Old 10-15-2011, 03:11 PM   #1
Sam-I-Am328
My Ride: 2000 BMW 328i
Question Whats the problem???
I have a manual 5speed 2000 328i with 97k miles. Theres a strange vibration and sound when I first start to accelerate. I also have to apply more gas than usual to get it going. Almost feels/sounds like the tires are rubbing against something, but as far as I can tell, they aren't. Its only when I start to accelerate and is not noticeable once i get over 15 mph. Its more of a rhythmic sound/vibration too. Like "rrrRRRrrrRRRrrrRRR". I dont want to drive the car in fear of making the problem worse. If anyone else has experienced this or has any advice or opinions PLEASE help. It will be much appreciated
Sam-I-Am328 is offline   Reply With Quote
Old 10-15-2011, 03:23 PM   #2
Sam-I-Am328
Also, Im more of a fix-it-yourself kinda guy, but I might be in over my head on this one. Just out of curiousity, how much would it cost to get it looked at by a shop/dealership in San Diego CA?
Old 10-15-2011, 03:39 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Try jacking up the front and rear and spinning the wheels. I'm thinking maybe brakes binding, since you brought up the tires rubbing...and it's not that.
E-brake is possible too. Feel for different amounts of heat from the rotors after driving a little...use your finger and count how long until you can't hold it on any longer. If you're a girl, you could spit on your finger first!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-15-2011, 03:45 PM   #4
Vic328CSi
My Ride: depends on the mood
Most likely a wheel bearing issue, thats what I would check first. Had very similar symptoms to yours on my '00 328Ci that got louder and louder the more time passed. Intially it was only at low speeds, then it got real bad at any speed. The pass-rear wheel bearing was toast. Was a bit difficult diy since those things are pressed in tight, but not impossibe. Replaced wheel bearing, all noise gone. These things go every 100k miles usually.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
strange sound, strange vibration
