Old 10-14-2011, 08:27 PM   #1
Bavaryan
My Ride: 330i w/out park.
Where can I be loosing brake fluid at? manual trans
I know that over time as the pads get thinner the brake fluid in the resevoir will slowly drop, this is normal.
However, in the past 7k miles or so, i'd say i've lost about 1" of fluid level in my resevoir. That seems more than normal due to pad use.
Things i've checked:
All 4 calipers
Clutch Master
Brake master(unless leaking into the booster, no way to really check that until it gets worse, but I doubt that one...)
Clutch and brake lines.
What am I missing? Could the slave be leaking fluid into the bell housing? is this common?
Thanks!
Bavaryan is offline   Reply With Quote
Old 10-15-2011, 12:43 PM   #2
markusmarkus
My Ride: 2001 330Ci
If the clutch slave cylinder was leaking into the bell housing you'd see fluid dripping from the bell housing.
markusmarkus is online now   Reply With Quote
Old 10-15-2011, 05:19 PM   #3
Bavaryan
If it were a big leak, definately yes. But this is a very small leak. Most probably wouldn't notice it/pay attention to it, but i'm OCD about fluid leaks. I think I chose the wrong car to be OCD about fluid leaks on.
