diablorojo
My Ride: Supercharged 330i
I originally had a Borla exhaust ( prior to forced induction) that has been modified after FI to add an X pipe and changed the muffler also because the rasp was so bad. Now I'm considering going with a 3" custom exhaust but concerned about loosing back pressure.
I know it's common on the M to go to 3" but the exhaust set up is different.
Does anyone have any success with a 3" exhaust?
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 10-14-2011, 07:41 PM   #2
diablorojo
Also...I have over 400rwh....
Old 10-14-2011, 09:10 PM   #3
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
Shitty video and wheels. 3" single on an NA motor. Do it.
Len013091 is offline   Reply With Quote
Old 10-14-2011, 09:11 PM   #4
Len013091
And another. Magnaflow 3" mufflers. A 14" and 18".
Old 10-14-2011, 09:25 PM   #5
diablorojo
I have dual 2.5 from header to exhaust. I'm wondering if I should do 3" dual to exhaust...
Old 10-14-2011, 09:53 PM   #6
Len013091
The dual 2.5 outflows a single 3 area wise, but a single pipe is much easier in terms of muffler selection and whatnot. it also cuts down on rasp.
Old 10-14-2011, 10:09 PM   #7
SweTurbo
Big Pimpin'
My Ride: 323i -98
I have 3" all the way to the rear muffler which is 2x 2,5" , my car is too quiet lol
Old 10-14-2011, 10:14 PM   #8
diablorojo
I'm looking more so because of boost. I'm thinking I can move more exhaust with dual 3" exhaust but wonders if anyone has done it with a 330. Are the M3's using dual 3"?
Old 10-15-2011, 08:58 AM   #9
Len013091
The bigger boosted m3s use a single 4". You'd be hard pressed to fit dual 3 under your car, and honestly that's too much... unless you've got a worked over 572 under the hood.
Old 10-15-2011, 12:43 PM   #10
95blkmax
My Ride: 00 BMW 328i
Send a message via AIM to 95blkmax
Im on turbo. My exhaust is 2.5" downpipe into a full 3" custom catback (Magnaflow 24" resonator and a 3" single inlet/ dual 2.5" outlet muffler). With the turbo it's not loud at all. Just a deep tone.
I strongly recommend it, especially if you are over 400rwhp. You get better scavenging effect (not back-pressure) out of a single big pipe than 2 small ones (when have you ever seen a high power supra or RB-powered Skyline with dual pipes? lol). People too often confuse the two terms. What you WANT is good scavenging effect (which for turbo is mostly useless, but for NA and blower setups yes you want it), what you DON'T want is back-pressure. Back pressure is literally a "backup/ clog in the piping" that robs power.
Hi, my name is 95BlkMax, and I am a Boostaholic
"DANGER TO MANIFOLD!!!!" O_o!
95blkmax is offline   Reply With Quote
Old 10-15-2011, 12:53 PM   #11
diablorojo
@95blkmax....is it duel 3" from the header or single 3" from the header?
Old 10-15-2011, 01:17 PM   #12
InDiGlOM3
My Ride: HPF M3 stg 2.5
the 700rwhp Turbo M3's run 3 inch downpipes....... so 3 inch all the way is plenty.
Old 10-15-2011, 02:00 PM   #13
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I do, but no FI. Made good power over dual 2.5.
Old 10-15-2011, 04:22 PM   #14
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
I have a short section of 3", maybe a foot long, that then flares out to 3.5" to the rear tip
edit:
what do you have?
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 10-15-2011, 05:48 PM   #15
diablorojo
I have 2.5 all the way to the muffler which meets 2.5 into the muffler and 2.5 out. I have an x pipe Borla resonators and a magna flow muffler.
Situation: I just got the head ported, larger throttle body and 14psi pulley (all going on over the next couple days). I'm going to have a significant increase in engine flow and believe I can benefit from a larger exhaust.
I'm thinking now of just doing a single 3.5" from the header to the muffler. I want to make sure I'm allow enough flow for an efficient exhaust.
Old 10-15-2011, 09:17 PM   #16
95blkmax
single 3" from the downpipe backto the muffler
sounds about right . I had a 95 Maxima with a 3.5 swap, and I picked up about 7fwhp (NA at the time) going from single 2.5" to single 3".
you will hate 3.5" exhaust. Thats overkill at your power level. A 3" mandrel bent exhaust with a non-baffled mufler (such as most magnaflow muffler) and a big resonator is more than enough for that.
Would you make more power with 3.5? Im sure you will.
Will it be an increase that will be worth the MUCH higher cost and the drone that you will not be able to get rid of?... well that's up to you .
Just trying to save you some money, headache, and the hearing of you and your neighbors lol
Old 10-15-2011, 10:24 PM   #17
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I'm aiming at ~350whp for my next setup and will be running a 3.5" exhaust. I've seen gains on ~300whp naturally aspirated S54 motors by switching from 3 to 3.5.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 10-15-2011, 10:26 PM   #18
xixixi
Banned User
My Ride: 01 330x-xi
basic physics, math proves this isn't needed. I'd love to see dyno's? Did they switch Y pipe placement? What else was modified to see these gains? I suppose s54's defy physics to achieve this, I'm impressed!
Old 10-15-2011, 10:45 PM   #19
Activ3
Search for any competitive S54 powered racecar, and see what exhaust setup they're running. The AA, Bimmerworld, and VAC S54 race exhausts are all 3.5" shortly after the header. A good amount of the e36 turbo guys have also found within the last couple years that upgrading to a 3.5" exhaust from a 3" has proven gains, a few of them are even going up to 4".
And what math and basic physics do you have that proves that a 3" will flow as well as a 3.5" for that application?
Old 10-16-2011, 06:58 PM   #20
nickr519
My Ride: ZX-10R, Ram 2500
+1 I love it when people say this and then don't spell it out. If it's so basic why wouldn't you just at least dish out the relevant formulas for those who are savvy and then explain relationship of the variables for those who don't understand "basic math and physics"
'99 323i - totalled
'87 supra - sold
'90 300zx - sold
'01 GSX-R600 - sold
'97 Ram 2500
'06 ZX-10R
nickr519 is offline   Reply With Quote
