Old 10-15-2011, 01:32 PM   #1
neta4
My Ride: 330ci Sport manual
Front windows stopped working with burning smell
Hi All,
I had a bit of a random experience today with my 2002 330ci. Driving down the motorway the front drivers side window dropped slightly, as if the door had opened (which it had not) a few seconds later the electrics basically went mad: The wipers came on, the screenwash motors came on, the alarm went off with a constant and deafening tone and all controls for windows and wipers stopped working. Then came a strong burning smell.
I pulled over and disconnected the battery which was the only way to stop everything turning on. Once I had reconnected it most things seemed to function with the exception of the front electric windows. The fuses are OK and when I press either button I can hear a small click which I understand to be the relays. What is left of the buring smell does seem to be stronger in the passenger side but its hard to tell. Its not coming from the vents.
Has anyone had a similar experience? Can anyone point me in the direction of the problem?
I am going to check out the relays tomorrow when it is light!
neta4 is offline   Reply With Quote
Old 10-15-2011, 01:37 PM   #2
Drew@Swift Motorworks
Drew@Swift Motorworks's Avatar
My Ride: Scooty Puff Jr
Wow sounds crazy
Could be a short or something. Take the door panels off and check the wiring
p1192285638-5
.::PM me your tech questions, I'm always happy to help!::.
Swift Motorworks
Drew Powers
p: (707)702-1775
e: drew@swiftmotorworks.com
www.SwiftMotorworks.com
Drew@Swift Motorworks is offline   Reply With Quote
Old 10-15-2011, 03:52 PM   #3
scottjoh
My Ride: 1999 323i - TiAg
All the items that went nuts are GM5 modules so that must be the problem. I've never heard of anything like that before, but, I'd like to test that module. Send it in to me.
scottjoh is offline   Reply With Quote
Old 10-15-2011, 05:05 PM   #4
Vic328CSi
My Ride: depends on the mood
Originally Posted by neta4 View Post
Hi All,
Sounds like you need an exorcist.
Hope you find the issue, most likely a blow window regulator but cant explain the rest. Maybe you shorted out the motor and it sent everything else into a fritz
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
