Old 10-15-2011, 01:26 PM   #1
everchini
My Ride: 2000 323Ci
The dreaded milkshake.
So Iíve had this issue before, a little over a month ago, I was driving the coolant light came on and the temp gauge went into the red. I pulled over and there was brown coolant everywhere in my engine compartment. The coolant expansion tank cracked (mechanic told me) he replaced the expansion tank along with all of the hoses.
Drove it for a month without any problems, until last week when i started the car saw the coolant light come on, shut it off, checked it and noticed that the level was very low and that the dipstick showed there wasnít any oil either. With no signs of leaking under the car. I filled both with 50/50 coolant and 2 qts of oil. I drove about 10 minutes down the road to notice that the coolant was leaking over the coolant cap and formed a puddle on the ground. On the way back home, it started to overheat a little bit and smoke from the coolant cap.
I let it cool down, checked it this morning and the coolant level was back to being low and was very frothy as you can see by the pictures. The first picture shows what tank looked like before I filled it when I noticed it was low and the three other pictures are what it currently looks like.
I bought the car last May from a Mini Cooper dealership with no warranty, I have a loan on the car and if itís a head gasket iím not sure what my options are unless I trade it in as is and roll it over into a new loan. This is my second BMW, Iím lost please help!
ID:	421013   Click image for larger version
ID:	421014   Click image for larger version
ID:	421015   Click image for larger version
everchini is offline   Reply With Quote
Old 10-15-2011, 03:48 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Is there any coolant in your oil and how long did you drive it in the red?
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 10-15-2011, 03:50 PM   #3
edsmax
My Ride: 01 330i
Send a message via AIM to edsmax
It looks like your head gasket went - take it to a mechanic.
Mods: OEM clears all around, ZHP ///M weighted shift knob, GruppeM CAI, UUC Clutch Stop, B&M SSK, red line fluids, golf tee
edsmax is offline   Reply With Quote
Old 10-15-2011, 03:51 PM   #4
everchini
My Ride: 2000 323Ci
I'm not sure, how can I know for sure? I'll check right now. And it was no more than 1 min. but I pulled over and turned the car off instead of letting it cool off, I was told that turning it off right away could cause the block to warp.
Old 10-15-2011, 03:54 PM   #5
darksideracer69
My Ride: 01 325ci
Yuck
Sent from my SGH-T959V using Bimmer
IMAG02051
Old 10-15-2011, 03:54 PM   #6
everchini
My Ride: 2000 323Ci
I am going to replace the head gasket, has anyone attempted it before?
Old 10-15-2011, 03:55 PM   #7
everchini
My Ride: 2000 323Ci
Yeah, yuck indeed, sweet wheels man
Old 10-15-2011, 03:55 PM   #8
edsmax
My Ride: 01 330i
Nah, you are reading too much into it. You did the right thing by turning off the car right away. Unfortunately, these aluminum engine parts warp very easy so even if it was "no more than a minute" in the red, thats all it can take. Some people are lucky and some are not.
My advice - drain the oil and look at it. If coolant is in the oil, then you will know for sure.
Old 10-15-2011, 04:16 PM   #9
darksideracer69
My Ride: 01 325ci
If you have the right tools, and are mechanically inclined. It shouldn't be to bad.
But if I remember there was this thread about a guy not having his car for a month cause he kept running into problems.
The right tools are very important.
And thank you
IMAG02051
Old 10-15-2011, 04:18 PM   #10
Stinger9
My Ride: '04 330Ci
How good are your skills?
What's the largest job you've DIY'ed before?
This is tough and I've never seen a DIY for it before. Search for one anyway; it may exist, but it would have to be long. Got a good set of tools?
Bentley does have instructions for this. I'd read this section to get an idea if you'd want to tackle the job.
Just a logical disassembley and put back together after checking/replacing/milling the head. Except for the camshaft timing which supposedly requires special tools and skills. Got a chain going on there.
I believe this is clearly an example of the warping of the head when overheating that so many refer to when urging a proactive replacement of cooling systems. You did nothing wrong in that the overheating can take place so quickly that no indication is given to the driver until it is too late and the expensive damage is done. Engine temperature gauges do not respond quickly enough.
Please report back to us here as to what makes you decide to do what you ultimately do? I'd really appreciate knowing how you handle this, with details.
Old 10-15-2011, 04:33 PM   #11
Vic328CSi
My Ride: depends on the mood
As long as its not your only car, i say do it! It does take a while the first time though dont rush it. I did gaskets on my dads old Range range rover (that he loves too much to get rid of) few months ago, very rewarding feeling to diy. Just make sure you get the right tools and do it right. Dont cut corners. Probably the hardest part is removing/reinstalling the exhaust manifolds. And careful not to strip/cross thread any of the bolts, its an aluminum block.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 10-15-2011, 04:44 PM   #12
MarkyNels
My Ride: 2013 S4
Exactly..
It's going to be off the road for a while, and the HG seems to be your issue.. It's not a big deal to do, as you can do it within a day if you're mechanically inclined .. The only things i can warn you about now are head and block decking. It is possible that your head is warped. The actual integrity of the HG could be fine, but due to reaching such high temps due to a cracked coolant res could have caused the head to warp, thus being your issue, not your HG per se. So you will need to get the head decked. I'm sure you have a machine shop that specializes in engine rebuilds that can do this. General price runs to about 100-150$ depending on how many passes the need to run (ie. how out of clearance it is). Then you'll need a HG which will vary in thickness due to the material removed. IF there was only a couple thou, i would just run a stock HG thickness. Generally you don't need to be concerned with this though, and the machine shop will guide you in the right direction.
As for the block - typically this is fine. To make sure, you need to clean HG remnants from the block mating point and run a straight edge along it while checking tolerance with a feeler gauge. This will tell you if there are any low spots or dips in your block. This can be caused by pitting - stagnant pools of coolant collecting over periods of time due to a warped head or faulty HG. Like i said, check it, but don't be too concerned about this because it's rare the block will need to be machined..
These are things you need to be aware of, as most people assume they just need to change the HG and throw everything back together..
If you can take it apart, you can put it back together. Another word of caution - read THOROUGHLY into timing and cam positions. This may save you a few valves and a rebuild in the future.
Best of luck
MarkyNels is offline   Reply With Quote
Old 10-15-2011, 04:58 PM   #13
Vic328CSi
Best of luck
+1
Cylinder head machining, pressure testing is a MUST. Otherwise all the effort doing a head gasket is wasted when it blows again 2000miles later.
e46 328Ci 9psi SC
Old 10-15-2011, 05:08 PM   #14
Stinger9
My Ride: '04 330Ci
Pressure testing what?
I understand the block and head flat checking.
But what are you pressure checking?
Originally Posted by Vic328CSi View Post
+1
Old 10-15-2011, 05:12 PM   #15
shata
My Ride: 00 328i , 06 330i
Damn im sorry, Thats gona be expensive. Ive had cooling system problems also this past 2 weeks. It held out all summer and now its like FU!
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Old 10-15-2011, 05:15 PM   #16
shata
Looking at a flush...A good one - I personally say disassemble the cooling system and clean it all out or flush it drive it for 50-100 miles and flush it again. Then the head gasket if you don't have it done yourself well im sure your looking at 2k repair most likely maybe 1k if your lucky.
And I feel you on your problems, Mine is on loan also and this car has cost me about 4k since ive owned it. And now another 1k for my cooling system overhaul thats being done next weekend at shop.
Old 10-15-2011, 05:40 PM   #17
Vic328CSi
They pressure test the cylinder heads to check for cracks/valve seal. Its alumnium, it can crap out especially if its overheated.
e46 328Ci 9psi SC
Old 10-15-2011, 05:55 PM   #18
everchini
My Ride: 2000 323Ci
Thank you everyone for the posts, my cousin has replaced a lot of head gaskets but this will be his first BMW, he's researched all the tools that we need to finish it, even if we do run into problems I'll take it to a shop, or just flush the absolute **** out of it and trade it in, and rollover my loan
Old 10-15-2011, 07:03 PM   #19
Blocked Out
My Ride: Imola 330i M-Sport
I would STRONGLY advise to take it to a reputable BMW technician, not one of those retards that work on any car , but one that works only with BMWs.
Head gasket replacement is a BIG job even for me and I've done it as well as more complicated things. You need tools and not only that , you need patience and a little bit of skill.
If its your headgasket , then I'll help you as much as I can , but you MUST be 100% sure thats its the headgasket before you start. Do a compression test just to be double sure.
Here is a link, start reading now. I'll pull out a few more when I get back.
http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
Original BMW Teile ///
IMG_1725
Old 10-15-2011, 07:09 PM   #20
everchini
My Ride: 2000 323Ci
I would strongly love to afford a BMW Technician, well with these signs what else could it be? There's oil and coolant mixing somehow, what are the other possibilities?
coolant, head gasket, milkshake, oil, overheat
